Now, I have in the past done a lot of work in systems with sorts and they are incredibly useful, but I'm by no means an expert and have my favourites, but given the constraints in the original article I was somewhat surprised at the algorithm chosen - of-course it's a demonstration of comb sort, but there is another little favourite of mine when you have those sort of constraints - a small array with a well-defined range of elements - and it's a form of radix or bucket sort, so looking for more little examples and tests for my TinyBasic, I knocked one up in it:
The idea of the bucket sort is that you don't do any compares or swaps - you practically throw away the input data and re-create it by counting each item into a list of buckets, then "re-play" the bucket list back into the output data. It's used when you have well defined inputs (in this case numbers from 0-255) and a limited number on numbers (here, an array 256 elements in size). When data sizes increase it starts to get beyond the capabilities of 8-bit systems very quickly, but can still be used in parts. A common use is in 3D rendering when you want to sort objects by distance so you can draw the furthest away objects first which would them be overdrawn (in part or whole) by closer objects when rendering the scene to a 2D surface - as long as you can sort and draw fast enough you get all the hidden surface hiding for free... In our 6502 world if you have a data set such as described here then you could code this sort and the times will be measurable in microseconds...
So One pass, No compares, No swaps.
Ok, you need a 2nd pass to re-create the actual data and you need double the storage but if you want speed that's the trade-off...
So after I'd satisfied myself this morning I had another look and decided to add bad old Bubble sort and my usual go-to sort which is Shell sort. I was surprised that Comb sort as on-par with Shell sort given it's relative simplicity but not surprised by how slow bubble sort was...
Sort for an array of 256 elements of random numbers: (The same input on all tests)
- Bucket sort: 1.07 seconds
- Comb sort: 7.34 seconds
- Shell sort: 7.67 seconds
- Bubble sort: 57.5 seconds
(A few notes: This is my GIBL TinyBasic on a 16Mhz 6502. The ! and ? operators are like peek and poke - ! is for 16-bit words and ? is for 8-bit bytes. !160 = 0 stores 0 in memory locations 160 and 161 and these are the bottom 2 bytes of the 100Hz ticker that's maintained by the underlying OS. TOP is the start of free memory available for strings and arrays).
NEW
REM Sorts
REM Input is an array of 256 elements of 0-255
100 X = TOP : REM Input/Output
110 Y = X + 256 : REM Bucket counts
REM Initialise counts and Generate random input
REM Get data
120 GOSUB 800
REM Print Input
129 PR "Original data:"
130 GOSUB 900
REM Bucket Sort
150 GOSUB 600 : PR "Bucket Time: ", T : GOSUB 900
REM Comb
240 GOSUB 800
250 GOSUB 700 : PR "Comb Time: ", T : GOSUB 900
REM Bubble
260 GOSUB 800
270 GOSUB 500 : PR "Bubble Time: ", T : GOSUB 900
REM Shell
280 GOSUB 800
290 GOSUB 400 : PR "Shell Time: ", T : GOSUB 900
299 END
400 !160 = 0 : REM Zero the clock
405 M = 1 : E = 255
410 DO : M = M * 3 + 1 : UNTIL M > E
420 DO
430 M = M / 3
435 FOR I = M TO E
440 V = ?(X+I) : J = I
450 K = J - M
455 IF (K < 0) OR (?(X+K) < V) GOTO 475
460 ?(X+J) = ?(X+K)
465 J = K
470 GOTO 450
475 ?(X+J) = V
477 NEXT I
485 UNTIL M = 1
490 T = !160 : REM Read the clock
499 RETURN
REM Classic Bubble Sort
REM ============================================================
500 !160 = 0 : REM Zero the clock
510 FOR I = 0 TO 255
515 FOR J = I TO 255
520 IF ?(X+I) > ?(X+J) T = ?(X+I) : ?(X+I) = ?(X+J) : ?(X+J) = T
530 NEXT J
540 NEXT I
550 T = !160 : REM Read clock
560 RETURN
REM Bucket sort
600 !160 = 0 : REM Zero the clock
610 FOR I = 0 TO 255
620 Z = ?(X+I) : Q = Y + Z : REM Index
630 ?Q = ?Q + 1 : REM Count
640 NEXT I
REM Re-Create sorted data from bucket counts
650 J = 0 : FOR I = 0 TO 255
660 C = ?(Y+I) : REM Count in this bucket
670 IF C <> 0 DO : ?(X+J) = I : J = J + 1 : C = C - 1 : UNTIL C = 0
680 NEXT I
690 T = !160 : REM Read clock
699 RETURN
REM Comb/Combination Sort
700 !160 = 0 : REM Zero the clock
705 S = 256 : G = 256 : REM Initial values
710 DO
715 G = G * 10 / 13
720 IF G < 1 G = 1
725 W = 0
730 FOR I = 0 TO 255 - G
740 J = I + G
750 IF ?(X+I) > ?(X+J) T = ?(X+I) : ?(X+I) = ?(X+J) : ?(X+J) = T : W = W + 1
760 NEXT I
770 UNTIL (G = 1) AND (W = 0)
780 T = !160 : REM Read clock
799 RETURN
REM Generate Random input (and zero the bucket counters)
800 RND = 1234 : REM Seed, so we get the same 'random' numbers
810 FOR I = 0 TO 255
820 ?(X+I) = RND % 256 : ?(Y+I) = 0
830 NEXT I
840 RETURN
REM Print the input array
900 @ = 3 : Q = 0
910 FOR I = 0 TO 255
920 PR ?(X+I);
930 Q = Q + 1 : IF Q = 16 Q = 0 : PR ""
940 NEXT I
950 PR ""
960 RETURNCode: Select all
Original data:
81 95 205 19 68 220 193 23 88 65 234 42 139 116 182 222
192 74 156 192 81 79 144 197 206 83 180 57 153 7 72 108
180 228 105 255 32 112 101 106 179 28 70 199 231 25 26 1
41 183 59 236 61 35 52 249 33 142 19 149 245 235 49 119
159 0 138 219 12 20 6 79 144 120 189 227 195 63 99 229
14 146 199 8 26 6 75 156 6 171 239 241 209 113 149 27
252 45 49 38 247 41 186 35 139 213 25 255 61 163 199 200
18 127 96 181 230 122 239 49 26 70 72 234 43 149 121 190
167 200 93 130 211 77 94 134 168 176 116 216 25 135 40 44
53 218 12 81 194 222 0 85 61 253 38 134 8 185 218 195
68 149 254 110 191 225 245 219 65 143 211 180 118 107 140 145
218 7 171 124 174 178 164 142 208 25 253 34 100 93 190 231
111 240 26 75 155 133 171 253 102 234 207 17 82 207 16 116
253 35 116 152 138 168 250 99 235 52 30 95 64 225 101 138
12 93 129 151 133 219 15 144 25 71 104 109 206 51 183 88
130 206 208 66 148 204 81 71 136 209 186 123 220 4 137 47
Bucket Time: 107
0 0 1 4 6 6 6 7 7 8 8 12 12 12 14 15
16 17 18 19 19 20 23 25 25 25 25 25 26 26 26 26
27 28 30 32 33 34 35 35 35 38 38 40 41 41 42 43
44 45 47 49 49 49 51 52 52 53 57 59 61 61 61 63
64 65 65 66 68 68 70 70 71 71 72 72 74 75 75 77
79 79 81 81 81 81 82 83 85 88 88 93 93 93 94 95
95 96 99 99 100 101 101 102 104 105 106 107 108 109 110 111
112 113 116 116 116 116 118 119 120 121 122 123 124 127 129 130
130 133 133 134 134 135 136 137 138 138 138 139 139 140 142 142
143 144 144 144 145 146 148 149 149 149 149 151 152 153 155 156
156 159 163 164 167 168 168 171 171 171 174 176 178 179 180 180
180 181 182 183 183 185 186 186 189 190 190 191 192 192 193 194
195 195 197 199 199 199 200 200 204 205 206 206 206 207 207 208
208 209 209 211 211 213 216 218 218 218 219 219 219 220 220 222
222 225 225 227 228 229 230 231 231 234 234 234 235 235 236 239
239 240 241 245 245 247 249 250 252 253 253 253 253 254 255 255
Comb Time: 734
Bubble Time: 5750
Shell Time: 767
