24bit parallel colour data to HDMI
Posted: Thu Apr 13, 2023 1:08 pm
A bit of an out-of-interest or forward looking post on my part but... has anyone generated an HDMI video signal from a frame-buffer?
I currently have an 8bit:8bit:8bit set of RGB data that I convert to a VGA signal using a bunch of discrete counters and an ADV7125 3-by-8bit DAC. With VGA not being as common as it once was I started wondering: how hard would it be to generate an HDMI signal?
It seems like it's basically impossible in the hobby world.
Unless...
I can find an off-the-shelf part that I can clock my parallel data into at manageable frequencies (on the order of a 100Mhz) and that can then internally generate the GHz HDMI signal.
The ADV7513 seems to be perfect but is not available at Mouser anymore. Has anyone used the ADV7513 before or is there a similar component still available alternative? The datasheet for the '7513 is four useless pages but there is also the HARDWARE USER’S GUIDE that seems pretty complete.
I can still find '7513s at AliExpress but have had limited success with orders from them. Should I buy a couple and hope for the best? And is there a reference circuit or something that I can test one in?
Andrew
Unless...
Andrew
