WDC Terbium IDE (Tide) with the W65C816
Posted: Sat Apr 06, 2024 6:15 pm
I have decided I am going to try and use Tide. Why? .... ... I ... don't ... let's move on*.
Just getting it to start and not constantly throw Failed to set data for 'version' errors every time options are changed is a bit of a mission. So I'm going to document my experience in this thread.
First off to fix the Failed to set data for 'version' error:
Right click on tide.exe in the .\WDC\Tools\bin directory and change Properties -> Compatibility to "Run this program in compatibility mode for: Windows XP (Service Pack 3)" and check "Run this program as an administrator."
I also have the following configured in "Edit System Environment Variables" under "System Variables" -> "Path"
C:\WDC\Tools\INCLUDE
C:\WDC\Tools\LIB
C:\WDC\Tools\BIN
and have additional "System Variables":
WDC_INC_6502 -> C:\WDC\Tools\INCLUDE
WDC_INC_65816 -> C:\WDC\Tools\INCLUDE
WDC_LIB -> C:\WDC\Tools\LIB
If your installation of WDC Tools is not in C:\WDC then you'll need to update the above to point to where you have installed them.
* I want to experiment with W65C816 programming and the C compiler that seems to generate the best '816 code is the WDC816CC compiler (when using the optimiser). Using the WDC C compiler from the command line getting to me so I thought. "Let me use their IDE instead". And now I'm here.
C:\WDC\Tools\LIB
C:\WDC\Tools\BIN
