Page 1 of 5
PICO9918: A drop-in replacement for a TMS9918A (with source)
Posted: Mon Jun 10, 2024 1:22 am
by visrealm
Hi all,
I know a number of you are using (or planning to use) TMS9918A VDP in your homebrew projects (including myself). Thought I should share my new project: A drop-in replacement for the TMS9918A using a $4 Raspberry Pi Pico.
Here's a couple of videos showing it in action:
The hardware supports 12-bit VGA rather than Composite or YPrPb. Currently, I'm only implementing the original TMS9918A/TMS9929A, though I could certainly look into implementing some of the awesome F18A features in the future.
The PICO9918 is much easier to hook up than a TMS9918A since the VRAM and Clock is all handled in-house. I'm at an early stage hardware-wise where I'm using an off-the-shelf Pi Pico. I plan to incorporate the RP2040 directly in a future revision, further shrinking the package.
I've shared all the source code on GitHub: https://github.com/visrealm/pico9918
Re: PICO9918: A drop-in replacement for a TMS9918A (with sou
Posted: Mon Jun 10, 2024 5:27 am
by barnacle
Interesting, Troy.
Though I was unable to view the videos on Youtube; instead I got unskippable video game spam, and get-rich-quick spam in German, and nothing else. I had to use FreeTube to view the actual videos (which appear impressive though I'm not familiar with the capabilities of the chip itself).
Posted: Mon Jun 10, 2024 5:54 am
(Just to note, the youtube videos work for me)
Nice work Troy! The Pico is a great thing very suitable for retro projects.
Posted: Mon Jun 10, 2024 6:21 am
by visrealm
That's a shame (and completely out of my control).
They're genuine YouTube links - I don't get any ad money, or anything else from YouTube. If YT places unskippable ads on them, I can't change that unfortunately. :(
Glad you persisted though :)
Good to know. Thanks, Ed.
Posted: Mon Jun 10, 2024 8:13 am
by barnacle
Thanks Troy; not sure what happened there. It looked like YT replaced your videos entirely with spam videos instead... odd, because I have adblockers active when I use YT exactly to avoid that.
What I need to do now is find a convenient guide to bit tickling with the RP2040...
Posted: Mon Jun 10, 2024 9:50 am
There's an enormous datasheet but it's well written and well organised. It has a whole chapter on the PIO engines and twenty pages of examples
https://datasheets.raspberrypi.com/rp20 ... f#page=344
Edit: also a chapter in the SDK docs
https://datasheets.raspberrypi.com/pico ... df#page=31
There's the code for this project, of course
There are also other existing open source projects which interface with 8 bit busses, for example
https://github.com/oliverschmidt/a2pico
https://github.com/dp111/PicoTube
https://github.com/hoglet67/pico_bus6502
https://github.com/hoglet67/pico-swram
Dive into the code and have a look around at what's been done...
Posted: Mon Jun 10, 2024 12:07 pm
by barnacle
Thanks, ploughing through the 'getting started' docs.
I may be some time...
Neil :mrgreen:
Posted: Mon Jun 10, 2024 12:48 pm
Oh, for those who like videos, here's a playlist, seems sensible and well-paced:
Posted: Tue Jun 11, 2024 11:51 am
by visrealm
Had a number of people asking about 80 column mode too. So, I added that this evening:
https://www.youtube.com/watch?v=qdCapu0CVJ8
Posted: Tue Jun 11, 2024 5:10 pm
by barnacle
That PIO is looking very interesting... I think I need to get one of these. Or indeed, more than one, since I'm bound to break some.
But I fancy a graphics co-processor; spitting out 16-level greyscale at 640x480 VGA would appear to be easily within the bounds of possibility. Add a side order of 6800 bus and serial and PS/2 all in one part - there's a lot to recommend it.
Posted: Tue Jun 11, 2024 5:15 pm
by rwiker
Awesomer and awesomer!
The RP2040 really seems to be a versatile part (in the right hands... I have on two RPI picos, but haven't done anything with them).
Posted: Thu Jun 13, 2024 6:56 am
by visrealm
PIOs are great!
I'm using them for the VGA output, combined with DMA, so that's fairly hands-off (or CPUs-off perhaps?) once you set it going. Just need to provide it with a scanline of RGB data via an interrupt/callback whenever the PIO requests it.
I'm also using PIOs to generate the GROMCLK and CPUCLK output signals. These are just square waves at a set frequencies (~470KHz and ~3.4MHz). Once again, set up the PIO, tell it what to do and off it goes - set and forget.
I'm not using PIOs for BUS interactions. Here, I'm using a GPIO interrupt handler which is triggered when the READ or WRITE signals change. It (very quickly ~32 clock cycles max for a 4MHz bus) handles the request.
There are two CPU cores. One is pretty much twiddling its thumbs, waiting for interrupts from the VGA PIOs. The other is frantically generating scanlines.
100%
Posted: Sat Jun 15, 2024 4:46 pm
by barnacle
Pretty much the same as I had in mind. I'll order a couple up when I get back from this trip to Italy (take a 30-year old car from the UK to Turin via Berlin and meet up with some old friends)
Posted: Sat Jun 15, 2024 6:35 pm
by okwatts
Looking forward to seeing if this migrates to the Pico-56 (at least the software side) not sure if that is possible or in the plans. For those looking at the Pico there is active development using MMBasic (https://geoffg.net/picomitevga.html) that is fun in its own right as well as exposing the hardware interface (I2C,SPI, etc) to basic makes quick and easy interfaces without Python or C required.
Posted: Mon Jun 17, 2024 6:47 pm
by cbmeeks
visrealm wrote:
Hi all,
You sir, just made my decade. I've been doing a lot of VGA work with the Pico lately (well, been a few months).
https://github.com/cbmeeks/VgaPico
The primary goal for my VgaPico project was to have some sort of "drop in" video chip for homebrew computers. I always wanted it to lean towards the TMS9918 as that is a passion project of mine (https://github.com/cbmeeks/TMS9918).
Once I learned about the Pico and saw what it could do, I was convinced it's what I wanted to use. FPGA is just too hard for me and other micro-controllers seem to have too many hurdles (at least for me).
I will be watching this very closely.
