a really newbie question...
ehguacho
Post by ehguacho »
just to be sure: in the instruction ASL A (ASL accumulator) the operation is:
1) A = ASL accumulator
...or just
2) ASL accumulator
the result of the ASL operation is stored into the accumulator? or the ASL instruction is just used to set/reset flags?
sorry about my english, i'm from Argentina :S
http://felliniycia.comule.com/
Result is stored in the Accumulator. Some assemblers allow 'ASL' as a legal opcode, some 'ASL A'
ehguacho
Post by ehguacho »
thanks Ed! i suppose it is also valid for "ASL Zero Page" and all the others ASL's... i mean that the result of any kind of ASL is always stored into the accumulator. is that right?
leeeeee
In Memoriam
Post by leeeeee »
The result of an ASL always overwrites the original data.
Lee.
ehguacho
Post by ehguacho »
Lee.
that means that it may ovewrite memory address... thanks Lee!
Only ASL A leaves the result in the accumulator. ASL done to a memory address does not affect the accumulator. If you don't want it to affect the memory address, then first do LDA then ASL A.
There's a ton of great information in the WDC programming manual downloadable at their website at http://www.westerndesigncenter.com/wdc/ ... manual.pdf .
ehguacho
Post by ehguacho »
but it affects the value in the memory address. isn't it? i.e.:
assume $FE is #AA (170 in decimal)
ASL $FE
...after that $FE is #54 (84 in decimal)
Yes, and also affects the N, Z, and C flags the same as ASL A.
ehguacho
Post by ehguacho »
ok thanks! :D
