Replication of B128 – CBMII series
Posted: Tue Jun 07, 2022 3:28 am
Hey, I would like to know, has anyone ever replicated any of the old Commodore B128 computers (the ones utilizing the 6509 processors)?
Yes, I found multiple replications for the Commodore Pet.
Even here, I saw the Micro-PET (http://www.6502.org/users/andre/petindex/boards.html)
I suppose, I could also use another alternative https://www.glensstuff.com/pet2001/pet2001.htm , follow closely the overall design and modify the architecture as to implement the quirky bank switching of the mos 6509 processor.
My goal, was to achieve software compatibility for the B128.
Yeah, originally, I was lucky enough to acquire at B128-80 (CBM 710). http://www.zimmers.net/cbmpics/cb4s.html
As stated from the seller from eBay, "all it needs, are replacement rom chips." Turns out, computer booted up, without doing a memory check. When I did a simple test to print text, it displayed gibberish. And the built-in display eventual died after being on for a few minutes. Eventually, I discovered a number of ICs suffered the fate of corrosion from numerous pins due to age.
Having discovered, that a number of local Computer repair shops, would not touch
a vintage 8-bit computer, I took the journey of learning on how to de-solder and re-solder components. Unfortunately, alone the way, I’ve learned on what not to do. Eventually, learned the proper way to solder. However, the in mist of the activity, apparently, I reached the point of, no recover
, since some where down the line, I got short between +5v line and a ground. (While looking through magnifying glass, I couldn't find any obvious signs of any solder beads, touching any adjacent points.)
When, since it is really extremely rare to come across spare mother board for the CBMII series, I am wondering if anyone ever attempted to reproducing PCB board, based upon existing schematics? http://www.zimmers.net/anonftp/pub/cbm/ ... index.html
Though, I’m really not sure, if there was an attempt by Ruud Baltissen, to design a new CBM-II using modern ICs like CPLDs and may be even FPGAs. But I can’t seem to find anywhere if he was successful or not.
I sure would hate, being a newbie, to attempt this effort from scratch.
Thoughts??
Thoughts??
