Page 1 of 1
Problems with Microchess
Posted: Sat Dec 17, 2005 2:04 pm
by philpem
Hi,
I'm trying to modify Microchess (Daryl Rictor's modified version) to run from ROM on my 6502 board. RAM is 32Kbytes from $0000 to $7FFF, ROM is from $C000 to FFFF (16k).
I've changed both of the assembly origin (*=) directives so MC is based at $C000, and replaced the ACIA routines with dummy routines that just JSR to the monitor ROM. This was enough to get MC (mostly) running, but it seems to be getting stuck in a loop while it draws the board. Here's where it's getting stuck:
ADC #$08 ; point y to beginning of next row
TAY ;
CPY #$80 ; was that the last row?
BEQ POUT8 ; yes, print the LED values
; for some reason the beq pout8 never fires
BNE POUT1 ; no, do new row
Also, it seems the chess board isn't getting initialised. Do I need to do any initialisation before JMPing to $C000?
The monitor ROM doesn't touch X or Y, but all the UART comms routines clobber the accumulator and the flags. The code I've inserted into MC does a PHA, then the JSR, then a PLA and an RTS, so register clobbering shouldn't be an issue...
Has anyone got any suggestions? I was going to step through the code with my logic analyser, but I can't get a decent connection to the data bus (damn test clips)...
Thanks.
Posted: Sat Dec 17, 2005 5:33 pm
by 8BIT
Hi Phil,
I tested the code on my Simulator. Here is what I did:
I relabeled the *=$1000 to *=$9000 and *=$1500 to *=$9600.
I also modified the three calls to the system IO routines to match those of my Simulator:
syskin jmp $E821 ; Sim's get a key routine
syschout jmp $E824 ; Sim's chr ouput routine
syshexout jmp $E812 ; Sim's HEX byte output (Print1Byte)
these routines end with the RTS instructions so execution returns to the Microchess routine calling these adresses.
I then started the simulator and did a jump to $9000 and all worked fine. You have to type 'C' to clear the board and set up a new game. Then press 'P' to let the computer play the white move. You then enter your from & to locations followed by the <Enter> key. i.e. 6343<Enter>
I'm not sure why your program is stuck in a loop. Is your processor a WDC65C02, or is it another older one that might not be supporting the CMOS instructions????
Good luck!
Posted: Sat Dec 17, 2005 7:14 pm
by philpem
Hi Phil,
Hmm. Looks like I need to get my 65C02S inverse assembler (for my HP1651B logic analyser) working then...
Well, that explains why the board looked like.. well.. like two people had decided to play "House Rules Chess, Anything Goes Variation"
It's a WDC W65C02SP, running at 8MHz, with a GAL16V8 for address decoding. The UART card is a TI TL16C550, a Maxim quad linedriver (yes, all the handshaking pins work, except RI) and a GAL.
Thanks.
Posted: Sat Dec 17, 2005 8:00 pm
by philpem
Wait.. $1500? The version I've got (from 6502.org) uses $1580...
Posted: Sat Dec 17, 2005 9:28 pm
by 8BIT
Yes, you are right. I too am not using the IO routines included in the program as my SBC and Sim already have the IO routines. I had moved the $1580 block down to $1500 to reduce the gap caused be the removed code.
Posted: Sat Dec 17, 2005 10:37 pm
by philpem
Why bother with the *=$1500 at all? Why not just leave the data chunk to follow on from the code?
In any case, I've got it mostly working now. It displays a perfectly sane chess board, then when I press "C", it redraws the white side fine. When it gets to the black side, it gives me this output:
| |**| |**| |**| |**|50
|BP|BP|B|B|B-------------------------
... followed by a BELL from the terminal (usually only output when it receives an ASCII "BEL" character, #$07 iirc)
If I reset the 6502, I get the slightly more sane:
|**|WC|**| |**|BP|**| |60
|B|**| |**| |WP| |**|70
00 01 02 03 04 05 06 07
4A 79 4E
Which includes the "LED" display, but still looks mad...
I'm now using a raw copy of the code from
http://home.surewest.net/dnh/downloads.html, with the SYSHEXOUT routine from the 6502.org version.
Thanks.
Posted: Sat Dec 17, 2005 11:09 pm
by philpem
Oh, I'm such an idiot...
; BLOCK DATA
*= $C500
SETW .byte $03, $04, $00, $07, $02, $05, $01, $06
That *= was making my assembler trample all over the last few bytes of the lookup table that stored the chess piece characters ("WP", "WC" and so forth). Moving the *= up to C600 fixed the bug. It wastes about 250 bytes of code, but at least MC works now
Now to try and remember how to play chess, and maybe build up that M/IO board I've been promising myself. IDE hard drive, 3.5" floppy, realtime clock and LCD interface, all on one board. Very cool
Thanks.
Posted: Sun Dec 18, 2005 5:01 am
by 8BIT
Phil,
Glad to see you found the trouble. You are right, you probably don't even need that *=..... hind sight....
Good luck with the I/O board. I'm 80% done with a Fat16 compatible file system driver for IDE HD and CF cards... and 50% done with the Ethernet driver...
To quote Mr Scott,... " I need for time captain!"
Merry Christmas to all!!!!
