Pico‑6522 Bridge: Real 6522 Smart Peripheral Auto Handshake
Posted: Mon Feb 09, 2026 3:57 am
Hi everyone,
I’ve been a member here for a few years now, and I wanted to share a project in hopes of giving something back to the community. This started as a small personal tool and unexpectedly grew into something much larger. I’ve now released it publicly in case it’s useful to others.
GitHub repo:
https://github.com/DonaldMoran/pico-6522-bridge
How this project started
This whole thing began with a very simple goal: I just wanted an easier way to get my 6502 assembly programs onto my machine without fumbling with SD cards (though I’ve enjoyed bit‑banging those), waiting on slow copy/paste transfers, or dealing with XMODEM (which I also enjoyed exploring). Every time I made a change, the workflow slowed me down.
Once I had a basic file‑transfer mechanism working through a Raspberry Pi Pico, I realized I could also use it to demonstrate that my 6522 emulation — via my 6502 Pico emulator — was behaving correctly. From there, the project grew almost by accident.
I found it surprisingly convenient that I didn’t need to implement a filesystem on the 6502 side at all — instead the Python 3 file_server.py handled everything by exposing a network file share behind the scenes (i.e. a folder on the machine I write my assembly on). That meant I could write code, assemble it into something like X.BIN, and from my NETDOS environment simply type “X” as a command. The system automatically loads (bloads) and executes X.BIN without any extra ceremony. That workflow turned out to be so smooth that I kept extending the idea.
Smart Peripheral Mode (Real 6522 Hardware)
One of the most interesting directions this project took is the smart peripheral mode, where the Pico connects to a *real* 6522 VIA and acts as an intelligent co‑processor for a 6502 system.
The 6502‑side assembly is written in ca65, and the pico bridge uses the 6522’s
automatic handshake mode (CA2 pulse‑on‑write) for parallell communications.
The GitHub repo is built around automatic handshake, though I have also
tested manual handshake mode offline (while fighting with the "ghost byte" in auto mode
, and the protocol behaves correctly in
either configuration. I stuck with automatic handshake mode for the theoretical speed boost, and the challenge of the "ghost byte" at transaction end, which I beat /solved elegantly I think.
In this mode, the Pico:
- responds to VIA handshakes
- handles CA1 and CA2 or CB1 and CB2 correctly
- provides a clean, deterministic parallel interface
- exposes a command‑driven API to the 6502
This allows a 6502 system to access modern capabilities (filesystem, Wi‑Fi, external commands, dynamic loaders, etc.) through a real VIA chip, without needing any custom hardware beyond the Pico and the VIA.
About the emulator
A special thanks goes to jfoucher, whose original emulator provided the foundation for this work. I’ve modified it heavily along the way, but his contribution was essential in getting this started.
The emulator work wasn’t originally meant to be a standalone project — it was simply a way to make firmware development easier for my *real* breadboard 6502 computer. Instead of constantly flashing hardware or wiring up test circuits, I could iterate quickly in the emulator and then move the same code over to the physical machine once it was stable.
Over time, the emulator grew significantly. I’ve had it working with LCDs, bit‑banging SD cards, and various other experiments. More recently I added proper support for CA1, CA2, CB1, and CB2, and made sure they behave as expected. I’m also reasonably confident that the 6522 timers work at least to a practical degree for typical use cases.
The emulator ended up becoming a surprisingly powerful development tool, even though it started as a convenience layer for my hardware work.
Two System Builds: NETDOS and Microsoft BASIC 2.0
The project now includes two complete builds that run on top of the bridge:
1. NETDOS (my own disk operating system)
This is a DOS‑like shell environment I wrote specifically for this project. It uses the Pico as a smart peripheral to provide:
- directory listings
- file loading and execution
- command dispatching
- dynamic external commands
NETDOS lets me write code, assemble it into X.BIN, and simply type “X” at the prompt to run it instantly. No SD cards, no serial transfers, no XMODEM — just edit, assemble, run.
2. Microsoft BASIC 2.0 Integration (from the mist64 reconstruction)
There is also a build that integrates Microsoft BASIC 2.0 using the excellent mist64 reconstruction. In this version:
- LOAD works
- SAVE works
- CD works
- DEL works
This gives BASIC a modern, DOS‑like backing store without needing a real disk drive or filesystem on the 6502 side. BASIC programs can be loaded and saved through the Pico’s virtual filesystem, and the environment feels surprisingly natural.
What the project does now
The Pico emulates a 6522 VIA and exposes a command‑driven interface that lets a 6502 system access:
- filesystem operations
- Wi‑Fi configuration
- external commands
- dynamic command loading
- binary dispatching
- and more as the library evolves
The goal is to provide a clean, extensible bridge between a 6502 machine and modern peripherals or network services.
What’s available
- Full source code (MIT licensed)
- A growing command library
- Documentation and examples
- Pre‑built binaries for convenience (UF2 + BIN)
- A clean GitFlow structure for contributors
Dual‑Pico Wiring Diagram (Emulator ↔ Bridge)
System Architecture Block Diagram
A personal note
This forum has given me so much over the years — knowledge, inspiration, and a sense of community. I hope that in some small way this project (and others I contribute in the future) can give something back. Thank you all for the shared technical wisdom that has kept the 6502 world alive and thriving.
— Don
GitHub repo:
About the emulator
- LOAD works
- SAVE works
- CD works
- DEL works
- external commands
What’s available
HOST PICO (Emulator) BRIDGE PICO (Pico W)
| GP0 (PA0) <--------->| [DATA BUS] <--->| GP6 (PA0) |
| GP1 (PA1) <--------->| [DATA BUS] <--->| GP7 (PA1) |
| GP2 (PA2) <--------->| [DATA BUS] <--->| GP8 (PA2) |
| GP3 (PA3) <--------->| [DATA BUS] <--->| GP9 (PA3) |
| GP4 (PA4) <--------->| [DATA BUS] <--->| GP10 (PA4) |
| GP5 (PA5) <--------->| [DATA BUS] <--->| GP11 (PA5) |
| GP6 (PA6) <--------->| [DATA BUS] <--->| GP12 (PA6) |
| GP7 (PA7) <--------->| [DATA BUS] <--->| GP13 (PA7) |
| GP11 (CA2) ---------->| [REQUEST] ---->| GP14 (Input) |
| GP10 (CA1) <----------| [ACK] <----| GP15 (Output) |
| GND -----------------| [COMMON GND] ---|--- GND |
| 65C02 CPU |
| - Executes user |
| programs |
| - Issues I/O |
| requests |
| 8-bit data + control
+---------v--------+
| 6522 VIA |
| PA0–PA7 <----> Data Bus
| CA1/CA2 <-----> Handshake
| CB1/CB2 <-----> Optional HS
| Parallel smart-peripheral link
| Raspberry Pi |
| Pico W |
| (Smart Peripheral)
| - Implements VIA |
| protocol layer |
| - Handles FS, |
| Wi‑Fi, NETDOS, |
| BASIC I/O, etc |
| - Loads/executes |
| external cmds |
| High-level operations
+-------v-------+ +---------v---------+ +----------v----------+
| Virtual FS | | External Commands | | Wi‑Fi / Network |
| (file_server) | | (X.BIN loaders) | | (optional) |
| - LOAD/SAVE | | - Dynamic loading | | - Future expansion |
| - CD, DEL | | - Command dispatch| | - Remote FS access |
A personal note
— Don
