Which assembler could I possibly use ?
I have always written my programs for various SBC 6502 projects with Kowalski 6502 and then run the assembler and burn the ROMs.
Unfortunately Kowalski works worse and worse with wine, on my new Linux system it just hangs and crashes.
Which assembler would you recommend - possibly for Linux - if I have only used Kowalski 6502 so far?
Thank You.
Thank You.
Re: Which assembler could I possibly use ?
I very highly recommend the Macroassembler AS, also known as "ASL." It runs on both Unix (including Linux and MacOS) and Windows, is one of the more powerful assemblers out there, and is probably first in the world in terms of the number of CPUs it supports. It's also under active development.
For just 6502 development on either Windows or Unix it's as good as any other assembler, but because it supports both platforms and will assemble code for pretty much any 8- or 16-bit CPU (and some 32-bit CPUs) you might ever imagine using, it means you don't need to change assemblers when you start exploring new things.
- GARTHWILSON
- Forum Moderator
I have a list of 65xx assemblers on my site's links page, at http://wilsonminesco.com/links.html#assem . The quantity of them makes it impossible for any one person to be familiar with more than a small percentage of them, to be able to give a complete comparison; but at least you can go "shopping." I have written a few notes about my observations (from a distance) there. Unfortunately the one I myself use and like, Cross-32, does not seem to be available anymore, and I would like to find out who owns the rights to it, to ask if I can distribute it, just to keep a good thing going, not particularly to make any money at it.
- BigDumbDinosaur
Which version of Kowalski are you running?
I favour one which is buried in one of Garth's links (damn, we need to find more inventive names for 6502 assemblers!) - as65, http://www.kingswood-consulting.co.uk/assemblers/
- native linux executable
- NMOS and CMOS options
- Macro capability
- it uses 'traditional' syntax very similar to the Avocet assembler I used forty-odd years ago
A few more which get a mention in Acorn contexts but are not limited to Acorn environments:
https://github.com/stardot/beebasm (a very popular choice. There's a VS plugin which some find useful)
http://sun.hasenbraten.de/vasm/
https://github.com/SteveFosdick/laxasm
https://github.com/0xC0DE6502/max65-releases
BTW there's a curated list on this site's reference section (6502.org is more than the forum!)
http://6502.org/tools/asm/
Thank You.
Thank You.
If you're familiar with separate compilation, assembly and linking then this may work very well for you. The assembler produces a relocatable object file that you can link with other files to produce an object file in more or less the same way that other tools work under Unix - e.g. gcc (although the command-line options are similar but different).
I've been doing it this way since I got back into the 65xx some years back now. editor, Makefiles and ca65 ... It has useful macro facilities too and will generate code for NMOS, CMOS and '816 CPUs. (Or more precisely give you errors when you use an opcode not supported on your particular target). My largest project is a bytecode VM which assembles to 16KB and is split over 30+ source files to keep everything manageable. the whole thing assembles and links in under a second on my Linux desktop.
If you want to try and want example Makefiles, etc. let me know.
I should mention that I find linking assemblers to be more of a pain than useful for 8-bit work. (I started out with a linking assembler, ASxxxx/AS6502, when I started doing cross-development on Linux a few years back.) The source and object files for 8-bit machines are so small that they both, along with the listing file, fit into the L2 cache on my fifteen-year-old laptop, and the L1 cache on any modern machine, and assembly from scratch is possibly even faster than doing a partial assembly and then a link. So there's no speed advantage there.
What they do do, however, is limit your options for optimisation. This may or may not be a big deal, but if you are occasionally writing programs you want to be as small as possible, avoiding the overhead of the interfaces you need for linking can be helpful. (You need to use a linking system if you're doing part of your program in other languages, such as C, but if you're using C you've already thrown optimisation out the window, anyway.)
Thank You.
Thank You.
teamtempest
Macro capability
So far, my only grumble is that I can't find a way to force an absolute addressing mode when the operand address is on page zero, but it's not insurmountable. It also doesn't do relocatable modules, but I tend to write monolithic code so it's not an issue for me.
Macro capability
macro ABS_ADC ?expr
byte $6D
word ?expr
endmacro
Thanks for all your ideas and comments. The version of my Kowalski program is 1.2.11 - I saw somewhere that there is a newer version, but I don't think that's the problem. Using Wine with Kowalski is more the difficulty. I've already experimented with ca65, I don't have the documentation for some other assemblers. I'll have a look at your recommendations.
- BigDumbDinosaur
Visit here to download the most recent version of the Kowalski package. The current version is 1.4.0.6. You may have better luck with it in WINE.
EDIT: The current version is now 1.4.0.9.
Last edited by BigDumbDinosaur on Sun May 25, 2025 12:36 am, edited 1 time in total.
- Macro capability
you by chance would still have a copy of that assemble from avocet? or know where to get it. I am only hoping. thanks.
Ken
I wish I had, but it's over forty years since I last used it. As I recall, it was a cross-assembler running on CP/M.
