Now, if we were able to do a nibble swap in 2 or 3 cycles, it would have been a different matter.
Random-number generation
Re: Random-number generation
I have a huge choice of 12 cycle sequences, and it's not very likely that this (admittedly clever) sequence is optimal for the purpose of mixing bits randomly.
- BigDumbDinosaur
barrym95838 wrote:
Arlet wrote:
Unfortunately, doing a nibble swap on 6502 is quite expensive, and probably not really worth it.
Eight bytes and 12 cycles, so not terrible. Depends on your definition of "expensive", I suppose.
I don’t see an issue with the apparent “expense” of the linked nybble swap. If performance truly is a concern, then it’s time to crank up the clock speed or use the 65C816 and rewrite the code to do byte-swaps in a word for a potentially better effect on quality. The 816’s XBA instruction only takes three cycles.
A 12 cycle nibble swap being "too expensive" is not absolute. It simply means that the same goal (good quality randomness) can be better achieved with a different sequence of instructions that take fewer than 12 cycles. Performance is not a concern. There are no requirements. It's simply a fun challenge to produce a certain result in minimum number of cycles, that may be useful to some people. Part of the challenge is to work within the limitations of the chosen target.
2 clc
2 lda #$45
4 adc s+0
4 sta s+0
4 adc s+1
4 sta s+1
4 adc s+2
4 sta s+2
4 adc s+3
4 sta s+3
4 adc s+4
4 sta s+4
4 adc s+5
4 sta s+5
4 adc s+3
4 sta o+0
4 adc s+6
2 asl a
4 sta s+6
4 adc s+2
4 sta o+1
4 adc s+6
2 asl a
4 sta s+6
4 adc s+4
4 sta o+2
4 adc s+5
4 sta o+3
104
Here is my 1995 PRNG code :
call Init: one time
each time you want a random byte, call begin:
the random byte is in rndbyte.
The period before repetition is factorial 256 : !(256)
call Init: one time
// Random Generator 1995
// Main Program
init:
ldx #0
stx storex
stx storey
loop:
lda array1,x
sta array,x
inx
bne loop
rts
begin:
ldx storex
inx
lda array,x
pha
clc
adc storey
sta storey
ldy storey
lda array,y
sta array,x
pla
sta array,y
clc
adc array,x
stx storex
tax
lda array,x
sta rndbyte
rts
storex: .byte $00
storey: .byte $00
rndbyte: .byte $00
array: .byte 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
array1: .byte 85,40,23,156,235,170,177,134,56,192,69,86,100,230,141,164,109,218,155,97,144,132,117,130,37,153,6,0,129,43,175,187,53,16,71,160,244,173,202,176,229,34,105,92,248,77,14,119,126,242,169,17,213,158,201,165,101,57,46,78,231,253,13,237,120,111,221,58,54,197,210,133,114,42,110,118,48,50,240,36,123,190,74,139,25,135,196,191,59,84,89,255,226,161,62,205,146,232,172,157,182,224,24,72,20,174,168,95,102,15,140,233,211,108,239,44,219,107,112,149,125,9,220,186,223,147,96,238,104,33,3,193,116,18,208,38,52,41,188,87,70,8,7,83,142,27,79,121,179,152,166,145,93,189,99,67,234,136,198,90,216,51,63,251,206,98,209,204,73,200,91,115,183,5,138,181,131,167,113,254,31,243,246,150,137,76,203,4,245,49,11,21,252,94,39,128,212,80,60,30,1,236,28,103,185,66,214,82,64,61,12,249,55,47,215,2,22,75,81,29,171,154,250,68,178,127,32,162,222,159,35,19,26,227,199,225,184,45,195,10,148,106,88,194,217,207,180,163,151,124,228,143,241,247,122,65
The main part is only 65 cycles. Did I win the fun challenge?
ldx storex -- 4 cycles
inx -- 2 cycles
lda array,x -- 5 cycles
pha -- 3 cycles
clc -- 2 cycles
adc storey -- 4 cycles
sta storey -- 4 cycles
ldy storey -- 4 cycles
lda array,y -- 5 cycles
sta array,x -- 5 cycles
pla -- 4 cycles
sta array,y -- 5 cycles
clc -- 2 cycles
adc array,x -- 5 cycles
stx storex -- 4 cycles
tax -- 2 cycles
65 cycles
The atarisim code is :
It can be compiled with :
and can be run with :
cl65 -tatari -Catari-asm.cfg 1995prng.asm
./atarisim 1995prng | xxd -r -p | rng_test stdin8
.export start
ICPTL = $0346
ICPTH = $0347
.zeropage
zp_start:
cnt: .res 6
zp_end:
.code
.proc init
init:
ldx #0
stx storex
stx storey
loop:
lda array1,x
sta array,x
inx
bne loop
rts
.endproc
.proc begin
ldx storex
inx
lda array,x
pha
clc
adc storey
sta storey
ldy storey
lda array,y
sta array,x
pla
sta array,y
clc
adc array,x
stx storex
tax
lda array,x
sta rndbyte
rts
.endproc
storex: .byte $00
storey: .byte $00
rndbyte: .byte $00
.proc print_hex_byte
pha
lsr
lsr
lsr
lsr
jsr print_hex
pla
print_hex:
and #$0F
tax
lda hextab,x
; Fall through
::putc:
ldx #0
jump: jmp $FFFF
hextab: .byte "0123456789ABCDEF"
.endproc
start:
; Init fast putchar
jsr init
lda ICPTL
clc
adc #1
sta print_hex_byte::jump+1
lda ICPTH
adc #0
sta print_hex_byte::jump+2
; Clear state
ldx #zp_end-zp_start-1
lda #0
zpclr:
sta zp_start, x
dex
bpl zpclr
; Generate and print numbers
loop:
jsr begin
lda rndbyte
jsr print_hex_byte
; lda #$9B
; jsr putc
inc cnt
bne loop
inc cnt+1
bne loop
inc cnt+2
bne loop
inc cnt+3
bne loop
inc cnt+4
bne loop
inc cnt+5
bne loop
rts
teamtempest
init:
ldx #0
ldy #0
stx storex
stx storey
rts
begin:
ldx storex
inx
lda array,x
pha
clc
adc storey
sta storey
ldy storey
lda array,y
sta array,x
pla
sta array,y
clc
adc array,x
stx storex
tax
lda array,x
sta rndbyte
rts
storex: .byte $00
storey: .byte $00
rndbyte: .byte $00If 'storex' and 'storey' were arbitrary uninitialized RAM locations, then yes, an 'init' of some sort would be necessary. But even then you could call 'init' once (taking care to actually store the Y-register if a non-zero seed is used) and fall through to 'begin', and that would be your first iteration. After that always call 'begin', just like now.
teamtempest wrote:
I'm curious why you need the 'init' procedure at all. The values in 'storex' and 'storey' are fixed at assembly time, and the values do not change thereafter. You apparently do nothing with the return value from 'init' (which only loads the Y-register and then does nothing with it. Is that intentional?).
All my old 6502 codes are on paper and I have to type them again on the computer to revive them. I made a copying error. The paper code was :
ldx #0
ldy #0
stx storex
sty storeyCode: Select all
ldx #0
stx storex
stx storeyIn addition I no longer have the assembler I was using when the code was written. I need to modify the code to work with my current assembler. For example, it does not accept this:
storex: .res 1
storey: .res 1Re: Random-number generation
By the way, if I'm not mistaken, then this is an implementation of RC4
Alex1 wrote:
If I want to go back to the beginning and get the same random byte string, just make a call to init:. Without this initialization function, once the algorithm is launched, I can't start over at the beginning.
For a real apples-to-apples comparison, we would have to define some categories regarding output quality (and how to test that), memory footprint, as well as the number of output bits.
If I did not make a mistake (which is always possible) I am ahead of you in the challenge because your algorithm does not meet the characteristics:
You said that your last algorithm produces 2^48 bytes before looping, that's not what Practrand says.
Nice 32 bit random generator, with 7 bytes of state, and 4 bytes of output. Period is guaranteed to be at least 2^48 words, so for all practical purposes will never repeat.
Here is my code, here are the results with only the o+3 output:
.export start
ICPTL = $0346
ICPTH = $0347
.zeropage
zp_start:
;state: .res 8
cnt: .res 6
zp_end:
.code
.proc rand
CLC
LDA #$45
ADC s+0
STA s+0
ADC s+1
STA s+1
ADC s+2
STA s+2
ADC s+3
STA s+3
ADC s+4
STA s+4
ADC s+5
STA s+5
ADC s+3
STA o+0
ADC s+6
ASL A
STA s+6
ADC s+2
STA o+1
ADC s+6
ASL A
STA s+6
ADC s+4
STA o+2
ADC s+5
STA o+3
RTS
.endproc
s: .byte $FF,$FF,$FF,$FF,$FF,$FF, $FF
o: .byte $00,$00,$00,$00
pha
lsr
lsr
lsr
lsr
jsr print_hex
pla
print_hex:
and #$0F
tax
lda hextab,x
; Fall through
::putc:
ldx #0
jump: jmp $FFFF
.endproc
start:
; Init fast putchar
lda ICPTL
clc
adc #1
lda ICPTH
adc #0
; Clear state
lda #0
zpclr:
sta zp_start, x
dex
bpl zpclr
loop:
jsr rand
; lda o+0
; jsr print_hex_byte
; lda o+1
; lda o+2
jsr print_hex_byte
lda o+3
jsr print_hex_byte
inc cnt
bne loop
inc cnt+1
bne loop
inc cnt+2
bne loop
inc cnt+3
bne loop
inc cnt+4
bne loop
inc cnt+5
bne loop
rts
./atarisim arlet-new | xxd -r -p | ./rng_test stdin8
RNG_test using PractRand version 0.94
RNG = RNG_stdin8, seed = unknown
test set = core, folding = standard (8 bit)
rng=RNG_stdin8, seed=unknown
length= 2 megabytes (2^21 bytes), time= 3.6 seconds
no anomalies in 63 test result(s)
length= 4 megabytes (2^22 bytes), time= 7.8 seconds
no anomalies in 71 test result(s)
length= 8 megabytes (2^23 bytes), time= 15.9 seconds
no anomalies in 76 test result(s)
length= 16 megabytes (2^24 bytes), time= 31.7 seconds
no anomalies in 84 test result(s)
length= 32 megabytes (2^25 bytes), time= 61.5 seconds
no anomalies in 93 test result(s)
length= 64 megabytes (2^26 bytes), time= 121 seconds
no anomalies in 99 test result(s)
length= 128 megabytes (2^27 bytes), time= 239 seconds
no anomalies in 108 test result(s)
length= 256 megabytes (2^28 bytes), time= 474 seconds
no anomalies in 118 test result(s)
length= 512 megabytes (2^29 bytes), time= 943 seconds
no anomalies in 126 test result(s)
length= 1 gigabyte (2^30 bytes), time= 1874 seconds
no anomalies in 135 test result(s)
length= 2 gigabytes (2^31 bytes), time= 3744 seconds
Test Name Raw Processed Evaluation
TMFn(2+6):wl R= +21.8 p~= 1e-6 mildly suspicious
...and 143 test result(s) without anomalies
length= 4 gigabytes (2^32 bytes), time= 7461 seconds
TMFn(2+5):wl R= +35.9 p~= 1e-14 FAIL
TMFn(2+6):wl R= +48.5 p~= 4e-22 FAIL !!
TMFn(2+7):wl R= +18.4 p~= 3e-5 unusual
...and 148 test result(s) without anomalies
loop:
jsr rand
lda o+0
jsr print_hex_byte
lda o+1
jsr print_hex_byte
lda o+2
jsr print_hex_byte
lda o+3
jsr print_hex_byte
length= 2 megabytes (2^21 bytes), time= 2.1 seconds
length= 4 megabytes (2^22 bytes), time= 4.9 seconds
length= 8 megabytes (2^23 bytes), time= 9.8 seconds
length= 16 megabytes (2^24 bytes), time= 19.3 seconds
length= 32 megabytes (2^25 bytes), time= 36.3 seconds
TMFn(2+0):wl R= +69.0 p~= 1e-34 FAIL !!!
...and 92 test result(s) without anomalies
Alex1 wrote:
You said that your last algorithm produces 2^48 bytes before looping, that's not what Practrand says. Here is my code, here are the results with only the o+3 output
ARC4 is a good random generator, but for average 6502 systems, the 256 byte RAM array is relatively expensive.
I will accept the challenge though, but then I'm also going to use a 256 byte RAM, and 8 bit output. What kind of performance are we looking for ? I don't mind trying for 32TB passing on PractRand, but it will take a really long time to run such tests. I don't really want to hog my PC for 3 months testing various algorithms. Will you accept 1TB, and plain "stdin8" ?
Arlet wrote:
It's not looping, though. It fails random tests before looping. Imagine you have a simple 64 bit counter, it wouldn't be random, but it would still produce 2^64 unique outputs before looping.
When I announce a period for my algorithms, they remain random throughout the period. You have to do the same otherwise it's cheating for the challenge
length= 16 terabytes (2^44 bytes), time= 6061817 seconds
no anomalies in 225 test result(s)
