Random-number generation
- barrym95838
Re: Random-number generation
Arlet wrote:
It's possible to optimize in various directions. Using more/less ZP, code size, cycles, or period/quality. Let me know what you care about most.
If code space is at a premium, you might use the 8 bit version of my code, and call the routine twice to obtain 16 bits. While strictly not guaranteeing that every possible value will be visited, the fact that it passes good randomness tests into the gigabytes means that in practice it must have equal chance for each value. Keep in mind that it is possible that certain 16 bit values will occur multiple times while other values are not yet seen.
If you need 16 bits output where each value occurs exactly once per 64k calls, let me know. I can make that too, but it will require a different approach.
Improved code, now 77 cycles and 5 state bytes, and passes 8GB random test. Output is stored in o+0 and o+1
working example
CLC
LDA #$45
ADC s+0
STA s+0
ADC s+1
STA s+1
ADC s+2
STA s+2
ADC s+3
STA s+3
LDA s+4
ROL A
ROL A
STA s+4
ADC s+2
STA o+0
ADC s+4
STA s+4
ADC s+3
STA o+1
ADC s+1
ADC s+4
STA s+4
ADC o+0
STA o+0
ADC s+4
STA s+4
RTS
More improved code, now 71 cycles and 5 state bytes, and passes 4GB random test. Output is stored in o+0 and o+1. I've also added this code to my github repository.
Note that the last STA o+0 and STA o+1 are optional. You can modify the program to store the two output bytes somewhere else. For instance, you could return the 16 bit value in X,A pair by replacing the STA o+0 with TAX and removing the STA o+1.
owlet link
CLC
LDA #$45
ADC s+0
STA s+0
ADC s+1
STA s+1
ADC s+2
STA s+2
ADC s+3
STA s+3
LDA s+4
ROL A
STA s+4
ADC s+2
STA o+0
ADC s+3
STA o+1
ADC s+1
ROL A
ADC o+0
STA o+0
ADC s+4
STA s+4
ADC o+1
STA o+1
RTS
owlet link
- barrym95838
LDA s+4
ROL A
STA s+4Code: Select all
ROL s+4
LDA s+4Got a kilobyte lying fallow in your 65xx's memory map? Sprinkle some VTL02C on it and see how it grows on you!
I've only tested this with $45 constant at the beginning. It will still work with other odd constants, but quality of random output may vary a bit. For instance with constant 1, it still passes 1GB of output. If you happen to have an even constant in A, you can replace the CLC by SEC.
If you just wanted something super simple that produces every single 16 bit value exactly once, in random order, you could use something like this. 16 bit output in A,X:
Good enough for games where you need a random action for a monster, but it's not going to pass any randomness tests. It's very easy to generate these kinds of random generators. You start with some code that iterates through every single 16 bit number, which is the part between CLC .. STA s+1. You then have two bytes in s+0 and s+1, which have a bit of randomness, but not too good. You then mix these bytes together to improve quality. If you mix with any bijective (invertible) function, then you guarantee that every 16 bit value still occurs exactly once. If you have two bytes A and B, you can create bijective functions by taking any arbitrary function f(), apply it to A, and then apply that to B in an invertible way, for instance with ADC or EOR. So, A = A + f(B), or B = B ^ g(A). Just be careful that you don't add unknown carry flag. You can also use any invertible operation on A or B by itself, such as a bit rotate. These bijective mixers can be stacked.
CLC
LDA #1 ; any odd value
ADC s+0
STA s+0
ADC s+1
STA s+1
ASL A
ADC s+0
TAX
EOR s+0
RTS
- barrym95838
CLC
ADC s+0
STA s+0
ADC s+1
STA s+1
ASL A
ADC s+0
TAX
EOR s+0
RTS
The "exactly once" comes naturally if you want tiny code and ZP footprint, but don't want a bunch of missing/duplicate values.
a few other random generators :
batari8 (0)
Type: galois8 lfsr
6502 author: Fred Quimby
RAM: 1 byte
Cycles: 11-12
Period: 255
References: https://github.com/batari-Basic
Notes: This is the rand routine included with the 2600 development
language batari Basic. It's main strength is it's compactness
and speed.
Sample: (2a) 15 be 5f 9b f9 c8 64 32 ...
LDA randv0
LSR
BCC noeor
EOR #$B4
noeor:
STA randv0
batari8rev (1)
Type: galois8 lfsr
6502 author: (forward) Fred Quimby, (reversal) Mike Saarna
RAM: 1 byte
Cycles: 11-12
Period: 255
Notes: This is a reversed version of the LFSR included with batari
Basic. Reversal allows the pseudorandom sequence to be
rewound at any point, without requiring additional storage.
Sample: (32) 64 c8 f9 9b 5f be 15 2a ...
LDA randv0
ASL
BCC noeor
EOR #$69
noeor:
STA randv0
batari16 (2)
Type: galois8 extended to 16 bits
RAM: 2 bytes
Cycles: 19-20
Period: 65535
Notes: This is the rand16 routine included with the 2600 development
language batari Basic, and the default rand routine in
7800basic. Its quick and compact for a 16-bit LFSR.
Sample: (2a2a) 41 a3 e3 fd d2 d8 ba 19 ...
LDA randv0
LSR
ROL randv1
BCC noeor
EOR #$B4
noeor:
STA randv0
EOR randv1
batari16rev (3)
6502 author: (forward) Fred Quimby, (reversal) bogax
RAM: 2 bytes
Cycles: 22-23
Period: 65535
7800basic, run backwards
Sample: (a124) 19 ba d8 d2 fd e3 a3 41 ...
LDA randv1
LSR
LDA randv0
ROL
BCC skip_eor16
EOR #$68
skip_eor16:
STA randv0
ROR randv1
EOR randv1
pitfall8left (4)
Type: fibonacci8 lfsr
6502 author: David Crane
RAM: 1 byte
Cycles: 30
Period: 255
References: https://samiam.org/blog/20130606.html
Notes: This is the left-travelling LFSR from the Atari 2600
game Pitfall. It's at the core of the game's algorithmic
level generation.
Sample: (2a) 95 4a a5 52 29 14 8a 45 ...
LDA randv0
ASL
EOR randv0
ASL
EOR randv0
ASL
ASL
ROL
EOR randv0
LSR
ROR randv0
LDA randv0
pitfall8right (5)
RAM: 1 byte
Cycles: 30
Period: 255
Notes: This is the right-travelling LFSR from the Atari 2600
level generation.
Sample: (45) 8a 14 29 52 a5 4a 95 2a ...
LDA randv0
ASL
EOR randv0
ASL
EOR randv0
ASL
ASL
EOR randv0
ASL
ROL randv0
LDA randv0
xorshift16 (6)
Type: xorshift16 lfsr
6502 author: Veikko
RAM: 2 bytes
Cycles: 30
Period: 65535
References: http://www.retroprogramming.com/2017/07/xorshift-pseudorandom-numbers-in-z80.html
Notes: This is an efficient 6502 implementation of the xorshift16
algorithm.
Sample: (2a2a) 0a ad 77 8b 50 37 06 75 ...
LDA randv1
LSR
LDA randv0
ROR
EOR randv1
STA randv1
ROR
EOR randv0
STA randv0
EOR randv1
STA randv1
xhybrid24 (7)
Type: hybrid xorshift16+galois8
6502 author: (hybrid code) Mike Saarna, (base xorshift16) Veikko
RAM: 3 bytes
Cycles: 48-50
Period: 16711425
References:
Notes: A bit sampling on the xorshift16 upper-byte cranks a galois8
lfsr forward. This results in an atypical lfsr period.
xhybrid24 passes and scores well on most "dieharder"
randomness quality checks. This level of rand quality probably
isn't needed on 6502 based systems, but it's nice that it can
be done with relative efficiency.
Sample: (010101) f4 c5 d0 ae 75 6b 70 d2 ...
BIT randv1
BVS skipupperlfsr
LDA randv2
LSR
BCC skipuppereor
EOR #$B4
skipuppereor:
STA randv2
skipupperlfsr:
LDA randv1
LSR
LDA randv0
ROR
EOR randv1
STA randv1
ROR
EOR randv0
STA randv0
EOR randv1
STA randv1
EOR randv2
overlap24 (8)
Type: ??
6502 author: ??
RAM: 3 bytes
Cycles: 73
Period: 16777215
References: https://wiki.nesdev.com/w/index.php/Random_number_generator/Linear_feedback_shift_register_(advanced)
Notes: Has an XOR-feedback that contains only four bits, but by
shifting and feeding back 8 bits at once, a more complex
overlapped result is obtained.
Sample: (010203) 1b 36 2d 45 8a d4 81 43 ...
LDY randv1
LDA randv2
LSR
LSR
LSR
LSR
STA randv1
LSR
LSR
EOR randv1
LSR
EOR randv1
EOR randv0
STA randv1
LDA randv2
ASL
EOR randv2
ASL
ASL
EOR randv2
ASL
EOR randv2
STY randv2
STA randv0
riverraid16 (9)
Type: ??
6502 author: Carol Shaw
RAM: 2 bytes
Cycles: 27
Period: 57337
References: http://www.bjars.com/source/RiverRaid.asm
Notes: "randomHi is very random, randomLo is NOT when more than one
bit is used, because: randomLo[x+1] = randomLo[x]*2 + 0/1, but
randomLo is used more often [in the game] [...]"
--Thomas Jentzsch
Sample: (a814) 0a 05 b6 5b 99 f8 7c 3e ...
LDA randv1
ASL
ASL
ASL
EOR randv1
ASL
ROL randv0
ROL randv1
LDA randv1- barrym95838
Very nice little collection there, Alex1. Thank you!
Nice 32 bit random generator, with 7 bytes of state, and 4 bytes of output. Period is guaranteed to be at least 2^48 words, so for all practical purposes will never repeat. The four output bytes are written only once, and not read back, so you can modify the code to put them somewhere else instead of in the RAM array. Note that the random quality is on the low side, but at 20 cycles/byte, it is quite fast. It is possible to shorten the 6-stage ADC/STA sequence at the beginning to reduce footprint, code size, and cycle time, at the cost of lowering the random quality even more.
(I'm playing around with PRNG for Arduino, and it has a very nice SWAP instruction that swaps the high and low nibble of a register. It's very effective in combination with ADC chains to create good randomness. Unfortunately, doing a nibble swap on 6502 is quite expensive, and probably not really worth it)
owlet code
CLC
LDA #$45
ADC s+0
STA s+0
ADC s+1
STA s+1
ADC s+2
STA s+2
ADC s+3
STA s+3
ADC s+4
STA s+4
ADC s+5
STA s+5
ADC s+3
STA o+0 ; first output byte
ADC s+6
ASL A
STA s+6
ADC s+2
STA o+1 ; second output byte
ADC s+6
ASL A
STA s+6
ADC s+4
STA o+2 ; third output byte
ADC s+5
STA o+3 ; fourth output byte
RTS
By the way my LFSR64+LCG64 still good after 16TB data...
RNG_test using PractRand version 0.94
RNG = RNG_stdin8, seed = unknown
test set = core, folding = standard (8 bit)
rng=RNG_stdin8, seed=unknown
length= 8 megabytes (2^23 bytes), time= 2.9 seconds
no anomalies in 76 test result(s)
length= 16 megabytes (2^24 bytes), time= 6.5 seconds
no anomalies in 84 test result(s)
length= 32 megabytes (2^25 bytes), time= 12.9 seconds
no anomalies in 93 test result(s)
length= 64 megabytes (2^26 bytes), time= 24.8 seconds
no anomalies in 99 test result(s)
length= 128 megabytes (2^27 bytes), time= 47.7 seconds
no anomalies in 108 test result(s)
length= 256 megabytes (2^28 bytes), time= 92.1 seconds
no anomalies in 118 test result(s)
length= 512 megabytes (2^29 bytes), time= 180 seconds
no anomalies in 126 test result(s)
length= 1 gigabyte (2^30 bytes), time= 355 seconds
no anomalies in 135 test result(s)
length= 2 gigabytes (2^31 bytes), time= 706 seconds
no anomalies in 144 test result(s)
length= 4 gigabytes (2^32 bytes), time= 1406 seconds
no anomalies in 151 test result(s)
length= 8 gigabytes (2^33 bytes), time= 2821 seconds
no anomalies in 159 test result(s)
length= 16 gigabytes (2^34 bytes), time= 5661 seconds
no anomalies in 167 test result(s)
length= 32 gigabytes (2^35 bytes), time= 11312 seconds
no anomalies in 173 test result(s)
length= 64 gigabytes (2^36 bytes), time= 22845 seconds
no anomalies in 181 test result(s)
length= 128 gigabytes (2^37 bytes), time= 45338 seconds
no anomalies in 189 test result(s)
length= 256 gigabytes (2^38 bytes), time= 91090 seconds
no anomalies in 195 test result(s)
length= 512 gigabytes (2^39 bytes), time= 186524 seconds
no anomalies in 202 test result(s)
length= 1 terabyte (2^40 bytes), time= 366013 seconds
no anomalies in 208 test result(s)
length= 2 terabytes (2^41 bytes), time= 729582 seconds
no anomalies in 213 test result(s)
length= 4 terabytes (2^42 bytes), time= 1470769 seconds
no anomalies in 218 test result(s)
length= 8 terabytes (2^43 bytes), time= 2981457 seconds
no anomalies in 222 test result(s)
length= 16 terabytes (2^44 bytes), time= 6061817 seconds
no anomalies in 225 test result(s)- barrym95838
Arlet wrote:
Unfortunately, doing a nibble swap on 6502 is quite expensive, and probably not really worth it.
Eight bytes and 12 cycles, so not terrible. Depends on your definition of "expensive", I suppose.
