It is currently Fri Nov 15, 2024 1:00 am
 Post subject: 6502 Stock
PostPosted: Sat Apr 05, 2014 7:12 pm
My current stock of 6502 parts.
Rockwell and Synertek parts are pulls. WDC parts were purchased direct or through a UK distributor.
6502 Parts.xlsx [11.07 KiB]
Downloaded 157 times
Andrew Jacobs
 Post subject: Re: 6502 Stock
PostPosted: Sat Apr 05, 2014 7:55 pm
Thanks. I put the link to this in the "65xx parts sources" head post.
Edit, 1/2/20: BitWise posted an updated inventory at viewtopic.php?p=72448#p72448 .
PostPosted: Sun Apr 06, 2014 6:24 am
However, the file can't be opened unless one has a recent version of MS Excel.
PostPosted: Sun Apr 06, 2014 7:02 am
I opened it in Open Office 3.2, from 2010, from Oracle, under Linux, with no problem. I don't use Microsoft software.
PostPosted: Sun Apr 06, 2014 9:48 am
(Microsoft offer a freely downloadable viewer for their newer formats)
PostPosted: Sun Apr 06, 2014 5:09 pm
I have it but it didn't want to open that file.
What I'm really getting at is any files that are posted on publicly-accessible sources really should be in neutral formats.
PostPosted: Sun Apr 06, 2014 7:49 pm
Here's a cropped screenshot:
PostPosted: Sun Apr 06, 2014 10:45 pm
You should write us up a petition (in a neutral format) and I'll be one of the first to sign it. That should really shake things up a bit around here! :lol: :wink:
Mike
PostPosted: Mon Apr 07, 2014 7:46 am
But it is in an open standard format.
http://officeopenxml.com/
:wink:
Andrew Jacobs
PostPosted: Wed Apr 23, 2014 1:24 pm
Not to add fuel to the fire, but I can open it with Excel 2000 with the updates. I am not sure if the updates are still available from MS or not, but they are probably out there somewhere.
PostPosted: Wed Apr 23, 2014 6:27 pm
Agree. Also, files should be in the simplest format needed to express what needs to be expressed, in this case a csv format would probably do.
But that is enough of format wars ;-)
Lawrence
