VIA Ph2
Posted: Sat Feb 18, 2023 5:50 am
To create a reliable Ø2 for an external 6522 for a C64, Garth used the system Clock delayed 150nS.
http://6502.org/users/garth/projects.php?project=7
This seems pretty drastic to me. Looking at the timing diagrams (always risky to rely on), most VIA internal operations commence on the falling edge of Ø2 but some seem dependent on the rising edge, principally the timers, which are capable counting N+1.5 Cycles. Would delaying the rise of Ø2 affect those functions?
What about an opposite situation, in which VIA Ø2 rises before the processor clock does? As long as the address bits that generate CS and /CS, and the bits that select the VIAs registers are stable and settled, it shouldn't matter if Ø2 is early with respect to the cpu clock, right?
I ask because a design I've been working on (for what seems like forever!) for the VIC-20 has the possibility, under certain conditions, to cause VIA Ø2 to rise before the processor Clk, which will rise about 60nS later than normally. If I arrange for VIA Ø2 to rise slightly after the slightly later and shorter than normal cpu phase, that will create some minor, but not insoluble, difficulties elsewhere in the overall design, but my main concern is that the two shorter than normal Ø2s will have an affect on the serial I/O timings.
Any and all thoughts/opinions appreciated.
Thanks,
Richard
Thanks,
Richard
