Displaying an ASCII spiral in 6502
- lightbeing
A challenge was recently organised on facebook.
The aim was to create a short BASIC program displaying an ASCII code progressively on the screen, following the shape of a spiral which starts at the centre of the screen. The challenge was opened to all computers.
I wrote a code in assembly for the Commodore 64. Whilst writing it, I figured out that it could be used actually on any computer based on the 6502 processor. It just needed some ajustments for the screen memory adresses and # of rows. The final shape of the spiral on the screen is a perfect square (25 x 25 on the Commodore 64, 25 being the # of rows).
It takes around 20,000 cycles. It's based on 4 subroutines (each computing the positions on the left, right, up and bottom) with ADC and SBC running in a loop, and self-modifying code. Nothing exceptional nor fantastic.
While writing it, I thought that a similar challenge could be organised just for the fun of sharing knowlege and practices. Anyone interested?
Re: Displaying an ASCII spiral in 6502
Could you show us a sketch of the target shape? (Either as ascii art in CODE tags, or as an attached image)
But how can a spiral turn into a square?
Or do you mean like a turtle graphics spiral, turning 90° and increasing the side length by 1 every turn?
Like this, but with ASCII "graphics":
- lightbeing
The FINAL shape of the spiral is a square when the drawing has finished.
But each ASCII output during the drawing on the screen is performed as a rotation (left or right)
Here's how the final shape looks like with 205/206 PETSCII codes.
The facebook group is BASIC language programming:
https://www.facebook.com/groups/2057165187928233
The result of the challenge is here
https://magentacloud.de/s/nEcAdCPDiteLgPp
- Attachments
- vice-screen-2024011119332343.png (5.82 KiB) Viewed 6996 times
OK, so it's a spiral fill pattern, printing whatever (but the usual diagonal "maze" happens to look good)
By spiral fill I mean something like
5 4 3 12
6 1 2 11
7 8 9 10- lightbeing
5 4 3 12
6 1 2 11
7 8 9 10Re: Displaying an ASCII spiral in 6502
I eventually found it on Facebook - dates back to November 2023.
https://www.facebook.com/10000937048512 ... 862283827/
This is Richard Russels entry in BBC Basic:
https://wasm.bbcbasic.net/bbcsdl.html?a ... s%2Fcompo4
And, sorry to be a grump, but after taking far too long to try to find the original posting on Facebook and then having to wade through what I consider to be an utterly dreadful website with the results I have to say that frankly I just can't be bothered at this point.
I strongly suggest that in-future you provide direct links or just re-post the entire thing here so that those who care can see what you mean with the minimal of effort because life's just too short.
10 MODE 1
20 VDU 5,19,1,4,0,0,0
30 GCOL 0,129 : CLG
40 VDU 23,205,&80,&40,&20,&10,&08,&04,&02,&01
50 VDU 23,206,&01,&02,&04,&08,&10,&20,&40,&80
60 X = 608 : Y = 512 : N = 1
70 REPEAT
80 FOR I = 1 TO N : MOVE X,Y : VDU 205.5 + RND(1) : X = X+32 : T = INKEY(1) : NEXT
90 FOR I = 1 TO N : MOVE X,Y : VDU 205.5 + RND(1) : Y = Y+32 : T = INKEY(1) : NEXT
100 N = N+1
110 FOR I = 1 TO N : MOVE X,Y : VDU 205.5 + RND(1) : X = X-32 : T = INKEY(1) : NEXT
120 FOR I = 1 TO N : MOVE X,Y : VDU 205.5 + RND(1) : Y = Y-32 : T = INKEY(1) : NEXT
130 N = N+1
140 UNTIL N > 40
150 ENDAnd, sorry to be a grump, but after taking far too long to try to find the original posting on Facebook and then having to wade through what I consider to be an utterly dreadful website with the results I have to say that frankly I just can't be bothered at this point.
I think there’s an interesting challenge in optimising some 6502 code which makes coordinates for this kind of spiral. I’ve previously seen this spiral as an Ulam Spiral, where each point is used to indicate if a number is prime or not.
- lightbeing
On a computer with 40 colums, the rotation will move on the screen by adding or subtracting those values +1,+40, -1,-1,-40,-40,+1,+1,+1,+40,+40,+40 and so on.
The "fastest" way would be to builld a table with precalculated positions (high byte and low byte) but the table would take 1250 bytes (based on 25 rows). Furthermore, I tend to consider that precalculated positions is not really... "sexy".
A table doesn't seem very interesting, that's for sure! Often these challenges have a size limitation, or will score on the basis of size, so that can push solutions towards ingenuity. The smallest code to do the job might be a good challenge, in fact... I don't think it's likely to be slow, in any case.
I think we just need to move left one then down one, then right two and up two, then left three and down three, and so on. One way could be to store a direction vector starting with (-1,0) and rotate it left 90 degrees at each corner by swapping its elements and negating the new first element - so (-1,0) becomes (0,-1) then (1,0) then (0,1) and then back to (-1,0). The numbers are small enough that they don't wrap, which helps! Or it may make more sense to unroll the loop. I might sketch something a bit later if I get time.
- lightbeing
- lightbeing
You're right. The length of the code should be limited to a maximum number of bytes. Mine is 143 bytes long. Although it uses 7 bytes for the waiting loop, I have the feeling that it's not completely optimised and ingenious. I guess 200 bytes long is far enough.
I would also add the following rules in order to make the competition fair:
- pure 6502 legal codes
- use of screen memory and one ASCII/screen code
- use of "internal" routines prohibited
- direction of rotation may be right or left
- final shape displayed on screen is 25x25 (you can do more but it takes more cycles...)
If anyone is interested in participating or helping me in organising the challenge, just let me know.
- Attachments
- vice-video-2024011313094162.gif (306.83 KiB) Viewed 6855 times
