How to get the VICE compatible symbol file from VASM?
Posted: Tue Nov 30, 2021 4:16 am
I am using the VASM assembler with the VICE emulator. I have tried to find the answer to my problem on other forums (https://www.lemon64.com/forum/viewtopic ... 70&start=0) and to figure out that on my own without any succes so far...
I have found that other assemblers, e.g. 64tass has a nice feature when executed with switch --vice-labels. It generates file with labels and breakpoints that could be loaded by VICE and used in the monitor when started with the -moncommands switch. KickAssembler has a similar function (I have never tried it, but it is described in the manual).
Does anyone know if VASM can do it also? The only thing I found is the -L <listfile> switch, which generates a file with many parameters, which could theoretically be post-processed into a format that VICE would understand. There is no other option? Anyone using VASM?
Links
* 64tass: http://tass64.sourceforge.net/
* KickAssembler: http://www.theweb.dk/KickAssembler/KickAssembler.pdf
* VASM: http://sun.hasenbraten.de/vasm/release/vasm.pdf
Links
