Oh, of course the carry should be set before the start of a subtraction chain; er, er, I just didn't want to clutter up the discussion. Yes, that's it. Or a big boy did it and ran away. Um. Or cosmic rays?
Also, the line
I would submit that while the first version is both smaller and faster, it more clearly shows your intent.
should read
I would submit that the second version is both smaller and faster, the first more clearly shows your intent.
Here I go again, contributing to the total amount of wrong on the internet! Obviously I shouldn't post late at night.
(When I had to work with PIC assembly ten or a dozen years ago, I had to do multi-precision arithmetic. The PIC didn't have add-with-carry or subtract-with-borrow and as a result the carry had to be rippled through after every addition/subtraction. At the time, *every* example on the net with the sole exception of a single Microchip datasheet got that wrong...)
Though with my statement 'shows intent' I suspect that many of the code writers here would agree with this premise: optimising too early is always a bad idea. In initial code, write for clarity of intent and simplicity of logic; that way you will have more chance of remembering what it's supposed to do when you come back to it in six months, or next week. Come up with clever tricks to optimise code length or clock cycles if and only if it turns out to be necessary, or aesthetically desirable.
