Page 1 of 1
Atmel Porgammer upload software
Posted: Thu Nov 03, 2022 10:52 am
by A0CBM
I purchased a program platform from Atmel and would like to find out if there are any open source programs to upload to the programmer. I have WinCUPL and wanted to see how the ATF1504AS works, but I can't upload my PLD file to the programmer. Am I at the mercy of Atmel or is there an alternative? I have an ATDH1150USB-K Download platform. I found something on NuMicro ISP Progamming Tool, but I don't know if that works with my setup. Thank you.
Re: Atmel Porgammer upload software
Posted: Thu Nov 03, 2022 3:36 pm
by 8BIT
I'm not absolutely sure about this, but it looks like you need to download the ATMISP software to program the device using that cable. here's a link to a PDF I found on the cable which has a link to the software in it.
https://ww1.microchip.com/downloads/en/ ... rGuide.pdf
My guess is you compile your logic using WINCUPL and then you would select the .JED output file within the ATMISP software to program the device.
best wishes!
Posted: Thu Nov 03, 2022 7:07 pm
What Daryl said.
- Write and compile your logic with WinCUPL.
- Test your logic with WinSIM.
- Program your device with ATMISP.
Within ATMISP, you will need to set up a programming “chain” for the ATF1504AS. Just follow the prompts.
