Dark mode for forum.6502.org
I'm using Dark Reader extension for most websites, it works really well but it's not always good with the images.
So I made a dark mode user style (CSS only) for myself and decided to share it in case some of y'all like their screens dark as much as I do: https://userstyles.world/style/11705/da ... m-6502-org
I'm using it with Stylish extension on my Firefox, but there are plenty of others (including other browsers) since the user style format is an open standard.
It will probably work well with other PHPBB2-based forums - you'll just need to update it with the domains to apply it for.
Let me know if you find any forum sections that I forgot to cover.
Images are by Jodi-86 (https://www.phpbb.com/customise/db/styl ... ver_based/) and are licensed under GNU GPL v2, and so is my user style.
/Andrew
Re: Dark mode for forum.6502.org
damn that looks really good. i wish a dark mode was a native feature on these forums.
though you'll run into issues when it comes to custom text colors as some forum members always set their text to be black (even though it's already almost black), which would then be difficult to read.
one option would be to have a white outline around text with dark colors.
another option would be to simply render all text in white regardless of the custom color it was assigned.
or you could do nothing as the site doesn't add outlines to very bright colors either. (though i feel like it should as otherwise those colors are kinda useless) (yes there is text here)
either way i'll see if i can get that working
Yeah - I stumbled upon some of Garth's posts and ended up forcing all text color inside messages to white.
But I like your idea with borders/shadows: it might worth a try.
I also fixed borders in some of forum icons - the default ones had ugly white edges when on dark background.
/Andrew
- GARTHWILSON
- Forum Moderator
I use the ProSilver mode, whereas I think many members are using the tan one instead. I and at least two others started turning all our posts black, color code 000000, because this ridiculous modern idea of "softening" the text by making it gray dramatically reduces my reading speed and comprehension, both. The argument for this "softening" is that the contrast on the screen is higher than that of black ink on white paper; but no, I never have the problem with ink & paper, only "softened" font on the screen. In extreme cases, they make it so I can sort of tell there's text there but I can't read it without getting up out of my chair and leaning way forward to get really close to my monitor which is behind my keyboard, landline phone, and other stuff.
Garth, is the theme configurable somewhere? I couldn't find such option in my profile.
/Andrew
- GARTHWILSON
- Forum Moderator
I feel like the original purpose of CSS has got kind of lost along the way. It's meant to be there to allow users to choose how things look, not really to allow publishers to enforce it. It's nice to see that some browsers (or at least extensions?) do allow users to specify their own custom stylesheets so that they can see everything in colours and styles that suit them, I will give it a go, at least as a base to customize for myself, thanks!
hmm the theme only seems to be half-functional for me, the text color and the icons are different but the actual background colors are the same white/gray/blue as before.
i am on firefox with "toolkit.legacyUserProfileCustomizations.stylesheets" enabled.
Personal hate: a coloured pencil brigade designer who decides pale gray on slightly paler gray is in interesting and readable aesthetic, but can't be bothered to control the width of a column by the average number of words in it...
I'm quite a fan of the fact that forum.6502.org still supports Netscape Navigator.
...but a dark mode would be nice
+1 for dark mode.
I find that light mode screens are getting harder and harder for me to read. Not to mention they show every little speck or streak on my glasses and since I cannot for the life of me keep my glasses clean, I prefer dark mode on everything.
Oh, I like that. Just added the extension and the custom style; looks great!
Is there a way to get this style in/on Chrome on my Windows PC?
Thank you very much...
