Page 1 of 1
Programming 6530
Posted: Sat Aug 27, 2005 6:12 pm
by asmlang_6
How can I program the ROM of a MOS 6530?
Posted: Sun Aug 28, 2005 3:47 am
by 8BIT
I downloaded the 6530 datasheet from the 6502 datasheet archive. As I thought, the ROM is mask programmed. That means it was programmed during manufacturing and cannot be reprogrammed. There are a few other options that were mask programmed also. You might want to look over the datasheet for all of the specifics. Here is the link:
http://www.6502.org/documents/datasheet ... 0_riot.pdf
hope this helps!
Re: Programming 6530
Posted: Thu Sep 01, 2005 10:46 am
by Ruud
As 8bit said, the ROM is programmed during production. This site:
http://www.baltissen.org/htm/buildkim.htm tells you how to reproduce a Commodore KIM using normal available IC's. In this case a 6530 can be replaced by a 6532 and an EPROM.
