Page 1 of 1
uint32_t comparison
Posted: Thu Feb 05, 2026 9:12 pm
by barnacle
I'm trying to compare two 4-byte words: one at a fixed location (lba) and one at a variable location pointed to by [Y:A]. All I need to know is whether one is greater than the other; equality is nice to have since I can delete another routine. Both variables are unsigned values.
The need to increment and test Y demolishes any previously calculated flags, which is a shame, but I think this ought to work (I may have the C flag upside down). There's a lot of flags being pushed and pulled...
; u32_cmp
; compare four-byte words in lba and [Y:A]
; returns the carry set if [Y:A] < lba
u32_cmp:
sta u32_ptr
sty u32_ptr+1
ldy #0
php
u32_c_1:
plp
lda lba,y
cmp (u32_ptr),y
php
iny
cpy #4
bne u32_c_1
plp
rts
Thoughts?
Re: uint32_t comparison
Posted: Thu Feb 05, 2026 9:33 pm
by barnacle
Ooops, let's try this; it needs the subtraction for the higher order bytes:
u32_cmp:
sta u32_ptr
sty u32_ptr+1
ldy #0
lda lba,y
cmp (u32_ptr),y
php
u32_c_1:
iny
plp
lda lba,y
sbc (u32_ptr),y
php
cpy #3
bne u32_c_1
plp
rts
Posted: Thu Feb 05, 2026 9:49 pm
by leepivonka
Maybe like:
u32_cmp: ; compare lba with (YA) as uint32, return P.C & P.Z
sta temp1 ; save ptr to arg
sty temp1+1
ldy #$ff ; start at most-significant byte
@1: iny ; step to next byte
cpy #4
beq @9 ; if done, return z=1, c=1
lda lba,y ; compare
cmp (temp1),y
beq @1
@9: rts
Posted: Fri Feb 06, 2026 6:30 am
by barnacle
Ah, thank you; that's a little tidier than mine. I'll have a play.
Posted: Fri Feb 06, 2026 6:34 am
I'm trying to compare two 4-byte words...There's a lot of flags being pushed and pulled...
No need to to make it complicated.
Something like this might work for you, assuming the “4-byte words” aka “double words” are in little-endian order:
u32_cmp =* ;compare LBA to variable
; This function compares the current 32-bit LBA to a
; 32-bit variable whose address is pased in .A (LSB) &
; .Y (MSB). The LBA & variable are assumed to be in
; little-endian format. Returns are as follows:
; SR ——> c z Result
; x 1 LBA == variable
; 0 0 LBA < variable
; 1 0 LBA > variable
; Invocation example:
; lda #<variable
; ldy #>variable
; jsr u32_cmp
; beq isequal
; bcc lbalower
; bcs lbahigher
sta u32_ptr ;variable pointer LSB
sty u32_ptr+1 ;variable pointer MSB
ldy #4-1 ;index...
; We are working MSB to LSB.
u32_c_1 =* ;main loop
lda lba,y
cmp (u32_ptr),y
bcc u32_c_2 ;LBA < variable
bne u32_c_2 ;LBA > variable
dey
bpl u_32_c_1 ;keep checking
iny ;LBA == variable
u32_c_2 =*
rts
Posted: Fri Feb 06, 2026 10:47 am
by barnacle
My assembler makes yours a byte longer than Leepivonka's, BDD, but it's more understandable to me
and I think it might provide more functionality - not sure about that yet.
Thanks, both!
Posted: Fri Feb 06, 2026 2:23 pm
by barnacle
And here's the results from BDD's method; just what I need.
NeoDOS32 v0.0276
Free cluster count: 0001E5EC
Next free cluster: 0000007D
Press any key to boot:
Test 32-bit compare
lba is < tmpq1 Z = 0 S = 1 C = 0
lba is = tmpq1 Z = 1 S = 0 C = 1
lba is > tmpq1 Z = 0 S = 0 C = 1
finished test - any key
This means I can replace an existing equality test as well.
Okay for me to use the code in the FAT32 stuff?
Posted: Fri Feb 06, 2026 4:42 pm
by teamtempest
I agree. It took me a second to understand that final INY, but only a second. Very straightforward and quite handy.
Posted: Fri Feb 06, 2026 8:36 pm
NeoDOS32 v0.0276
Test 32-bit compare
What are the S = 1 and S = 0 referring to?
Are you asking for permission to use my routine? Of course you may.
Posted: Fri Feb 06, 2026 8:49 pm
Having “slept on it,” as well having consumed sufficient quantities of coffee
, I came up with a slightly shorter rendition:
; SR ——> c z Result
; lda #<variable
; ldy #>variable
; jsr u32_cmp
; beq isequal
; bcc lbalower
; bcs lbahigher
ldy #4-1 ;index...
lda lba,y
cmp (u32_ptr),y
bne u32_c_2 ;LBA != variable
; If LBA < variable, c = 0, z = 0.
; If LBA > variable, c = 1, z is don't care.
dey
u32_c_2 =*
rts
Bon appetite!
Posted: Fri Feb 06, 2026 8:53 pm
by barnacle
The flags tested were zero, sign, and carry. Just included for completeness since it's the inverse of the carry. The canonical name is probably 'N' in 6502 land.
Thanks for the permission. Credit in the source code!
The new code is interesting, but it's handy to have the equality test as well.
edit: wait, what does the last routine return for equality? Z set?
Posted: Fri Feb 06, 2026 11:51 pm
Yes, canonical for the negative bit in SR is ‘n’.
In a binary comparison context, the state of n is not only irrelevant, it may/could/might/probably-will be treacherous. In comparisons, c and z are your friends; n is a sNake in the grass
, since it reflects the internal sign effect caused by the subtraction that CMP, CPX and CPY carry out. It is possible with certain values to produce a comparison in which carry is clear (register_value < memory_value) and the internal subtraction does not result in a carry into the sign bit.
Yer welcome.
The new code is interesting, but it's handy to have the equality test as well...edit: wait, what does the last routine return for equality? Z set?
Same results as the previous routine, as described in the comments.
