65C22 Timer1 in free run mode and interrupts.
Posted: Mon Apr 21, 2025 5:43 pm
In my ongoing exploits to develop my understand of 65C02 related hardware and software (which is an enjoyable pastime in itself!), I've been improving my routines for the Hitachi 20x4 LCD HD44780U module which is connected in 4-bit mode to PORTB of the 65C22. As part of my approach, I had already created an 80 byte buffer in RAM which allows the LCD to act as a pseudo memory mapped device. I would make multiple writes to the buffer then call a subroutine to update the LCD with the buffer contents which also took into account the non-linear mapping of the LCD display. This way, the "memory mapped display" in RAM was contiguous which made for an easier programming model.
Then I came across this forum post which made me think of emulating the same interrupt driven approach to LCD updating. This would be a nice project as I hadn't done any real interrupt handling code. After some initial teething and troubleshooting, it worked. I am aware, however, this may be despite my coding rather than because of it. So, I'd be grateful if you can comment on my code and highlight where improvements could be made or where best practices should be adopted.
Basic concept is to get Timer1 to generate an interrupt every 10 ms and to count 16 of those interrupts, at which point, the LCD will be updated with the buffer contents, everything reset and the process to start again. Using my logic analyser, I can see that IRQB is indeed going low every 10 ms and that data burst activity to the LCD in 4-bit mode is lasting around 4.8 ms (I'd pre-calculated that, according to the HD44780U datasheet, this would take a minimum of 3.1 ms for LCD execution time alone). The whole cycle takes around 160.04 ms, equating to an LCD refresh rate of 6.25 Hz. The MPU load for doing this equates to around 3% (I think, as I worked it out like this -> 4.8/160 = 3.0% - is that the right way to do it?). My phi2 clock runs at 3.6864 MHz. I've not included the code that does the LCD/buffer transfer but I can post it if required.
Thanks.
Dave
.org $0480
start_0480: ; Set up Timer1 on 65C22 VIA in free run mode to generate an interrupt every 10ms (0.01s).
lda #$10 ; Sets the counter to track number of interrupts (16 no.).
sta TIMER1_COUNT + 1 ; Hold this as a constant to reset to. Like a latch.
sta TIMER1_COUNT ; This will decrement then be reset with the above value.
lda #%01000000
sta ACR ; Places Timer1 into continuous interrupts (free run mode).
lda #$FE ; 0.01s @ 3.6864 Mhz (-2 cycles) = 36,862 ($8FFE).
sta T1LL
lda #$8F
sta T1LH
sta T1CL
lda #$8F
sta T1CH
lda #%11000000 ; Sets interrupts for Timer1.
sta IER
cli ; Clear Interrupt Disable i.e. enable interrupts.
rts
; Includes
.include 4-bit_lcd.h.a65
; Interrupt Handler(s)
.org $0700
irq:
pha ; A, X & Y -> stack.
phx
phy
lda T1CL ; Clears the interrupt flag just by reading from T1CL.
dec TIMER1_COUNT ; Decrement counter.
bne irq_exit ; Are we at Zero? No -> nothing more to do, so exit.
; We have counted the number of interrputs required at this point.
lda TIMER1_COUNT + 1 ; Get the reset value.
sta TIMER1_COUNT ; Update.
jsr lcd_prbuff ; Update the lcd display with the contents of the lcd buffer.
irq_exit:
ply
plx
pla ; Y, X & A <- stack.
rtiDave
