It is currently Tue Jun 04, 2024 1:11 pm
 Post subject: Odd Kim-1 memory issue
PostPosted: Tue May 23, 2023 6:56 am
I've just started using a Kim-1 that belonged to my brother and which hasn't been powered on for a very long time, possibly decades. It seems to take a minute or so and multiple resets to settle down, but then allows me to use the monitor as expected.
I ran into problems when trying to load the first addition program from the manual. Opcodes at certain memory addresses were being corrupted, but in a consistent and reproducible way.
I did some testing loading 0, 1, 2, 4, 8, 16, 32 into the first 16 locations in memory, and discovered this:
If I load 00 into the first 16 memory locations, then load 08 into location 0000, location 0008 becomes 08. If I load 08 into location 0001, location 0009 becomes 08. Trying this with other values suggests loading any value with an 8 in it (binary 1000) adds 8 to the value held in memory location 8 places later.
Does anyone have any ideas what might be causing this? Could it be something as simple as a short between an address and a data line somewhere? (I have a multimeter but no oscilloscope for fault finding).
Grateful for any advice!
PostPosted: Tue May 23, 2023 8:58 am
As the ROM addressing is working - otherwise the user interface almost certainly wouldn't work - perhaps most likely A4 is open and has floated high, at the RAM end. A cracked trace or dry joint could cause that. Even possible that the RAM chip has failed.
I'd suggest starting by checking continuity of A4 and for confidence also A3 and A5. Check that all the pins which should be connected are connected, and while you're walking around the pins, check that in all cases adjacent pins are not connected.
PostPosted: Tue May 23, 2023 12:34 pm
Ah... <sigh> I have fond memories of the KIM-1. Uh, no pun intended :oops:
I agree the problem involves memory circuitry, but I'd worry about the A3 signal, not A4. Perhaps Ed's brain got struck by an alpha particle! Or perhaps mine did.
The KIM-1 uses 1kx1 RAM chips, meaning there's a separate chip for each bit. It's plausible that a single chip has failed. Stand by while I check the manual for more details.
PostPosted: Tue May 23, 2023 12:56 pm
Thank you both! So, do I understand correctly that each byte has its bits stored across all 8 RAM chips?
PostPosted: Tue May 23, 2023 1:23 pm
Yes, that's right. This is shown in Figure 3.4 on page 27 of the user manual.
The error you described is affecting the data in bit3 of the bytes, and bit3 is managed by memory IC U-9. Apparently U-9 is failing to heed the A3 signal from the CPU.
It's worth doing the continuity check as Ed suggested, but I'm not optimistic it'll reveal a problem with connections. To me it seems more likely that the fault is inside IC U-9, and it'll need to be replaced. Too bad KIM's chips are soldered in place.
As an aside: initially I also wondered about U-13, the tri-state driver that drives RAM read data onto the CPU data bus. Could one of its sections have failed? But if that were the case then I think you would've noticed bit3 always reading high (or always reading low).
PostPosted: Tue May 23, 2023 1:36 pm
Links to the 65xx and KIM-1 manuals (and an entertaining story about their origin :P ) can be found here.
As for your KIM-1, are you confident that it's getting a good source of 5V power? It's a bit of a long shot. But after all these years I should know enough to look for simple problems before hypothesizing about more complex ones... :roll:
PostPosted: Tue May 23, 2023 3:59 pm
(oops! Thanks Jeff for the correction)
PostPosted: Tue May 23, 2023 5:17 pm
Good question about power! I did wonder about that. I'm using an Apple 2A / 10W USB adaptor. It's showing around 5.15V on my multimeter, unloaded. Any advice on a better off-the-shelf power supply?
PostPosted: Tue May 23, 2023 7:08 pm
That should be adequate (unless it's a counterfeit, in which case the specs perhaps won't be met). I'm guessing you've already used it to power up the KIM-1, so what voltage does your multimeter show when the supply is powering the KIM? The KIM expects 5V, give or take a certain tolerance which is probably either +/- 5% or +/- 10%. I'm not sure if it's 5% or 10%, and a quick peek in the User Manual didn't help (but perhaps I was too hasty). Anyway, if you're within +/- 5% and the supply isn't counterfeit (truly is capable of supplying as much as 2A) then you should be fine.
Appendix D of the User Manual shows a power supply you can build. Apparently the KIM-1 requires as much as 1.2A of current from the 5V supply. And, if you intend to use the cassette interface, KIM also requires 12V at up to 50 mA.
blogmywiki, do you have PM notifications turned on? I ask because you've apparently not read a PM I sent you earlier. In it, I suggest you needn't necessarily fix the RAM problem. You could alternatively disconnect the on-board RAM and add a single, more modern memory chip that massively upgrades the KIM's modest 1K.
OTOH, if you can obtain a replacement for U-9 and are comfortable doing the surgery then that's probably the best choice. And of course we're happy to guide you regarding either of those options.
I'm speaking as if it's confirmed that U-9 is the culprit. And perhaps that's a tad premature.
Does A3 (ie,pin 6) of U-9 show continuity (as it should) with pin 6 of the other RAM chips? Does the solder joint look OK where pin 6 joins the PCB trace? Other comments, anyone?
PostPosted: Tue May 23, 2023 8:06 pm
Is the perhaps-suspect RAM chip a lot hotter than the others? That can sometimes be an indication of a bad chip.
I wouldn't worry about power supply, with a misbehaviour which is so specific and repeatable.
PostPosted: Wed May 24, 2023 6:32 am
Thank you everyone! The fault is indeed *very* consistent and reproducible, so it does feel like a hardware problem on the board itself to me.
I'll do some more testing this weekend, thanks for the advice on continuity tests.
I'm very reluctant to try to replace a faulty chip for fear of messing up a piece of vintage hardware, so I am interested to learn more about connecting external modern RAM.
PostPosted: Wed May 24, 2023 9:18 am
If the chips are socketed, then swapping 2 round would be a good place to start. Then, if the fault follows the swapped chip, you know it's the chip, but if the fault stays then it could be board, tracks, etc.
But one thing that might be worth thinking about - but bear-in mind that I know nothing about the Kim-1 monitor, etc. - could you be overwriting critical areas actually used by the "KIM" software causing some odd side-effects? I'm wondering because I'm thinking that a RAM (or board) fault like this would likely cause the whole system to crash and losing just a few bits of RAM in a 256-bit IC seems unlikely to me, but I've seen stranger things happen...
PostPosted: Wed May 24, 2023 12:32 pm
I too was struck by that thought. In particular, how is it possible for the KIM firmware to successfully return from a subroutine?? :shock: But I gather from the lead post that the problem can't exactly be described as bad bits in RAM. Instead, it appears that address line A3 is stuck high or stuck low inside RAM chip U-9. (Perhaps a bond wire has broken off, but the reason isn't important.) The CPU can ask for access to 1024 different bits but the chip responds by accessing only 512 of the bits, because address line A3 is being ignored. Or, as blogmywiki put it,
This implies a degree of tolerance. Subroutines can successfully execute as long as they aren't nested more than four levels (8 bytes) deep! But if it had been A0 that failed then the system would be DOA.
Hmmmm. Well, it's fairly straightforward to add external RAM using the Expansion Connector. But in order to inhibit the on-board RAM I suspect (I need to verify this) it'll be necessary to cut one or two traces on the PCB. If so then your "vintage hardware" will no longer be pristine. And it's already compromised anyway due to the RAM problem, so my feeling is you may as well replace U-9. But the decision is yours.
How are your construction skills? If you do build a board that attaches to the Expansion Connector then I'd suggest making it bigger than the RAM requires. Then later you could use the extra space to put in a 65C22 or some other goodies! :P
PostPosted: Sat May 27, 2023 9:10 am
Thanks everyone, lots of great ideas and advice here.
I'm ruling out the PSU for now, as the fault is utterly consistent and the supply, if unorthodox, is genuine, it's a never used Apple part, shrink-wrapped and taken from an iPad box.
The chips are not socketed, alas, and my construction skills are not great. I did wonder about cutting traces to add external RAM, and am wondering if I can determine with some certainty that the RAM chip is at fault, it would be kinder to the historical artefact to replace it (or get someone with better soldering skills to replace it for me) than to cut traces to enable external RAM...
Anyway, I'll do some more testing later this weekend and thank you again to everyone who has taken an interest in this.
PostPosted: Sat May 27, 2023 1:39 pm
To be clear, there's only a single trace that would have to be cut. We don't need to sever the data bus connections; merely prevent U14 and U13 (which are 74125 tristate driver ICs) from driving onto the bus, and we can do that by interrupting the signal that tells them when to enable. There might be one or two even more minor mods, but all the mods would be reversible (although not invisible). My point is, it's not as if you'd be butchering the board.
That said, building and connecting a memory expansion is a moderately demanding job if you're a novice. The payoff is greater, but you might need guidance if you hit a snag. You might prefer instead to simply replace the defective RAM chip.
