It is currently Wed Sep 25, 2024 4:28 pm
PostPosted: Tue Mar 25, 2014 6:35 pm
I know it's a horrid abuse of programmable logic, but I'm wondering if it's possible to create an astable multivibrator in Verilog?
Why?
To complete the 6525 effort, I need to create a 500uS delay period. It doesn't have to be precise, just >= 500uS. I otherwise have no need for a clock signal. Thus, I was wondering if it would be possible to put the 10uS CPLD into a feedback loop, count 64 transitions, and use that as a timer.
Jim
PostPosted: Tue Mar 25, 2014 6:51 pm
Why?
Jim
I'm no Verilog expert, but seem to think that a simple(?) state machine may accomplish what you want. However, I'm not sure how you would go about achieving an ~500µS delay without use of a clock input.
PostPosted: Tue Mar 25, 2014 7:31 pm
Keep in mind that the 10ns (not µs) is a guaranteed maximum, and that there's no guarateed minimum. I suspect typical would be somewhere around half to 2/3 of max.
PostPosted: Tue Mar 25, 2014 8:21 pm
If you have a spare input and output, a resistor and capacitor will give you some approximation to any delay you want.
PostPosted: Tue Mar 25, 2014 8:57 pm
and even if there are no Schmitt-trigger inputs, you can approximate one by adding positive feedback with resistors, to avoid problems with the "no-man's land" in the slow input transitions between solid logic 0 and logic 1.
PostPosted: Wed Mar 26, 2014 5:49 am
Yep, messed up there. 10nS, but the theory is still valid, as I need 500nS of delay:
http://www.zimmers.net/anonftp/pub/cbm/ ... 6525-7.gif (see CB and CA notes in top left corner of page)
I figured I'd need to empirically test the delay to get it right...
I will have some extra pins on a 95144-100 to create the one shot, and I like it better as an idea. I assume you drive the output high, and then the input going high is your delay...
PostPosted: Wed Mar 26, 2014 1:58 pm
The trouble with propagation delay is, it's not predictable or well specified. No minimum figure, as Garth said.
A better way -- and the normal and natural way -- to implement a delay with programmable logic is via a counter. At the start of the delay the counter would be loaded, then it would proceed to decrement (or increment) according to a clock signal that's been chosen as a time base. The delay is complete when the counter reaches its terminal value (typically zero if you're decrementing).
That same basic idea can work for you, too. Presumably this 6526 device -- a 65xx peripheral -- gets the Phase 2 signal fed to it, and that can serve as your time base. From the datasheet you posted, I see the delay commences with a write to PRB. This would load your counter, which would subsequently decrement at the Phase 2 rate until the delay is complete. You'd arrange for CB to be low anytime the counter is not at its terminal value. This gives a nicely defined pulse following a write to PRB. :)
You'd need to decide whether the counter decrements on the rising or falling edge of Phase 2, and what the initial count should be. Looks like that count might be be extremely small -- like, 1! A simple flipflop might serve as the "counter." It would "count" from 1 down to zero. Possibly the original 6526 logic is just as I describe.
PostPosted: Wed Mar 26, 2014 6:30 pm
For an uncalibrated delay, you could make an on-chip ring oscillator with an odd number of inverters - perhaps 5 or 7 - and use that fast signal to clock a counter. You could trim that by bringing one of the outputs off-chip and loading it with a capacitor, probably.
