65C22 at 3V3 but with 5V inputs
Posted: Thu Oct 24, 2024 4:03 pm
It seems my understanding of input voltages of the 65C22 was not correct. I had falsely assumed that because the 65C22 can run at 5V or 3V3, then it could take either-or without issue.
For example, I thought I could run VCC at 3V3 and the inputs would accept 5V. But it seems I didn't "RTFM" close enough. LOL (no harm done, at least).
Instead, the maximum voltage is VCC + 0.3V.
If my board is mostly 3V3 but I want to interface to the outside world (via the two ports) at 5V, what is the best way to handle that? The 75LVC245 is common but I would have to set the direction and considering each pin of a port could be either input or output, I don't think that would work.
Should I just look into some bi-directional level converter and put between the ports and the headers?
