It is currently Sun Nov 24, 2024 12:13 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Oct 27, 2010 10:57 pm
I don't want to look as being too critic about the old 6502. It was a remarkable design. Probably the best MIPS/$ and MIPS/#transistor of its time.
Since you are new here, I will repeat that it is still selling in the quantity of hundreds of millions of units per year; but most of them are invisible, being at the heart of custom ICs, the fastest of them running over 200MHz, able to handle up to about ten million interrupts per second.  WDC's primary business is licensing IP, not selling hardware.
PostPosted: Wed Oct 27, 2010 11:31 pm
A 200MHz 6502?!.... I heard it before and I'm sure I'll hear it again, but jeez that speed is sweet for a 6502!
PostPosted: Thu Oct 28, 2010 4:32 am
BAH! That's nothing! You just wait until I finish my optical 6502 clone...
(j/k; but, were such a device indeed to exist, its maximum speed would be limited the slower of light propegation delay (about 1 ft per nanosecond) of the longest inter-gate distance, or the element with the highest index of refraction. An interesting topic for another day...)
PostPosted: Thu Oct 28, 2010 5:59 am
Even at a mere 20 MHz, the old 65C02 clips right along. The '816 does even better when fully exploited.
PostPosted: Thu Oct 28, 2010 11:08 pm
Indeed, and I think I even have a working conceptual design for a Hardware Object-Oriented Programming Language Accelerator (HOOPLA -- yes, it's intentional. If AmigaOS can get away with BOOPSI, I can get away with HOOPLA!!).
Why must I have so many projects? Why can I not finish one before starting another? :)
PostPosted: Fri Oct 29, 2010 2:20 am
kc5tja wrote:
...(j/k; but, were such a device indeed to exist, its maximum speed would be limited the slower of light propegation delay (about 1 ft per nanosecond) of the longest inter-gate distance, or the element with the highest index of refraction...)
You are thinking within the relativity Laws of Einstein..
Think of a black hole now. Those relativity laws are now under the Laws of electromagnetism, controlling light... a hyper galactic light coil... as opposed to a speaker coil, same principle i think
Ah jeez you got me started. This is WAY off-topic. My apologies
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Fri Oct 29, 2010 10:19 am
I was going on about an electromagnetic optical computer. Anyway, I happened across this article this morning:
http://news.yahoo.com/s/afp/20101028/tc ... ogyitworld
China has the fastest computer @2507 trillion calculations/sec, using IC's from the US!
PostPosted: Fri Oct 29, 2010 11:14 am
So true, so true.... :-)
André
PostPosted: Sat Oct 30, 2010 8:53 pm
jesari wrote:
Thanks for the explanation about the 6502 pipelining. I must admit there is some pipelining: last steps of execution in parallel with next instruction fetch. I think this is not always possible, but it can be done on some instructions, and is far from those pipelines found on typical RISC processors.
Hi Jesari
A few minutes ago we updated the pre-release simulator on the 6502.org website. It's even faster than before, and you can visit a URL like
http://visual6502.org/JSSim/expert.html ... =60&r=0020
to run a program of your choice and see the values moving between the various registers - including registers not visible to the programmer.
You could instead run the included short demo program with
http://visual6502.org/JSSim/expert.html ... loglevel=5
This is the first version to fix the timing control state signals, so you can see the state of the machine: it's not a shift register, but something like it. You should be able to see the overlap of successive instructions in a lot of cases.
You might want to arm yourself with Donald Hanson's big block diagram - many of the same names are used.
If you turn on the chip layout view, you'll find you can also zoom in and explore the values of any signals.
Hope you find it interesting! (Thanks to Barry, Brian and Greg, as always.)
Edit: update links, from pre-production to released version
PostPosted: Sat Oct 30, 2010 9:12 pm
I find it timely that you mention this; as I woke up this morning, I decided to work through my old bus synchronization circuitry, asking myself, "What if I represented state as a binary number instead of (in essence) a ring counter?" It's doable, but logic becomes much more complex (6-input AND gates versus 2- or 3-inputs).
Interestingly, you are free to assert multiple states at once, as the 6502 does, if you keep your states fully decoded at all times. You can't do that by representing states as a single number. This is essential for supporting pipelining too.
People can really learn a lot by observing how the 6502 handles its state progression. This is a HUGE service to the electrical engineering community as a whole, and 6502 enthusiasts in specific.
PostPosted: Sun Mar 13, 2011 11:42 am
I think, as one of the above posters put it, the 6502 should be classified as "pre-RISC", or as I'd put it "proto-RISC". It definitely doesn't meet the classical definition of RISC, but it was developed before RISC (as such) existed.
That said, it does have some similarities to later RISC processors. Such as a small instruction set, hardwired decode logic, pipelining (even if limited), and a precursor to large register sets in the form of the zero page.
But I think the most important point that makes it RISC-esque is that the ISA is elegant. It's my favorite ISA. The only complaint I've got is that the X and Y registers aren't orthogonal. When I'm in the zone, I can fit the ISA in my headspace, which is a good thing.
@loop: lda (src),y — sta (dst),y — iny — bne @loop — inc src+1 — inc dst+1 — dex — bne @loop
PostPosted: Sun Mar 13, 2011 8:31 pm
Yes, that is one real good thing. I remember an interview with Chuck Peddle where he said that they talked to programmers what they needed for an efficient instruction set, which the MOS team optimized, where other CPU designers more worked from theoretical considerations. And that approach really shows.
In fact I think the ISA is so elegant that I decided to extend it to a more modern approach. See my 65k project: http://www.6502.org/users/andre/65k/index.html
André
 Post subject: Re: CISC or RISC
PostPosted: Thu Dec 07, 2023 11:27 pm
I would argue that the best answer is it's a pre-RISC CPU. The distinction RISC <-> CISC makes sense from the time on when RISC was coined as a movement to counter CISC complexity. Since the 6502 family never suffered from complexity issues, and doesn't use micro-code, I prefer the term "pre-RISC" to "pre-CISC", but you may use either for symmetry.
PostPosted: Sat Dec 09, 2023 4:31 am
A wryly entertaining observation!
Welcome, leidner :)
Users browsing this forum: No registered users and 47 guests
