It is currently Sat Jun 08, 2024 10:57 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: Sat Jul 23, 2022 6:59 pm
In another thread commodorejohn and I were discussing how the 6502's zero page addressing is vaguely similar to the PDP-8 and CDC-160. Both were single accumulator machines that relied on a page zero indirect addressing mode as additional "registers". For example, neither had any index registers, and couldn't load an address into the accumulator.
This got me thinking about what 6502 assembly would look like if Chuck Peddle took that approach for the 6502, and he omitted the X and Y registers. One way to find out was to write code and explicitly avoid their use, so my Turing Tarpit challenge was born.
After nearly completing Conway's "Game of Life" I had a brain storm. What if I wrote a Turing complete interpreter using a minimal number of instructions? I could "cheat" and write all programs using that set of instructions. The obvious candidate is the esoteric programming language Brain F--k.
So here's my no X or Y register BF interpreter which includes some samples to test it:
https://github.com/Martin-H1/6502/blob/master/FunStuff/brainf.asm
Note that it's slow, but that's because it brute force scans the source text forward and backward during loops, rather than tokenizing the program with references to instruction pointers. I also used a JSR and RTS in two places and inlining could eliminate those instructions as well.
Update 1: I removed the link to my GitHub repo and embedded the original code directly. That's because I plan to delete the original and replace it with the threaded version.
Update 2: I went back to the link as I plan to keep both versions, and this will clutter the post less.
PostPosted: Sat Jul 23, 2022 7:21 pm
Congratulations on the achievement... but is BF really the obvious candidate? Perhaps it is, but it shouldn't be!
(You probably know that Game of Life is Turing complete, so if you'd managed that, it would be job done! And enormously less usable, even, than your language of choice.)
PostPosted: Sat Jul 23, 2022 7:39 pm
Yeah, that's why I started with the Game Of Life. I plan to finish it after this digression.
BF has the advantage that C to BF compilers exist, so there's a crazy amount of samples available for more typical CS problems.
PostPosted: Sat Jul 23, 2022 8:15 pm
I wonder... OPC6 supports a BCPL port, so it could possibly be an interesting little virtual machine. Not a tarpit as such. It's a small machine but might be a little bit of work to write an emulation in XY-free 6502. I would think writing the emulation would be the main task - being X and Y free probably not too much of an extra burden.
PostPosted: Sun Jul 24, 2022 10:49 am
(Sorry, didn't mean to derail your announcement and challenge!)
PostPosted: Sun Jul 24, 2022 11:54 am
No worries.
I would be curious to see other people's take on programming a 6502 using a reduced instruction set. Partly because of how the PDP-8 was able to get away with so few instructions.
PostPosted: Sun Jul 24, 2022 12:17 pm
It feels almost like a few macros would sort out the missing X and Y. I haven't tried it, and neither have I read your tarpit code, but with the single trick of feeling free to modify code which will shortly be executed I think we can do the job. Something like the following perhaps:
X and Y as counters - we can just use zero page
abs,X addressing mode - we can add up two numbers and construct an absolute instruction
indirect addressing - again, construct an absolute instruction then execute it
indexing and indirection combined - perform both of the above, with a possible cost saving if we can construct a zero page instruction.
There is of course a cost, in speed and density. (Or to put it another way, including these addressing modes offers improvements to speed and density.)
PostPosted: Thu Aug 04, 2022 4:29 pm
I've fallen into a digression on a digression. I really didn't like how my BF interpreter processed the program as text and scanned to find the branch locations at runtime. Such scanning was constantly redoing effort that could be done once!
As a complete digression I rewrote the BF interpreter to work more like Forth. It compiles the source text into a list of subroutine addresses and optional operands to those subroutines. By using a data stack I store the branch target iptr and pass that as an operand at runtime. The execute phase then cycles through this table of addresses doing a jump indirect. This makes execution much simpler and hopefully faster.
Using the Sierpinski triangle as a benchmark I've concluded that a threaded code approach is about 17% faster than processing the program textually. I was honestly hoping for something better, but I imagine loading words (rather than bytes) coupled with indirect jumps (rather than branches) eats into the gains from pre-computing branch targets.
In any event here's the source to the threaded code BF interpreter:
https://github.com/Martin-H1/6502/blob/master/FunStuff/brainfdtc.asm
Update: I did some code tweaking and the code is now about 20% faster.
PostPosted: Sat Aug 06, 2022 8:23 pm
My digression on a digression continues.
I was unhappy with the performance boost from direct threaded code, and I realized the overhead of the NEXT function was costing me cycles. I looked at the FIG Forth source, and cycle counting showed my version was in the ballpark. This is a common problem in Forth interpreters, and some go to great lengths to optimize NEXT. But it's possible to eliminate NEXT entirely by switching to subroutine threaded code. At that point the hardware PC becomes your instruction pointer. Plus, it's easy to do by emitting a JSR in the code stream followed by the thread address, and then using RTS instead of JMP NEXT in the threaded code. There were some minor but solvable difficulty in getting a pointer to the parameters to adjust the PC for branching.
Since it's 90 degrees outside, I'm inside doing some coding, and it worked like a champ. Here's a link to the code:
https://github.com/Martin-H1/6502/blob/master/FunStuff/brainfstc.asm
The following are my timings for printing the Sierpinski triangle with my three versions of the BF interpreters:
299 seconds - text based interpreter that scans the source.
222 seconds - direct threaded code interpreter similar to many Forth implementations.
148 seconds - subroutine threaded code for the win!
So how does this relate to my original challenge? Well none of these implementations uses the X or Y register and they all work fine. Also, my NEXT function was only slightly slower than the FIG Forth version, even through FIG Forth uses the Y register. So it proves my thesis that the index registers are nice to have, but not critical. It's page zero indirect addressing that's critical! Although self-modifying code might allow you to even avoid that.
Plus changing the algorithm produced far greater gains in performance than I could have achieved by not restricting my register usage. But that's old wisdom when it comes to programming.
PostPosted: Sat Aug 06, 2022 8:25 pm
Nice result! And it's good to have a quantification of the effects of these design decisions.
PostPosted: Tue Aug 09, 2022 8:02 pm
Thanks BigEd.
I returned to my Game of Life program and decided to sink deeper into the tarpit. Only disallowing the X and Y registers allowed from more complexity than a machine like the PDP-8. To get a better feel for what it would be like to program an early discrete components machine, I needed to disallow even more instructions.
The PDP-8 had eight memory instructions, an I/O instruction, NOP, and eight accumulator bit manipulation instructions. Like the 6502 the PDP-8's accumulator wasn't wide enough to hold an address, so it used pages with addressing modes like page zero indirect. The link register (carry bit) was the only processor status bit, so no zero, negative, or overflow bits and associated branch instructions. But there was a test for zero in the accumulator and branch instruction.
So to increase the Turing Tarpit challenge difficulty I restrict myself to the following 65c02 instructions and addressing modes.
Accumulator operations: and, ora, eor, adc, clc, inc, ror, and rol
Memory operations: lda #, lda absolute, lda (), sta absolute, and sta ()
Flow control instructions: bcc, bcs, beq, bne, jmp absolute, jmp (), jsr absolute, rts, and nop
That's 16 instructions, which is a notable reduction from the 6502's 56, and matches the PDP-8. I'm allowing absolute addressing because the 6502 is a byte machine and one or two byte operands are intrinsic to such a design. I'm also allowing the zero control bit because the PDP-8 had skip on zero.
Notable missing instructions are CMP, DEC, PHA, PLA, and SBC. Subtraction is done by adding the two's complement, and precomputed negative quantities. CMP is a nondestructive subtract, so you have to subtract and test for zero. DEC is achieved by adding negative one. This was actually common on early machines with a discrete logic ALU. The PDP-8 didn't have a stack, so I won't allow its use for anything other than subroutine calls.
I rewrote my game of life using the rules, and it works, but is really slow. I imagine that's because comparison requires doing math twice. Once to subtract a negative, and again to return a result. In any case here's the 6502 calculating like it's 1965:
https://github.com/Martin-H1/6502/blob/master/FunStuff/life.asm
Update: BigEd correctly pointed out that SEC is unnecessary without subtract, and ASL can be done via add. So that's sixteen instructions.
PostPosted: Wed Aug 10, 2022 6:34 am
I'm relatively sure some very early machines offered subtract only, rather than add only - it's easy, if you have subtract, to do an add, but not vice versa.
With subtract, the SEC is handy, whereas with add, the CLC is handy. I'm not sure you need both.
ROR is handy, but I think ROL and ASL can be done by doubling, more or less, and your add, or subtract, can manage that. Maybe keep ROL but ditch ASL - that would give you a round number of 16 instructions!
PostPosted: Thu Aug 11, 2022 11:25 am
I'm not sure about early machines in general, but I do know that the PDP-8 only had a TAD (two's complement add) instruction. It also had CIA (complement increment accumulator) which two's complemented the contents of the accumulator. By omitting subtract they saved hardware complexity and cost by shifting it into software.
You're right and I updated my list of instructions. I actually didn't need any bit operations for this project, but I included them on the list because eventually you would need them.
PostPosted: Thu Aug 11, 2022 1:27 pm
Yes, and the list of "very early machines" even includes some embedded applications! Diablo daisy-wheel printers had a processor built entirely with TTL (ie, no microprocessor), and I had a client that used a fleet of Diablo model 1345's in their manufacturing operation in the late 1980's and well into the 1990's.
Based on the schematic diagram (below) I was able to reverse engineer the instruction set, and it is painfully limited (ie, only ten instructions). In that respect its context seems relevant to this thread.
And Ed's remark is applicable, as there is no "plain vanilla" ADD instruction. Only two approximations are available.
  • There's an instruction that'll fetch a register, add-with-carry an immediate constant hard-coded in the program and, then store the result back to the register; and,
  • there's an instruction that'll fetch a register, fetch a second register and invert the data, add-with-carry, and then store the result back to the first register. Because of the inversion, this instruction is essentially a subtract (with borrow, if carry is clear). To accomplish a register to register addition you need to firstly create an inverted copy of one of the operands and then subtract.
The firmware for the Diablo relied heavily on bit operations, and there were several registers which each contained only a collection of unrelated bit fields. But (as with addition), things weren't entirely straightforward. :roll:
There was no logical OR instruction, so the only way to set a bit in a register was to use the instruction (noted above) which adds a hard-coded constant to the register. But of course that's inappropriate if the bit happens to already be set! :shock:
So, if you wanted a certain bit set, you'd first test that bit to see if it's already set... and then do a conditional branch! (ie, take no action if it's already set; otherwise add $01, $02, $04, $08 or whatever you need in order to set that particular bit! :lol:
I got completely sucked down the rabbit hole, and eventually ended up reverse engineering the firmware and then hacking it. And yes it'd be fair to call this a Tarpit programming challenge! (Why hack the original firmware? The second half of this page describes the goals (although not the actual code). And there's a page about the processor itself here.)
PostPosted: Thu Aug 11, 2022 2:16 pm
@Dr Jefyll, I thought at the circuit level there were only binary adders, and subtraction with borrow required inverters for one of the inputs. I recall when I looked at the 6502 logical diagram that's how it was arranged.
BTW, thanks for posting that information about the IC based processor. Microprocessors used to be magic to me until I started reading stuff like that. Then you see what's going on under the hood.
Someday I may try building my own CPU, but I would definitely keep it simple and put all the burden in software. So a Turing Tarpit would likely be the result.
