Page 1 of 2
Acorn Atom PCB
Posted: Mon Jan 31, 2022 10:41 pm
by GrubZero
Hi All.
I have an genuine, unused & unpopulated Acorn Atom PCB that maybe of interest to someone who wants to document the design & / or copy it & get some replica PCB’s made.
I’d be happy to loan the board to someone who wants to do this as long as they cover the postage.
Or, I may consider selling it?
I acquired it many moons ago with the intent of building an Atom from scratch, but, like many things, I never found the time!
Cheers.
Pete.
Re: Acorn Atom PCB
Posted: Tue Feb 01, 2022 8:13 am
(If it happens that you don't get any interest here, after say a week, you might well find more interest over on the Stardot forums. There's a small but active Atom scene over there.)
Re: Acorn Atom PCB
Posted: Tue Feb 01, 2022 7:05 pm
by Windfall
I did. Great fun. Although rounding up all the different parts (all NOS as a matter of principle) was cumbersome.
I probably got the PCB the same way you did.
Re: Acorn Atom PCB
Posted: Wed Feb 02, 2022 8:25 pm
by GrubZero
I probably did!
If I remember correctly, I purchased two PCB’s from a company called Telec Electronics based in the Netherlands.
I think I ordered they’re last two units?!
I wonder where they got them from?
Cheers.
Re: Acorn Atom PCB
Posted: Thu Feb 03, 2022 1:52 am
by Windfall
Same here. Ebay, March 2010, it seems.
From kits that were never built, I suppose. The Atom was my first computer, and at the time they came as a kit or ready built (mine was the latter).
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 1:09 am
by fletch
Hi Pete,
I sent you a PM. I am working on a redraw of the Atom PCB and would be interested in scans or the board itself.
Fletch
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 4:37 am
by Arlet
Ha, I remember building the kit as a teenager, together with my dad. It didn't work, and we didn't know how to fix it, so it sat idly in the bookcase for some time. At some point I remember him shipping it, and getting it repaired.
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 5:59 am
by fletch
I was saving up for a kit back in 1980 so I've always wanted to build one.
I found some scans of the Atom PCB on the net and have been trying to reproduce the PCB. However, the scans just aren't clear enough and I made a lot of mistakes that I had to correct by hand.
I am having problems getting the prototype working and I still don't know if the problem is a board fault, dodgy components or a construction fault. Having access to a better quality scan or an original board would help.
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 6:26 am
by barnacle
I think that the latest version 7 of kicad has a mode in which an image can be used as a template for a PCB layout. At least you'd start with the chips in the right place.
Are you looking to do an exact recreation or e.g. something with modern memory?
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 7:26 am
by fletch
The plan is to create a reproduction board along the lines of the OSIwebs Superboard II PCBs. I'm trying to duplicate the original layout using a program called Sprint-Layout. This will allow someone with the right chips to make a replica Atom just as if they had ordered a board back in 1980. Once that is done I may make another version that uses modern EPROMs and Cherry keyswitches.
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 7:51 am
(Welcome, fletch!)
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 8:38 am
by rwiker
Are the original Atom keyswitches available anywhere? I have two Atoms with a few broken switches each (and most likely some other problems).
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 2:35 pm
by fletch
Which issue of the board do you have? Issue 5 boards use Futaba switches like the BBC Micro and those are still available NOS.
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 2:49 pm
by rwiker
I believe the two I have use the earlier switches: https://deskthority.net/wiki/MEI_Sabrecoil
Re: Acorn Atom PCB
Posted: Tue Apr 18, 2023 8:32 pm
by fletch
I wonder if you can 3D print those?
