Hello 0010 all,
They aren't doing differential signaling & all the GNDs are connected together at the ends, so there is no particular pairing of data lines & GNDs.
Well, actually it's not supposed to be a
Centronics "low speed printer cable", that's why I wrote (printer) in brackets, it's supposed to be a "real" parallel cable, DB25 male to DB25 male, with eight separate data return wires, intended to connect a PC's parallel I/O to a measuring device, of more than €1000.00, which has differential I/O.
Quote from a well known reliable source: [··] lines with differential receivers will reject noise regardless of whether the signal [source] is differential or single-ended, [··]
The supplier, Conrad, says "We don't know, but you can get a new cable." and that's exactly where it goes wrong again, the cable that came with the apparatus didn't work at all. They send me a replacement cable with the same result, just an other wrong (printer?) cable.
I even sent the apparatus, with clearly described complaint, back to Conrad for "repair", it returned with a message from Conrad "everything OK, works well", but it doesn't. I also got three different versions of software packages from them, but nope. Most probably they didn't bother to connect it to a PC, but only switched the device on and viewed the startup sequence, which then gives an "OK, ready" result.
According to the device manual it can be connected to a normal parallel port, but
I am pretty sure with sugar on top I need something with "twisted pair" data lines and, similar to a "Null-modem cable", some of the other lines "crossed". After I figured out which wires to be "crossed", I tried to make such a cable myself, so now I established at least some communication between PC and device, but as soon as I cut the end of a cable, the wires become a rat's nest that makes determining which (colour coded) wires are twisted pairs impossible, wires not paired correctly result in unstable/indecisive measuring results.
Still hoping for some advice to gain good result . . .
P.S.:
Conrad
sucks
