Page 1 of 2
Apple II , DMA question.
Posted: Sun Mar 09, 2025 12:31 pm
by gregorio
In AppleII there is DMA access to RAM. It consists of stopping the 6502 clock. I have a question. For how long can you safely stop the 6502 clock in the LOW state in the MOS version?
Re: Apple II , DMA question.
Posted: Sun Mar 09, 2025 2:13 pm
Not for very long. Ed probably knows for sure, but I think FMIN for the NMOS part is in the 250 KHz range, below which the registers are at risk of losing content.
It is permissible to stop the clock for an indefinite period of time in the high phase with all versions of the 65C02. It is permissible to stop the clock an indefinite period of time in either phase with any WDC 65C02 or 65C816 that has an ‘S’ designator in the part number, e.g., W65C02S6TPLG-14. The ‘S’ indicates the device has a static core. WDC switched from dynamic to static cores in the early 1990s, at which time FMAX was increased to 14 MHz. Incidentally, the ‘T’ in the part number means the die was produced at the Taiwan Semiconductor (TSMC) foundry. Parts with the ‘S6T’ designation are the highest-performing versions of the WDC product line.
Posted: Sun Mar 09, 2025 3:55 pm
I don't know for sure, but in the past I said
> note that it's the max cycle time which is the constraint here. The general advice is to go no slower than 100kHz for reliable operation. In practice you've probably got some tens of milliseconds before charge leakage starts to flip values, maybe more
The actual length of time before an important value decays will be a function of voltage, temperature, noise, manufacturing variation, and possibly also altitude and solar activity...
Posted: Sun Mar 09, 2025 4:39 pm
by drogon
Highly anecdotal and "it worked for me", but when I was experimenting with overclocking my 6507s (so NMOS) I somewhat crudely unplugged a wire from one can oscillator into another.
The board stopped then started again - just carried on where it left off. I left it 10 seconds once to see what would happen - it just carried on.
No guarantee of anything though!
Did any peripheral for the Apple II actually use DMA though?
Posted: Sun Mar 09, 2025 4:46 pm
A related question is how long DRAM retains data without refresh - George Foot explored that here
Testing memory refresh failure
Posted: Mon Mar 10, 2025 5:01 pm
by Yuri
I'm curious as to why Apple didn't use the RDY pin for this, anyone know?
Posted: Mon Mar 10, 2025 6:17 pm
RDY has no effect during a write cycle with NMOS parts.
Posted: Mon Mar 10, 2025 6:46 pm
by gregorio
I want to connect a 65816 symulator (STM32H750) to the AppleII bus so that it works in DMA mode and does not disable the 6502.
This emulator has its own RAM but needs access to Video RAM and I/O.
Since the maximum amount of data to write to RAM that the symulator 65816 can write in one command is 2 bytes, I think that stopping for 2 cycles will not be a problem.
I will have to figure out how to prevent problems with MVN MVP
Posted: Mon Mar 10, 2025 7:10 pm
by barrym95838
April 1st is still a few weeks away, but maybe you could find some time to rig up an external gate to trigger NMI when it sees those opcodes, then print "PLEASE DON'T DO THAT" in your NMI service routine (in APPLESCII, of course).
Posted: Mon Mar 10, 2025 9:52 pm
by Uncle Warthog
Apple's recommendation is 10 uSec but it really depends on the actual CPU in use. The recommendation is based on Rockwell CPUs with Synertek CPUs being good for 40 uSec. If you're talking about a IIgs, that uses a 65816 which is fully static so you can stop things for any length of time. I suspect that an actual MOS CPU would be similar to the Rockwell in timing.
Apple produced some tech notes covering detailed bus timing for DMA access. See
https://mirrors.apple2.org.za/Apple%20I ... 989-09.pdf for details.
Posted: Mon Mar 10, 2025 10:11 pm
by Uncle Warthog
Many did. Any Z80 card using the original Microsoft softcard design or anything like it used DMA for access as there was no memory on the card. Many other replacement CPU cards did as well.
A few cards used for software piracy, er,
preservation had their own CPU and used DMA.
Some other cards such as video input cards and debugging aids did as well.
Apple had their own DMA SCSI controller card too. I've been told that Apple's big demo for that card was a digitized version of the asteroid field scene from
The Empire Strikes Back stored on a hard drive being pumped into an Apple IIgs' video and sound memory at full frame rate. Impressive if true. Some of the newer third-party storage controller cards made toward and after the end of Apple producing the II also use DMA.
Posted: Mon Mar 10, 2025 11:07 pm
What sort of problems are you anticipating?
Posted: Mon Mar 10, 2025 11:19 pm
No sir, the 65C816 in the IIGS is not static and as is the case with all 65Cxx MPUs, the clock can only be safely halted on the high phase. The IIGS went out of production about a year before the release of the static-core 816.
Posted: Mon Mar 10, 2025 11:24 pm
by gregorio
I use AppleII Europlus and SY6502 processor, so Synertec.
I don't have 65816 but only its simulator running on STM32H750
https://stm32-base.org/boards/STM32H743 ... 7XX-M.html
I want to connect it as a card to my AppleII
Basically, I have to develop the interface, so there is a chance that I will finish it by April 1st
Posted: Tue Mar 11, 2025 12:13 am
by gregorio
My simulator executes 65816 instructions in the shortest time of 250ns - longer about 500ns (does not emulate 65816 cycles exactly)
I want to get the fastest possible data transfer speed in DMA 1 byte per 1 6502 cycle, so if I send data to Apple2 RAM memory, then every few bytes I will have to perform one 6502 processor cycle to refresh its registers.
E.g. for 10us every 10 MVN or MVP instructions I will have to let the 6502 execute 1 cycle.
