SHE LIVES!!!Attachment:
- Previous rework removed and the cut tracks repaired - pic below.
- Three broken wires on the display Spectrastrip repaired - one was a hairline break that I only found out when I powered up for the first time and noticed a display digit wasn't working.
- Turned-pin IC socket fitted in address select position.
- Another turned-pin socket fitted into the first, and address jumper wires soldered to match the original docs. This allows me to rewire the address select later without messing up the base socket.
- Touched up a few dry-looking joints.
- IC10 refitted = 74LS04
- IC12 refitted = 74LS00
- All existing socketed ICs lifted and reseated to clear any corroded or loose connections.
Having done all the above, I slowly wound up my bench PSU to 7V (allowing 2V drop-out for the LM340-T5 regulator) while monitoring the output from the on-board 5V regulator and the current draw from the PSU - all looked good so I hit the reset button and - YAY LIFE!!!
As could be expected, the keyboard keys need a little exercise to get them working reliably, but I entered a sample program and hit (r)un and saw the expected result. Stepping through the monitor ROM memory shows the expected hex values so that's a good day's work.
I've run out of IPA, so the next steps when some more arrives will be to deflux the boards and apply a small amount of green solder resist over the rework. I might source some more Spectrastrip at some time, but the repairs to the display strip aren't looking too bad.
Next steps:
- Try out tape saving and loading using a PC-based tape recorder emulator (don't suppose anyone's already got some Acorn System 1 progs in MIDI format???).
- Blow the monitor program into an EPROM, re-jumper the board and see if it will run - this EPROM can the be used on the copy of the system I am building until I blow the authentic bipolar PROMs.
- Test the second INS8154 IORAM device - maybe build an AY-3-8912 sound board like we had at school when I first used the System 1!!
- Actually start making my copy!!
Edit: I've now used the System 1 to test all the main chips bought online as 'new old stock' for the replica build (a few of each: 6502, INS8154, 2114) - all working fine, so if the replica doesn't power up first time it's probably my fault!
Before I sign off for now, I must put on record my thanks to
Tony Edgecombe for 'selling' me his System 1 for the cost of a charity donation.
