Trying to grok the Woz FP routines
SpacedCowboy
Post by SpacedCowboy »
So I'm trying to figure out what's going on here - I'm having a go at writing a high-level compiler for the 6502, and it'd be nice to have a 'float' datatype, but I'm not managing to understand '1-2' at this point :)
I wrote a little routine to convert a float to 'woz' format, and it gives me:
@elysium xtal % wozf 1
 f: 80:400000
@elysium xtal % wozf 2
 f: 81:400000
... which makes sense to me given the description of the floating point format here (PDF). For '1', the exponent is 0 and the units bit is 1, sign=0. For '2', the mantissa is the same, the exponent is one higher.. So far so good.
I set up space in ZP for three 4-byte FP "registers" at $80 (flt_{x,m}2), $84 (flt_{x,m}1) and $88 (flt_e) - where each one is laid out as {1-byte exponent (x), 3 byte mantissa (m) inc sign bit}. After loading in the representation for '1' into flt2 and '2' into flt1, I see:
0080: 80 40 00 00 81 40 00 00  ;·@···@··
0088: 00 00 00 00 00 00 00 00  ;········
Next we call fsub (result in flt1 = flt2 - flt1), which is implemented as:
jsr fcompl                 ; create the -ve of flt1
jsr alignsw                ; align flt1 and swap flt1,flt2 if needed
 ... (fall through into fadd)
For clarity, the overall call hierarchy looks like:
│    f_sub    │
       ├─▶│   fcompl    │────▶│   addend    │────▶│    norm     │
       ├─▶│   alignsw   │────▶│    swap     │
       └─▶│    fadd     │
Tracking through that, we start off in fcompl, which is:
	sec						   ; set the carry
	ldx #$03					 ; set up for 3 byte subtraction
compl1:
	lda #0						; clear A
	sbc flt_x1,x				; subtract byte of exp1
	sta flt_x1,x				; restore it
	dex							; next byte
	bne compl1				  ; loop until done
compdone:
	beq addend				  ; normalise (or shift right on overflow)
... which (at the point of 'compdone' has the expected effect of turning the $40 in flt1 to $c0. No change to the exponent because it's just operating on the mantissa, and the other two bytes of this mantissa are 0..
0080: 80 40 00 00 81 C0 00 00  ;·@······
I should probably point out that these are actually the values I want to see...
80:400000 is "1", and
81:C00000 is "-2"
However, the next call is to addend, which is implemented as either a branch to 'norm' (normalize the mantissa) or 'rtlog' (shift the 6 bytes of flt1/e mantissas one bit to the right):
addend:
	bvc norm					 ; no overflow, normalise results
	bvs rtlog					; ov: shift mant1 right, note carry is correct sign
In this case, V is clear, so we jump to 'norm'... which is implemented as
norm1:
	lda flt_m1				  ; high order mantissa-1 byte
	cmp #$c0					 ; upper 2 bits unequal ?
	bmi rts1					 ; y: return
	dec flt_x1				  ; decrement exponent-1
	asl flt_m1+2				; 3-byte shift of mantissa-1 left
	rol flt_m1+1
	rol flt_m1
norm:
	lda flt_x1				  ; Mantissa-1 high-byte
	bne norm1					; no, continue normalising
rts1:
	rts							; all done
Tracing this, We
  • load A with contents of $84 (set to $81) as above,
  • it's not 0, so we run through the norm1 code.
  • On the first pass, flt_m1 (the first byte of flt1's mantissa) is $C0 (sign bit, $80, and the top mantissa bit both set), so we fail the BMI test
  • then we decrement the exponent (old value of $81 -> $80)
  • then do the asl/rol sequence,
  • loop around again because $80 isn't 0,
  • this time we pass the CMP test and return.
At this point, the data in page zero looks like:
0080: 80 40 00 00 80 80 00 00  ;·@······
So now we're back in fp_sub, at the 'jsr algnsw' stage. The code for algnsw is:
algnsw:
	bcc swap					; swap if carry clear, else shift right
In this case the carry is clear, so we jump to swap, which just swaps the bytes in the two floating point registers flt1 and flt2 (also storing a copy of the flt2 mantissa in flt_e)
swap:
	ldx #$04					; set up for 4-byte swap
swap1:
	sty flt_e-1,x			 ; copy to E
	lda flt_x1-1,x			; swap a byte of exp/mant1 with..
	ldy flt_x2-1,x			; exp/mant2 and leave a copy of..
	sty flt_x1-1,x			; mant1 in E (3 bytes). E+3 used
	sta flt_x2-1,x
	dex						  ; next byte
	bne swap1				  ; loop until done
	rts
And once that's called, we look (predictably) like:
0080: 80 80 00 00 80 40 00 00  ;·····@··
0088: 40 00 00 00 00 00 00 00  ;@·······
At this point, we're about to drop into the floating-point add routine, and add the negative-of-what-we-passed-into-flt1 to what-we-passed-into-flt2. The problem is that the two numbers in the registers are now
flt2 (@$80) = 80:800000 or "-0" [this started off as 2]
flt1 (@$84) = 80:400000 or "1" [this is unchanged, just swapped from the other register]
unsurprisingly the add routine returns the wrong results... I have checked and re-checked that this code accurately represents the code in the afore-linked PDF (and I used the second (later) version, assuming the one burnt into the Apple ][ ROM would be "good"), so I'm a bit confused over what I'm doing wrong here. I'm assuming [grin] that there isn't a mistake in code that's almost 50 years old and has had a lot of eyes on it - so perhaps there's some setup I'm not aware of, or something similar ? I did try to keep the register-layout order the same in case there was rol/asl from one register into another...
The test with $C0 looks "iffy" to me, because (ignoring the no-errors-in-code-this-used credo for a moment), the test is supposed to be (as I understand it) that "the top two bits of the mantissa ought not be the same", but the test against $C0 is testing the top-bit of the mantissa with the sign bit of the mantissa, and I didn't *think* the sign bit counted. If that is a bug, then an ASL A inserted before the CMP $C0 would fix it, I think.
Yeah, scratch that. Inserting an ASL A in there causes the addition of 1 to 2 to break, whereas it previously worked.
Any advice gratefully received :)
vbc
Re: Trying to grok the Woz FP routines
Post by vbc »
I have not looked deeper into the woz code for some times, but I compiled a small test program with vbcc using the woz library and checked a few of your steps.
 f: 80:400000
 f: 81:400000
Those values look ok to me.
Same here.
I also get those values, but when calling my printf with 80800000, it prints -2 rather than -0, so probably those values are ok?
What value do you get and what value do you expect? I get 7f800000 which is printed as -1.
I think some fixes were made to the original code at some time, but I would also assume that 1-2 has always been correctly calculated.
Hopefully that helps a bit?
SpacedCowboy
Nope, it doesn't. It helps a lot :D
I think what is apparent is that I need to understand the FP format better, if 80800000 is printing as -2 for you. I went back and looked at the PDF again, and in the FP examples he gives, there's no representation of -2, but there is a -4 (which is 81800000) - and that's consistent with -2 being 80800000. I just don't understand how :)
Elsewhere in the docs, it lays out the mantissa as:
HIGH-ORDER MANTISSA BYTE
     01.XXXXXX  Positive mantissa.
     10.XXXXXX  Negative mantissa.
     00.XXXXXX  Unnormalized mantissa.
     11.XXXXXX  Exponent = -128.
... and specifically says an exponent of $80 is 0. I can't easily reconcile that with 80800000 being -2. I would expect it to be:
@elysium ~ % wozf -2
 f: 81:c00000
I have checked other values from the source code against my 'wozf' command line app - and they seem to match up, these are in the code as constants:
1DD5  7F 58    LE2    DCM 0.69314718  LOG BASE E OF 2
      B9 0C
1DE1  80 6A    C      DCM 1.6567626
      08 66
1DE5  7F 40    MHLF.  DCM 0.5
      00 00
And I get the same bit layout:
@elysium ~ % wozf 0.69314718 1.6567626 0.5
 f: 7f:58b90c
 f: 80:6a0866
 f: 7f:400000
So maybe there's some sort of implied '1' somewhere if the mantissa is 0 ? I was working on it just being a simple two's-complement number but there appear to be wrinkles :)
Anyway, thank you very much for the reply, and for the data you're seeing. Being able to compare is half the battle :)
vbc
Post by vbc »
 f: 81:c00000
vbcc also creates 81C00000 for -2. However, according to that description that would imply an exponent of -128? It does seem to work though, and both values do compare equal:
volker@legion5:/tmp$ cat f.c
#include <stdio.h>
long x=0x00008080,y=0x0000c081;
int main()
 printf("%g %g %d\n",*(double*)&x,*(double*)&y,(*(double*)&x)==(*(double*)&y));
volker@legion5:/tmp$ vc +s6502 f.c -lm
volker@legion5:/tmp$ emulator
-2 -2 1
I presume for normal numbers the mantissa should be between [-2..-1[ or [1..2[, with:
01 0...0 => +1.0 to 01 1...1 => +2.0 (almost), and
10 0...0 => -2.0 to 10 1...1 => -1.0 (almost)
So 0x80800000 would be -2.0*2^0. Not sure if 0x81C00000=-1.0*2^1 is an actually intended representation.
SpacedCowboy
To answer your earlier question, I too get 7f:800000 as my answer for 1-2, which means it was actually working, I just didn't understand how that representation was supposed to be interpreted.
If 80:800000 is -2, and following your logic, I could see that being reasonable, then it follows that 7f:800000 is -1 (as in: -2 >> 1)
I really don't think the documentation is very clear on this though :)
Let me encourage use of capital A-F in hex numbers.  The '7f' above sure looks like '71' on my monitor.  I only knew from the context that it was an F.
BB8
Post by BB8 »
0x81C00000 has "C0" as upper byte, which has the two upper bits set (11xxxxxx), so it is not normalized per the woz format
Powersoft
Post by Powersoft »
 f: 81:c00000
      B9 0C
      08 66
      00 00
 f: 7f:58b90c
 f: 80:6a0866
 f: 7f:400000
Nice discussing. I am playing also with these routines, but I strugle with the in- and output. You wrote a nice routine wozf to show the numbers. Plese can you show the code for this litle program
AndrewW
Post by AndrewW »
New forum member bumping up an old thread.
I put together some 6502 code to output the exact decimal representation of Rankin/Wozniak FP values. It uses only integer arithmetic, and (given a big enough ZP buffer) will output the exact decimal equivalent of the 32-bit FP value to 40+ significant figures. While not necessarily useful for real-world use, this may help with debugging. Code below, including a test harness. Assemble it with the Rankin/Wozniak routines, then call PFLOAT to print the value in X1,M1 via OUCH, a routine to print one ASCII character passed in A (which you or your monitor/firmware should supply). Execute from $0F00 to run the test harness which prints a table of values in hex and decimal.
When I copied across the values in the DCM directives in the exponent code for testing, I discovered that some versions of the original routines have a typo in the DCM for C2. The decimal value in the comments is .03465735903. Some versions give the corresponding hex values as $7B, $46, $FA, $70, whose exact value is 0.03465735912322998046875, matching the DCM value to 8 significant figures. However, some versions give the hex as $7B, $46, $4A, $70, which only agrees to 2 SF. OCR error somewhere along the line?
Comments welcome - especially from anyone who can make the code shorter. 151 bytes is quite embarrassing given the famous terseness of Woz's code!
; PFLOAT  - Print exact decimal value represented by Wozniak/Rankin FP value in X1, M1.
;           Requirements: 1. A buffer in Zero Page, base address DIGITS, length BSIZ bytes.
;                         2. OUCH, a subroutine that prints the ASCII character in A
;                            (which may be overwritten), and which preserves contents of
;                            the X register.
;           Input:        FP value to be printed in X1, M1.
;           Output:       Decimal value printed using OUCH, - OR -
;                         If the integer part of the decimal representation is longer
;                         than BSIZ-2 bytes, overflow indicated by printing "E!".
;                         If the fractional part of the decimal representation is longer
;                         than BSIZ-1 bytes, it's truncated at BSIZ-1.
;                         X1,M1 overwritten.
;           This version assembled using atasm 1.08 (https://atari.miribilist.com/atasm/),
;           adapted to write tape images for Tim Baldwin's excellent Compukit UK101
;           emulator. Tested on emulator v1.4.0 (https://uk101.sourceforge.net/). I'll
;           update to the latest versions of both assembler and emulator one day ...
;           Andrew Watson
;           notinteresting@gmx.com
;           13 November 2023
        * = $0D00
OUCH    = $BF2D             ; Print one character (UK101 MON01)
BSIZ    = 100               ; Number of bytes in the print buffer
DIGITS  = $50               ; Somewhere on zero page where we can use 100 consecutive bytes
; Print the float in X1 in non-scientific notation
PFLOAT  LDA X1
        BNE NOTZRO
        LDA #'0
        JMP OUCH            ; It's zero. Handle as special case.
NOTZRO  LDA M1
        BPL NOTNEG          ; It's positive, so just print it
        LDA #'-             ; It's negative - print minus sign
        JSR OUCH
        JSR FCOMPL          ; Negate FP1, to make it positive, then fall through to print
; First, print the integer part
NOTNEG  LDA #$80            ; Sentinel
        STA DIGITS+BSIZ-1   ; Store a sentinel at start of decimal representation
        STA DIGITS+BSIZ-3   ; ... and anoter at the other end
        ASL                 ; Make $80 into zero
        STA DIGITS+BSIZ-2   ; ... and store that as the initial digit
; Exponent tells us how many times to shift out integer part. $01-$7F = no integer bits,
; $80 = one bit, $81 = two bits, $82 = three bits, etc
        LDY X1              ; Get exponent
        INY                 ; Always shift left at least once (MSB into old sign bit)
DIG     LDX #BSIZ-2         ; Pointer to first digit
        ASL M1+2
        ROL M1+1            ; Rotate 3 byte mantissa left by one bit
        ROL M1              ; Most Significant Bit goes into C
        LDA DIGITS,X        ; Load A with least significant decimal digit
AGN     ROL                 ; Double the digit, with carry in (carry out always 0)
        CMP #10             ; Did digit overflow?
        BCC M               ; No
        SBC #10             ; Doubling overflowed, so subtract 10 and set carry
M       STA DIGITS,X        ; Store the doubled digit back
        DEX                 ; Point to next most significant decimal digit
        LDA DIGITS,X        ; Fetch it
        BPL AGN             ; If it is a digit, loop back to process it
        BCC R               ; It's the sentinel, not a digit. Branch away if no carry in.
        DEX                 ; We're going to add a decimal digit, if there's room
        BMI ERROR2          ; ... but branch away to error handler if digit buffer now full
        STA DIGITS,X        ; Store the sentinel ($80) to left of new Most Significant Digit
        ROL DIGITS+1,X      ; Turn previous sentinel into digit 1 (C is always 1 here)
R       DEY                 ; Keep counting down the exponent
        BMI DIG             ; ... until it's $7F
; We're done converting the integer part - print it (it could be 0).
        JSR PRB
; Now print the fractional part - which is potentially all 24 bits of the FP number
        LDA #$82
        STA DIGITS          ; For fractional part, use $82 as the sentinel
        LDY #$E8            ; Bit counter could be -24 (we'll count up)
        LDA X1
        BMI DIG1            ; If exponent $80 to $FF, we must shift mantissa 24 times
        CLC                 ; If exponent $01 to $7F, we'll calculate shift count
        ADC #$69            ; Shift count: $7F -> -24 ($E8), $7E -> -25, $7D -> -26, etc.
        TAY                 ; Put count in Y.
DIG1    LSR M1
        ROR M1+1
        ROR M1+2            ; Rotate 3 byte mantissa one bit right, LS bit into C
        LDX #0              ; Start shifting decimal representation at MS digit
        BEQ AGN1            ; Always
LX      BCC NOA             ; No carry down
        ADC #9              ; Add the carry into this digit (C is always set)
NOA     LSR                 ; Divide digit by two
        STA DIGITS,X        ; Store it back
        INX                 ; Step on to next digit
AGN1    LDA DIGITS,X        ; Load that digit (or sentinel)
        BPL LX              ; Loop, unless it's the sentinel
SENT    BCC R1              ; We're at the sentinel. Branch away if no carry into it.
        CPX #BSIZ-1         ; Would moving sentinel overflow the buffer?
        BCS R1              ; If it would, don't do it
        SEC                 ; Reset carry after CPX
        ROL DIGITS,X        ; Turn old sentinel into a 5
        STA DIGITS+1,X      ; Store the sentinel in its new location
R1      INY                 ; Count number of mantissa shifts
        BNE DIG1            ; Loop back if we still have mantissa bits to shift
        LDA DIGITS          ; Is the sentinel at the start of the buffer?
        BMI NOFRAC          ; If so, there is no fraction, so don't print anything
        LDA #'.             ; Ready to print decimal point
        LDX #$FF            ; Ready to step through digits of the fractional part
NC      JSR OUCH            ; Print digit (or decimal point first time)
PRB     INX                 ; Step on to first/next digit
        ORA #'0             ; If it's a digit, make it ASCII
        BPL NC              ; But if it was sentinel, fall through instead
NOFRAC  RTS                 ; All done
ERROR2  LDA #'E             ; Error handler if the integer part overflows
        JSR OUCH            ; Print 'E'
        LDA #'!             ; ... and an exclamation mark
        JMP OUCH            ; ... and exit
; From here to the end is a test harness that loads floating point numbers into X1 and
; prints them in both hex and floating point.
; Table of floating point test values
TESTS = *
        .BYTE $00, $00, $00, $00    ; 0
        .BYTE $80, $40, $00, $00    ; 1
        .BYTE $81, $60, $00, $00    ; 3
        .BYTE $83, $60, $00, $00    ; 12
        .BYTE $85, $78, $00, $00    ; 60
        .BYTE $85, $88, $00, $00    ; -60
        .BYTE $88, $44, $80, $00    ; 274
        .BYTE $93, $7A, $12, $00    ; 1,000,000
        .BYTE $80, $C0, $00, $00    ; -1
        .BYTE $7C, $40, $00, $00    ; 0.0625
        .BYTE $96, $7F, $FF, $FF    ; 8,388,607
        .BYTE $93, $7A, $11, $FF    ; 999,999.875
        .BYTE $93, $7A, $11, $F8    ; 999,999
        .BYTE $A0, $40, $00, $00    ; 4,294,967,296
        .BYTE $80, $44, $00, $00    ; 1+2E-4 = 1.0625
        .BYTE $80, $40, $00, $01    ; 1+2E-22 = 1.0000002384185791015625
; Values extracted from the Rankin/Wozniak source, with PFLOAT output for comparison
        .BYTE $7E, $6F, $2D, $ED    ; 0.4342945
;                           (actually 0.434294521808624267578125, same to 7 SF)
        .BYTE $80, $5A, $82, $7A    ; 1.4142136   SQRT(2)
;                           (actually 1.414213657379150390625, same to 8 SF)
        .BYTE $7F, $58, $B9, $0C    ; 0.69314718  LOG BASE E OF 2
;                           (actually 0.693147182464599609375, same to 8 SF)
        .BYTE $80, $52, $B0, $40    ; 1.2920074
;                           (actually 1.2920074462890625, same to 8 SF)
        .BYTE $81, $AB, $86, $49    ; -2.6398577
;                           (actually -2.639857769012451171875, same to 8 SF)
        .BYTE $80, $6A, $08, $66    ; 1.6567626
;                           (actually 1.656762599945068359375, same to 7 SF)
        .BYTE $7F, $40, $00, $00    ; 0.5
;                           (actually 0.5, same)
        .BYTE $80, $5C, $55, $1E    ; 1.4426950409   LOG BASE 2 OF E
;                           (actually 1.442695140838623046875, same to 7 SF)
        .BYTE $86, $57, $6A, $E1,   ; 87.417497202
;                           (actually 87.4174957275390625, same to 7 SF)
        .BYTE $89, $4D, $3F, $1D,   ; 617.9722695
;                           (actually 617.9722900390625, same to 7 SF)
        .BYTE $7B, $46, $FA, $70,   ; 0.03465735903
;                           (actually 0.03465735912322998046875, same to 8 SF)
        .BYTE $83, $4F, $A3, $03,   ; 9.9545957821
;                           (actually 9.9545955657958984375, same to 7 SF)
LASTST   = * - TESTS
; Print byte in hex
PBYTE   PHA                 ; Save input byte
        LSR
        LSR
        LSR
        LSR                 ; High nybble shifted down
        JSR PNYBBLE         ; Print it
        PLA                 ; Get original byte back
PNYBBLE AND #$0F            ; Print nybble
        ORA #$30            ; 0-9 -> ASCII 0-9
        CMP #$3A            ; Greater than 9?
        BCC NOADJ           ; No - it's already a valid digit
        ADC #6              ; Need to add 7 so 10 -> A, 11 -> B, etc
NOADJ   JMP OUCH            ; ... and print it
; Print X1 in hex
PX1     LDX #0
PXX     LDA X1,X
        JSR PBYTE           ; Print a byte
        LDA #$20
        JSR OUCH            ; Print space
        INX
        CPX #4
        BNE PXX             ; For all 4 bytes
RET     RTS
; Load value pointed to by X in table TESTS into X1
LOADX   LDY #0
PT2     LDA TESTS,X
        STA X1,Y
        INX
        INY
        CPY #4
        BNE PT2             ; Copy next 4 bytes from table
        RTS
; Print X1 in hex, then as float
PBOTH   LDA #13
        JSR OUCH
        LDA #10
        JSR OUCH            ; CRLF
        JSR PX1             ; Print X1 in hex
        LDA #':
        JSR OUCH
        LDA #$20
        JSR OUCH
        JMP PFLOAT          ; Print X1 as floating decimal
; The test harness. Located at $0F00 just for ease of running under the UK101 monitor.
        * = $0F00
        LDX #0
NTST    JSR LOADX           ; Load value pointed to by X
        TXA
        PHA                 ; Save X across PBOTH
        JSR PBOTH           ; Print it
        PLA
        TAX                 ; Get X back
        CPX #LASTST         ; Was that the last one?
        BNE NTST            ; If not, do another
        .BYTE $02           ; Special halt operation for UK101 Simulator
barrym95838
Post by barrym95838 »
Welcome! It looks like you're off to a productive start here. I have played around with WOZFLOATs a bit myself, but I never got as far as you seem to have progressed. My plate is full at the moment, but I'm looking forward to checking out your code when time and attitude permit.
gfoot
Post by gfoot »
Nice job. I only had a glance at the code, and spotted one instruction that seems unnecessary (the ASL three lines after NOTNEG), but that's a bit of a silly optimisation - there are probably more significant ones elsewhere!
AndrewW
Post by AndrewW »
Here's that ASL instruction in context:
The ZP location at DIGITS+BSIZ-2 needs initialising with 0. We could just do:LDA #$0 then STA DIGITS+BSIZ-2 (4 bytes), but since we know the accumulator contains $80, ASL then STA DIGITS+BSIZ-2 does the same job and saves one whole byte (gosh).
Andrew
gfoot
Post by gfoot »
The reason I said it's unnecessary is really because of what happens next - it doesn't actually matter whether that memory location gets initialised with $00 or $80, nor the additional side effect of the ASL (setting the carry), as the next 20 lines execute the same either way, and this value in memory then gets overwritten by the line labelled M. I'm pretty sure this sequence will end up with the same result whether the ASL is present or not.
AndrewW
Post by AndrewW »
You're right! Good spot.
The normalised representation of zero generated by NORM is $00, $00, $00, $00, but other numbers may have exponent=0. For instance, Woz's code seems happy to operate on the normalised representation of 2^-128 ($00, $40, $00, $00 = 2.93873587705571876992 ... × 10^-39), which has exponent=0. The previous version of PFLOAT incorrectly assumed that all numbers with exponent=0 are 0; this is easily fixed by removing the first 4 lines. PFLOAT is happy to print denormalised representations of zero (e.g. $FF, $00, $00, $00 prints as decimal 0), even though that causes Woz's routines to deliver erroneous values. For instance, denormalised 0 ($FF, $00, $00, $00) + 3 ($81, $60, $00, $00) incorrectly yields 0 ($FF, $00, $00, $00), but if NORM is called on the denormalised 0 before the addtion, it correctly yields 3 ($81, $60, $00, $00).
However, PFLOAT can't print the decimal representation of -2^128, even though that can be represented ($FF, $80, $00, $00), because in trying to do so it'll try to negate its input, and 2^128 is not representable.
Corrected and optimised PFLOAT with gfoot's optimisation, correct printing of numbers with exponent=0 plus simplifications to the loop management code (and now down to 130 bytes);
OUCH    = $BF2D             ; Print one character in A (UK101 MON01). X & Y must be preserved.
; Print the float in X1 in non-scientific notation.
PFLOAT  LDA M1
        JSR OUCH
        STA DIGITS+BSIZ-3   ; ... and another at the other end
        STA DIGITS+BSIZ-2   ; ... and store that as the initial digit (ROL later turns it into zero)
        LDY X1              ; Load exponent, and add one, since we always shift left at
        INY                 ; least once (MSB into old sign bit)
        ASL M1+2
        LDA DIGITS+BSIZ-2   ; Load A with least significant decimal digit
AGN     ROL                 ; Double the digit, with carry in (carry out ignored)
        BCC M               ; No
        BMI DIG             ; ... until it's $7F or less
        JSR PRB
        LDA #$82
DIG1    LSR M1
        ROR M1+1
        LDX #<[1-BSIZ]      ; Index into buffer in ZP, counting up to zero
        BNE AGN1            ; Always
        STA DIGITS+BSIZ-1,X ; Store it back
        BEQ R1              ; If we're now pointing at last byte in buffer, exit loop
AGN1    LDA DIGITS+BSIZ-1,X ; Load that digit (or sentinel)
        ROL DIGITS+BSIZ-1,X ; Turn old sentinel into a 5
        STA DIGITS+BSIZ,X   ; Store the sentinel in its new location
        CPY #$7F+24         ; Iterate for (24 + number of bits to right of binary point)
