Hi all,
Ok, I have what might seem like an odd timing question, but I'll do my best to explain.
I'm exploring a multi-speed clock circuit, similar to what d???? (can't remember his nick off hand) created for his 65816 project, but a bit different, and I was wondering about timing with regard to the 6522 and the CPU.
Let's say I permanently clock the '22 at 10 MHz
Let's say the CPU is adjustable clock for between 2.5 and 10 MHz (with only 2 speeds selectable, high and low, high would be the same speed as the '22, and low would either be 2.5MHz or 5 MHz)
Can I interface with the via at 10 MHz if the cpu is running at 5MHz, or do I have to make sure the CPU is running at the same speed as the via for any transactions between the cpu and the via?
I'm thinking I need them both running at the same speed, but I'm just not sure - if I can have them running at different speeds, then the solution is easy; if they need to run at the same speed, then the solution is more difficult and I may put off implementing it until I've experimented more.
-T
_________________ -Tony
KG4WFX
