Want to check my understanding on some timings.
Yuri
Post by Yuri »
So I'm about to get some 32Mhz oscillators and try and boost my 6502 from 6.29375MHz up to 8Mhz.
I was reviewing the timing notes of my parts, particularly the ROM which is asking for a 150ns setup time and I got to wondering.
At 6.29375Mhz the whole period is about 159ns (minus some change)
Would I be correct in understanding that each horizontal edge of the clock is about 80ns (give or take rise/fall times)?
Further it would seem from the 6502 data sheets, that @ 8MHz there is about 40ns for the address to be setup, and then about 10ns for it to be valid.
4Mhz suggests these are 75ns and 10ns, still a far cry from the 150ns that the ROM data sheet asks for.
So my basic question is:
Am I effectively overclocking my ROM?
I'm not implementing any clock stretching, though I have noticed when I single step the clock, the address lines seem to hold for two clock cycles while the 6502 does it's internal thing.
IDK if the bus is actually floating during this time and I'm just seeing a latent charge or what, but I'm wondering if this side effect is effectively enough time to let the ROM do its thing.
Thanks
Yuri
Re: Want to check my understanding on some timings.
Post by Yuri »
Probably would help to provide the datasheet for the ROM I'm using. Here it is.
AT28C64B-15PU.pdf
(231.65 KiB) Downloaded 91 times
You might find your answers in this post and the ones that follow:
viewtopic.php?p=58784#p58784
Yuri wrote:
So I'm about to get some 32Mhz oscillators and try and boost my 6502 from 6.29375MHz up to 8Mhz...
You should clarify if “6502” refers to the NMOS part or the 65C02.
As for whether you are “overclocking” your EEPROM, use the most pessimistic timing specs for the EEPROM and the most optimistic specs for the MPU to calculate how fast you can run with that particular EEPROM without violating its timing.  Be sure to account for propagation delays through your glue logic.  It’s nothing more than basic math and understanding what the data sheet is telling you.  :D
As Garth notes in the post he referenced, the manufacturer guarantees that the device will perform as specified.  Any given device may well perform better than specified, sometimes a lot better—I’ve run into that on occasion.  However, you can’t bank on it.  How far you are willing to push the limits depends on how much stability you are willing to sacrifice.
Yuri
Post by Yuri »
I'm using the 65C02.
Right, and I do get that some parts may perform better than others for various reasons, and that the data sheets specify what the manufacturer grantees the part for.
More to the point, I want to make sure I'm actually reading these sheets and mathing this correctly. Thus, did I get lucky and got a particularly spry ROM that is fine with operating at near half the time it says it should, or am I doing my math wrong?
That was the origin of the question.
The 150ns rating of that particular EEPROM represents the amount of time that will elapse from when the device’s address, /CS and /OE inputs have stabilized until it drives the data bus.  In a circuit with the 65C02, as long as the EEPROM can produce output at least tDSR nanoseconds before the next fall of the clock, a read operation should be successful.  tDSR is 10ns with the MPU running on 5 volts.  Hence the EEPROM must have stabilized the data bus no less than 10ns before the fall of Ø2 in order for the MPU to be able to read valid data at the fall of the clock.
The point in the clock cycle at which the 65C02 will place an address on the bus after the fall of the clock is defined by the tADS spec.  That number is 30ns, worst case, on 5 volts.  Simplified, the elapsed time from tADS to tDSR is the “window” during which the EEPROM’s /CS and /OE inputs must be asserted, and the device itself must respond and drive the data bus.  If the EEPROM can’t drive the data bus by the end of that window, the MPU will likely see garbage.
Yuri wrote:
...I want to make sure I'm actually reading these sheets and mathing this correctly. Thus, did I get lucky and got a particularly spry ROM that is fine with operating at near half the time it says it should, or am I doing my math wrong?
Indeed, with a 150ns ROM, you're out of spec to run at 8MHz. But as noted, this will often work, in part because of how specifications are drawn up and how chips are made and tested, and in part because you're not running at extreme temperature and voltage.
