Hey, if anybody wants 8+32 floating point arithmetic for the PDP11,
you're welcome to use it.
I've found that the really nice thing about 5-byte floating point is the ability to also hold an integer over the whole range of values, encoded with the exponent being zero.
In any floating format, a floating zero is an exception, and is usually coded exp=00,man=00,00...., so just extend that and if the exponent is zero, the mantissa is an integer. 5-byte floats allows you to hold a full 32-bit integer as 00,xxxxxxxx. Other sizes, such as 4-byte floats, don't give you enough "space" in the bits.
