Back near the end of 2020 I presented the source code for Fleet Forth's new (ABORT") , which is so much faster than the old version when there is no error.
CODE (ABORT") ( F -- )
0 ,X LDA, 1 ,X ORA,
0= IF,
IP )Y LDA, SEC,
IP ADC, IP STA,
CS IF, IP 1+ INC, THEN,
POP JMP,
THEN,
>FORTH
WHERE CR R@ S?
ABORT ;
-2 ALLOT
The following snippet of code skips Fleet Forth's instruction pointer, IP , over an inline counted string.
IP )Y LDA, SEC,
IP ADC, IP STA,
There are two other words in Fleet Forth which skip over an inline string. They are (.") and (") .
R> COUNT 2DUP + >R TYPE ;
: (") ( -- ADR )
R> DUP COUNT + >R ;
Fleet Forth's kernel can be made smaller by taking the string skipping code out of (ABORT") and placing it in (") .
: (") ( -- ADR )
R@
>ASSEM
IP )Y LDA SEC
IP ADC IP STA
CS IF IP 1+ INC THEN
NEXT JMP END-CODE
R@ COUNT TYPE
BRANCH
[ ' (") >BODY 2+ , ] ; -2 ALLOT
The new (") is six bytes bigger and the new (.") is four bytes smaller.
The newest (ABORT") is twelve bytes smaller for a net savings of ten bytes.
INX INX
$FE ,X LDA $FF ,X ORA
' (") >BODY 4 + 0= BRAN
>FORTH
WHERE CR R> S?
ABORT ; -2 ALLOT
(ABORT") is still fast. When there is no error, this version of (ABORT") should be two cycles faster. The branch does not cross a page boundary, my metacompiler reports page boundary crossings. I get a print file of the metacompiler messages by typing LOGGER before loading the kernel source.
There is also this code in ?BRANCH
LABEL 2.IP.+!
CLC
IP LDA 2 # ADC IP STA
NEXT CS NOT BRAN
IP 1+ INC
NEXT 0= NOT BRAN // ALWAYS
which skips IP over a cell.
Note: LABEL creates a label in the metacompiler's host vocabulary with the present value of THERE , the target's HERE , as its value. It does not increase the size of the target in any way.
This code fragment, 2.IP.+! can also be used by (IS) , the word compiled by IS , and COMPILE .
The original source.
: (IS)
R> DUP 2+ >R @ >BODY ! ;
: COMPILE
?COMP R> DUP 2+ >R @ , ;
And the new.
: (IS) ( -- )
R@ @ >BODY !
LABEL SKIP.CELL
>ASSEM
2.IP.+! JMP END-CODE
: COMPILE
?COMP R@ @ , BRANCH
[ SKIP.CELL , ] ; -2 ALLOT
The new (IS) is three bytes smaller and the new COMPILE is four bytes smaller.
