It begins! (Wren Prototype build log)
Re: It begins! (Wren Prototype build log)
That's great, it's always good when things work in the end!
I'd suggest also running a full RAM test, to check you can write and read all RAM locations without corrupting others. You could also consider running the Dormann test site, which I only started using recently, but which has already caught a few failures in my systems.
allisonlastname wrote:
IT'S ALIVE!
- allisonlastname
Strange issue: the RAM doesn't seem to be accepting write cycles. I've checked the connections and they're all correct, so I have no idea what could be going wrong.
probably the youngest person on this forum
No True Scotsman
Is it still the same circuit as posted here?
Here's the current version that I have on the breadboard.
- allisonlastname
EDIT: Are you using decoupling capacitors? I don't see any on your schematic nor on the breadboard. To quote BDD:
Each device should be paired with a bypass (aka decoupling) capacitor. Time and time again, we have seen unstable or DOA designs that were victims of nothing more than inadequate or non-existing bypassing. Typical practice places a 0.1µF ceramic (MLCC) capacitor so it is as physically close to the device's VCC pin as possible. Capacitor connections should be as short and direct as possible. I use 50 volt, X7R capacitors in my builds. Bypass capacitors are cheap, don't be shy about using them.
and3rson wrote:
Just wondering - is there a reason why you're pulling /RST high? DS1813 should work just fine without it.
The pullup inside the DS1813 is weak. An external pullup makes the circuit a lot less noise-sensitive.
/Andrew
- allisonlastname
and3rson wrote:
The schematic seems to have no issues to me. Maybe double-check NAND wiring (U5A & U5D)? Do you have a logic analyzer? If so - you could check if RAM's /CS & /WE are properly asserted during RAM write cycles.
When you checked the wiring, did you look at VCC and GND too? If you happen to be using those little jumpers shaped like staples it's really easy to get them off by one row and accidentally leave (e.g.) your RAM's power pin floating. This sort of thing can be frustratingly pernicious, and can be pretty tough to spot (at least by my middle-aged vision) without a magnifier of some type.
- allisonlastname
There's 4.98V between Vcc and ground on the RAM chip, which is well within limits according to the datasheet.
- allisonlastname
Ok, I've tested the RAM chip by false-feeding it on a separate breadboard, and no matter what I do I can't make it accept writes properly. I also tested a few others I got in the same order, and all of those exhibited the same behaviour. I find it hard to believe that all of them were dead on arrival, but it seems to be the only explanation.
- GARTHWILSON
- Forum Moderator
- allisonlastname
I got them from Mouser. And yeah, it probably is a stupid error, but I can't think what. I've triple-checked all the pins and run it with false-fed signals and it still doesn't work.
Not sure what your flash programmer looks like but you might use that with minor hardware/software modifications to test your RAM chips...
- GARTHWILSON
- Forum Moderator
I agree with Garth. You might find some new insight after setting the problem aside for a while. (Also, do the reads and writes achieve the appropriate levels noted for reads and writes in the data sheet's Truth Table? Just checking!)
