Does your system have the lsusb command?
If so, could you run this command in each of the jumper positions?
lsusb -v -d 04b4:8613
I want to see if there is any difference in the descriptors.
Dave
gfoot@box:~$ diff nojumper.txt withjumper.txt
2c2
< Bus 001 Device 098: ID 04b4:8613 Cypress Semiconductor Corp. CY7C68013 EZ-USB FX2 USB 2.0 Development Kit
> Bus 001 Device 099: ID 04b4:8613 Cypress Semiconductor Corp. CY7C68013 EZ-USB FX2 USB 2.0 Development Kit
paganini@cutie:~/6502Decoder$ fx2pipe -a -n=4k >capture.bin
Firmware config: 0x12 0xcb 0xe0 0x0d 0x12
IO loop running...
Downloading firmware [builtin]...
Submitting max. 16 URBs to fill pipeline... 1 submitted
IO loop exited
fx2pipe: 4096 bytes in 0.000s)
paganini@cutie:~/6502Decoder$ hd capture.bin
00000000 ea ea ea ea ea ea ea ea ea ea ea ea ea ea ea ea |................|
00000030 ea ea ea ea ea bd ea bd ea bd ea bd ea bd ea bd |................|
00000040 ea bd ea bd ea bd ea bd ea bd ea bd ea bd ea bd |................|
00000800 ea ff ea fd ea ff ea fd ea ff ea fd ea ff ea fd |................|
00001000
paganini@cutie:~/6502Decoder$ ./decode6502 -c 65c02 -ahisy --rdy= --phi2= capture.bin
opcode ea: cycle prediction fail: expected 7 actual 1
EAEA : : INTERRUPT !! : 1 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAEA : : INTERRUPT !! : 1 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0 prediction failed
(I deleted a lot of these)
opcode ea: cycle prediction fail: expected 2 actual 1
EAEA : EA : NOP : 1 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAEB : EA : NOP : 1 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAEC : EA : NOP : 1 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAED : EA : NOP : 1 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
Instruction after rst /= 7 cycles
EAEE : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAEF : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAF0 : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAF1 : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAF2 : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAF3 : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAF4 : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0
EAF5 : EA : NOP : 2 : A=?? X=?? Y=?? SP=?? N=1 V=1 D=0 I=1 Z=1 C=0Code: Select all
paganini@cutie:~/6502Decoder$ fx2pipe -a -n=4k >capture.binCode: Select all
paganini@cutie:~$ sigrok-cli -d fx2lafw --config samplerate=24MHz -O binary --samples 4k >sigrok.binCode: Select all
gfoot@box:~/logicanalyzer/6502Decoder/fx2pipe$ xxd -g1 data25e.bin | head -2
00000000: 23 23 04 f0 04 26 23 c0 ff a2 ff 9a a9 a9 0c 8d ##...&#.........
00000010: 60 ff 0c a9 00 85 00 00 a9 80 85 01 80 a9 00 85 `...............
gfoot@box:~/logicanalyzer/6502Decoder/fx2pipe$ cat data25e.bin | ../decode6502 -haisy -d 1 -b --vecrst=A2FFC0 --cpu=65C02 --mem=FFF | head -10
0 0 0 23 ? ? ?
1 1 1 23 ? ? ?
2 2 2 04 ? ? ?
3 3 3 f0 ? ? ?
4 4 4 04 ? ? ?
5 5 5 26 ? ? ?
6 6 6 23 ? ? ?
7 7 7 c0 ? ? ?
8 8 8 ff ? ? ?
???? : : RESET !! : 9 : A=?? X=?? Y=?? SP=?? N=? V=? D=0 I=1 Z=? C=?
gfoot@box:~/logicanalyzer/6502Decoder/fx2pipe$ cat data25e.bin | ../decode6502 -haisy -d 1 -b --vecrst=A2FFC0 --cpu=65C02 --mem=FFF --skip=10 | head -10
0 0 0 23 ? ? ?
1 1 1 23 ? ? ?
2 2 2 04 ? ? ?
3 3 3 f0 ? ? ?
4 4 4 04 ? ? ?
5 5 5 26 ? ? ?
6 6 6 23 ? ? ?
7 7 7 c0 ? ? ?
8 8 8 ff ? ? ?
