Safe to Use PC Power Supply With KIM-1 Board ?
Posted: Fri Dec 09, 2005 12:18 am
Well, I'll just apologize now for being a newbie ... And for a long post ...
Would it be safe, in general, to try to use a salvaged PC power supply
to power a KIM-1 board ?
I rediscovered a KIM-1 recently (got it at a garage sale some time ago,
in a box with other stuff), stumbled onto some KIM site or another
probably Vern Garner's www.KIM-1.com, did't see an easy way to leave
a query there). While browsing around there, I realized all of the
sudden, that the board I had could (and was intended) to be actually
used, to some extent, just sitting alone on the desk, with an external
power supply! I guess I'd figured that with the edge connectors on it, it
was intended to be used with some sort of bus and/or chassis, which I
don't have, of course.
Which leads me to my question, basically, what's useful, comtemporarily
available, to power a KIM-1 board? I got a copy of the User's Manual,
used the A-Connector as stated to wire up +5V/Gnd from my DD-1
breadboard kit.
Unfortunately, I subsequently realized that although the DD-1 power
shows about +5.15V with no load, when connected to the KIM-1, it
drops to 4.3V.
Following the instructions in the "KIM-1 User Manual" and "KIM Hints"
pamphlet ... On pressing the RS key, the LED's flashed, but then when
attempting to enter the "simple program" (User Man 2.4), nothing
actually shows up on the LED's ...
Wondering if my power is just too low? Continuing to follow the
troubleshooting steps ... Between A-A and A-1, there's 4.11V, btw
E-21/E-22 is 3.97V, E-21/A-K is 4.11V ... Watching voltage btw
E-7/E-21 while pressing the RS button, goes from 0.01V to 3.96V ...
So, that's about where I'm at so far ... I'd like to try to use what I've
got lying around to make sure the KIM-1 board works at all, before I
even consider trying to breadboard up a power supply like the one
shown in the User Manual ...
Finally, direct questions ... How sensitive IS the KIM-1 to voltage
specs? It specifies +5V ±5%, obviously I'm below that ...
I have a number of old PC power supplies available (pack-rats of the
world unite!), but I'm cautious about those because they specify
around 22A (!) for the +5V line. The "KIM Hint" doc mentions specs
of 1.2A at +5V, and measurements between 700mA to 1A.
Also, I've read that PC supplies, while very well-regulated and stable
under normal use in a PC, get less so with a significantly smaller load
(like trying to use one for a hobby station, playing with gates and such
stuff) ... Only thing I've really done there, is put a VOM on one, and
watch it stay pretty stable, as far as I could tell, at 5.37V, and also with
and old drive attached, at 5.2V ... I've forgotten most of whatever I
once thought I knew about electronics, not really sure how to evaluate
this situation ...
Although I did search out one post which said that it was OK to use an
old PC power supply, as long as you put another load on it, such as an
old CD-ROM drive.
That one's here:
http://www.classiccmp.org/pipermail/cct ... 09486.html
But I didn't want to subscribe to a newslist just to ask the question...
This forum seemed somewhat recently active, so I thought I'd give it a
shot ... If anyone has any advice, please reply, or if I guess you could
email me at MinstrelMike@Yahoo.com if you wanted to go external.
I'll probably be impatient if I don't see a useful reply soon, and just try
out the PC power supply... Of course, then I'll reply here myself and
post the results, and of course, more questions if it doesn't work out.
Most likely, my attention-span will time-out on it within a few days
anyway ...
Well, if anyone's read the whole thing, THANKS!
Mike
PS: Maybe should have posted to the Hardware forum?
breadboard kit.
drops to 4.3V.
this situation ...
old CD-ROM drive.
That one's here:
anyway ...
Mike
