GlennSmith wrote:
Some datasheets are actually quite clear (like Infineon) that the chips are unsuitable for CMOS applications...
It's true some RAM datasheets explicitly state that output levels from the RAM are unsuitable for driving typical CMOS inputs (such as the inputs found on all modern WDC processors; also the inputs of logic families such as 74HC, 74AC, 74AHC).
Just be aware that most modern RAMs are equally unsuitable
even though their datasheets lack an explicit warning. What's important is the numbers contained in the electrical specs... not whether or not the manufacturer chooses to additionally include an explicit warning written in prose.
Martin A wrote:
For "homebrew" applications try it, and if it works use it, is perfectly acceptable
I am sympathetic to this outlook, and I've occasionally gotten away with "breaking the rules" myself. However I do NOT consider it perfectly acceptable, as there's a serious loss of noise immunity. Even hobby projects occasionally fall victim to this loss of noise immunity. Thankfully that's uncommon, but OTOH it has to be said that noise problems can be an absolute b*tch to recognize and resolve.
For more on noise immunity and CMOS (in-)compatibility, see my thread
TTL Compatible... NOT! ( WDC ).
Martin A wrote:
If the drivers can output a guaranteed 2.4v** from a 2.7v supply, and typically do 3v from a 3.3v supply. That's basically saying the high output is at least 90% of the supply voltage.
Things are not always as simple as they seem. I haven't specifically examined datasheets from Alliances, Martin. But as a general trend, it
appears as though many modern manufacturers of 5 volt RAM's are actually selling something else. What they seemingly produce are 3 volt RAM's that each include an internal regulator to reduce the incoming supply voltage from 5 down to approximately 3.
This preserves TTL compatibility and it saves them money due to the reduced die area of lower-voltage geometries.
And it undermines the point you're making about output levels being proportional to the supply voltage. Although the voltage-regulator theory is presently unsubstantiated, the point about proportional voltage swings gets raised (and found questionable) more than once in the linked thread.
