I saw that too. You can hear him pause just slightly at that point as if he's wondering whether to explain it or not.
If you look closely at the build in the video, you'll see that the reset circuit doesn't have a capacitor, even though it's there in the photo and schematic on his website. It's also on the photo on the kit box. There are other components as well in the photo and schematic not covered in his videos. He's clearly left things open for future development and more videos. Making videos is part of his business model. Based on his Patreon membership he's making at least $1500 per video and likely a lot more. He even says in his FAQ in response to a question about adding a certain feature to a project: "If I did, I'd want to make videos about it."
Interestingly, the RDY pin in his video is tied directly to 5 volts while in the kit photo and schematic it's tied through a resistor. I noted this a few days ago when reading what BDD said in another
thread:
BDD wrote:
You cannot connect RDY directly to VCC. That was also pointed out to you many posts ago. RDY is a bi-directional signal and will be driven low in the event the MPU executes a WAI instruction, whether intentional or not. The way you have it would result in the MPU trying to short out the power supply. Use a 3.3K pullup resistor on RDY.
I was aware of this functionality but hadn't fully considered it. I had played with the WAI instruction a few times but could never get it to work. On reading BDD's comment, things clicked. I had tied the RDY pin directly to 5 volts as I had for all of my builds since my first Ben Eater kit!
That's one of the problems with kits based on videos. Unless the series is complete, you'll likely move ahead faster than the series. Ben's just started on serial, but I've long since added it to my other builds and had added a PS/2 keyboard long before Ben got around to it. I still have my original Ben Eater build though so I can follow along as he adds more videos.
On a side note, I see that Ben's kits have new packaging. It looks like he's found a new producer for these. Also, his kits are no longer available at Jameco here in the US.
