Page 1 of 1
Snakes on the DANI-I 6502 SBC
Posted: Fri Jul 22, 2022 7:44 pm
by ChaseHQ85
Now that I have my cc65 fork really fleshed out, I had whip up a version of snakes for it!
https://www.youtube.com/watch?v=mg-rPlhPPvs
https://github.com/ChaseHQ/DANI-I-Snakes
Re: Snakes on the DANI-I 6502 SBC
Posted: Fri Jul 22, 2022 8:07 pm
by Proxy
i would still very much recommend putting everything related to a project in a single repository, for the same reasons as mentioned before.
but besdies that, that's a pretty neat looking clone. as an extra challenge, try to have the body of the snake smaller than 1 whole tile. so that when the snake is next to itself the body parts don't blend together.
Posted: Fri Jul 22, 2022 8:13 pm
by ChaseHQ85
Proxy wrote:
i would still heavily recommend putting everything related to that project in a single repository, for the same reasons mentioned before.
I get what you're saying but they truly are separate projects. CC65 is a fork so it has to stand on it's own so I can pull off the main for updates. As for the rest I personally just prefer (especially when im at work) pulling one project, working on it and pushing and not taking the entire tree with me. I understand your position but I think for my workstyle keeping it separate helps me organize as well as be productive.
Posted: Fri Jul 22, 2022 8:34 pm
by Proxy
hmm, that is honestly the first time i've heard of a worksytle like that. especially with github which is designed to allow for incremental updates to repos. oh well whatever works i guess.
just note that it will likely only be convenient to you and not to others who might want to follow the project.
also, sorry but i'm still a bit confused, what exactly do you need a fork of cc65 for? AFAIK you usually fork projects to modify their source code, but in this case you just want a custom target for it. so why not just download the pre-compiled binaries and follow their official tutorial? https://cc65.github.io/doc/customizing.html
i did the same with my own 65c02 SBC, i got a folder for cc65 programs that also contains a config folder with the crt0.s file, C standard library, and the .cfg file for my hardware. all according to that page.
Posted: Fri Jul 22, 2022 8:42 pm
by ChaseHQ85
With a fork and their already built Makefiles its incredibly easy to add your own target. Dave Plummer did something similar with his KIM-I. Having all the source at hand in say VSCode gives you a very nice environment for working off already working source as well.
Posted: Fri Jul 22, 2022 8:45 pm
by Proxy
oh i see.
Make is a pain to get working on Windows, so using the pre-compiled binaries was more convenient for me.
anyways my little extra challange for your snake program still stands if you want to try it.
Posted: Fri Jul 22, 2022 9:31 pm
by tmr4
Microsoft's NMake is fairly easy to set up for Windows. It's not as powerful or versatile as Make, but it gets the job done for me.
Posted: Mon Jul 25, 2022 10:18 pm
by ChaseHQ85
I've been running VSCode under WSL 2 - It uses Linux as the backend to compile the code, so Make is easily and readily available. - You could also just install Cygwin and it should work.
