It is currently Fri Oct 04, 2024 4:30 am
PostPosted: Fri Sep 22, 2017 11:32 am
In Mr. Wilson's NMOS/CMOS differences page(http://wilsonminesco.com/NMOS-CMOSdif/), about halfway down, there is a table of instructions that first appeared on the CMOS version.
Among these are a set of instructions that set/reset and branch on certain bits in a ZP location. That page says they are available on the WDC and Rockwell parts. According to WDC's programming manual (by Eyes and Lichty), these instructions are not present on the WDC part, only the Rockwell.
Which is correct?
PostPosted: Fri Sep 22, 2017 11:46 am
They are included in the w65c02 according to http://www.westerndesigncenter.com/wdc/ ... 65c02s.pdf, but I seem to recall that the Rockwell instructions weren't included in the early iterations of WDC's processor. But I can't find an old enough datasheet at the moment.
PostPosted: Fri Sep 22, 2017 11:47 am
Crossed over with Tor, but:
Actually, upon looking at the actual datasheet, I see that the bit-manipulation and branching instructions are indeed on the current W65C02S.
It may be worth explicitly noting this on your page, Mr, Wilson.
PostPosted: Fri Sep 22, 2017 11:54 am
Update: Wikipedia says that there used to be a '65SC02' processor which was a variant of the W65C02S but lacked the bit instructions. But I can't figure out from the WP history who inserted that information. It seems to refer to one of Zaks' books though.
PostPosted: Fri Sep 22, 2017 12:07 pm
I can definitely confirm that the W65C02S definitly has those instructions, as I use them quite a lot in my software.
PostPosted: Fri Sep 22, 2017 12:23 pm
I can imagine. They will probably be of great use to me, although not for hardware waiting loops like the ones I'm using at this stage.
PostPosted: Fri Sep 22, 2017 1:06 pm
From personal experience I can tell you hardware waiting loops are a great way to benefit from the BBS/BBR instructions! :) And SMB/RMB are terrific for bit-bang outputs. However, only a minority of 65xx systems map their I/O into zero-page. Sometimes there are good reasons for that; other times it represents a missed opportunity. For further discussion see major speedup with 65C02 I/O mapped into zero-page.
PostPosted: Fri Sep 22, 2017 1:07 pm
An earlier thread suggests that WDC initially didn't offer these instructions, but for a long time now they have included them in their offerings.
viewtopic.php?p=8218#p8218
Note also that the CMD/GTE 65SC02 part does not have them.
http://6502.org/documents/datasheets/cmd/
PostPosted: Fri Sep 22, 2017 3:04 pm
Ok, I'll do that.
Bill Mensch said recently that he wasn't fond of those but consented to add them to WDC's 65c02 when, if I understood correctly, a customer (company, not individual) wanted them. I remember in the late 1990's when they had both versions, and they put a "B" on the end of "W65C02S" to indicate the ones that had the bit-manipulating and -branching instructions, but then they made them all have them and took the B back off.
PostPosted: Fri Sep 22, 2017 3:14 pm
They are definitely more useful on the 6501 and 6541 chips that had peripherals mapped into page zero.
PostPosted: Fri Sep 22, 2017 6:52 pm
Ok, I'll do that.
Scratch that. Make it early 90's. I found the following again, in the Aug '92 data sheet. By the July '96 data sheet, these instructions were standard in all of them.
The note at the end of the Aug '92 data sheets says:
    7.1 Bit Manipulation
    The Bit Manipulation Instructions have been added to the standard W65C02S. The designation for this updated device is W65C02SB. [...] The W65C02S will continued to be produced for a period of time. The W65C02SB will eventually become the only W65C02S device available.
I updated the web page.
PostPosted: Fri Sep 22, 2017 7:24 pm
An alternative might be to be to use BIT - if the status bit you are interested is either bit 6 or bit 7, you can use BIT followed by BMI/BPL or BVS/BVC, rather than LDA followed by AND and then BEQ/BNE.
I've been working with CHOCHI lately, and the status register on the CHOCHI has RX_READY as bit 6, and TX_FULL as bit 1. So, polling for received character can be coded as
getchar: BIT $C009
         BVC getchar
         LDA $C008
         RTS
By making a trivial change to UART.v, you can code putchar as
putchar: BIT $C009
         BMI putchar
         STA $C008
         RTS
Without this change, you would have to do something like
putchar: PHA
putch1:  LDA $C009
         BPL putchar
         PLA
         STA $C008
         RTS
PostPosted: Fri Sep 22, 2017 10:27 pm
What I'm about to say doesn't concern the bit instructions, but it may be relevant to the conversation above. To watch a certain input bit, you can also wire it to the VIA's CA1, CA2, CB1, or CB2 and take advantage of its feature to interrupt on the selected edge. Select it in the VIA's PCR. To interrupt every so many edges, use the VIA's timer/counter 2 (T2) in pulse-counting mode, counting pulses on PB6. You load the desired number into T2, then when the decrementing brings it down to 0, it generates the interrupt. At the same time, you could use T1 as a phase-2-based timer, and the ratio gives you a frequency counter. The computer can spend most of its time doing something else while the VIA counts. No need for loops.
PostPosted: Fri Sep 22, 2017 10:32 pm
rwiker, your second code sample appears to be seriously defective.
Mike B.
PostPosted: Sat Sep 23, 2017 3:21 am
Mike B.
Ah... the "BPL putchar" in the third code sample should be "BPL putch1"... is that what you meant?
On the plus side, I got the indentation right :-)
