Simplest subset of 6502
Re: Simplest subset of 6502
Removed by author
Squonk wrote:
With only absolute addressing, one would need to pass arguments to subroutine by reserving some fixed memory.
Removed by author
Squonk wrote:
Actually, with only absolute addressing, self-modifying code and access to the stack pointer, it is indeed possible (although not trivial!).
The thing to bear in mind about this topic
is that it always is going to be a tradeoff, landing somewhere in between a very-nearly-6502 and a single instruction tarpit.
(Each of us will be inclined to place that tradeoff at a different place. It's all very interesting, but not a good basis to argue over.)
What's the simplest subset of the 6502 architecture that could still be reasonably useful?
Removed by author
Removed by author
Squonk wrote:
Even with self-modifying code, you need TXS to initialize the call stack.
Removed by author
But you can set the stack pointer to 0x1ff (well, 0xff) at reset, through hardware. Doesn't need a dedicated instruction unless you're going to get exciting in the program.
Removed by author
Well I'm kind of assuming you're emulating|designing|building a complete but minimal processor here, so it would seem that it's just a question of setting a register as part of the reset initialisation: to get the initial reset vector you have to jam the $fffc address onto the bus and then increment it after reading the value into the address register low and high. I don't know what mechanism you would choose to do that, but one could (e.g.)
- tick 0, issue a reset to a register counter
- tick 1, issue a decrement to it
and I feel these could happen in parallel with other required operations for the reset so wouldn't occupy any more time/ticks.
