It is currently Thu Nov 21, 2024 8:10 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: [97.1] Interrupt timing
PostPosted: Fri Feb 09, 2001 8:22 am
Just a small question from an emulator author - how come (maskable) interrupts take 7 cycles? Presumably the final five cycles are 'push pc low byte / push pc high byte / push status register / load new pc low byte / load new pc high byte' (give or take the ordering of the first three), but what are the first two concerned with? Not even 64doc seems to have this information.
Report this post
 Post subject: [97.2] Interrupt timing
PostPosted: Fri Feb 09, 2001 3:44 pm
ccording to my Rockwell book, there are 8 cycles involved in the NMI.
1 Fetch OP Code Hold Prog. Ctr, Finish Prev Operation
2 Fetch OP Code Hold Prg Ctr
3 Push PCH Decrement Stack Pointer
4 Push PCL Decrement Stack Pointer
5 Push Processor Status Decrement Stack Pointer
6 Fetch Vector Low ($FFFA) Load to PC Low
7 Fetch Vector High ($FFFB) Load to PC High
8 Fetch Interrupt Program Increment PC to PC+1
Hope this helps
Ted Melton
Report this post
