Page 1 of 2
ACIA Works for 65c02, not for 65c816 with same settings?
Posted: Sun Sep 19, 2021 3:01 pm
by Jmstein7
I've been tinkering and testing with my ACIAs (65c51 and LIV2's RTL equivalent) all week, when I had time. The issue is that, when I connect my 65c02 with a 4mhz or 6mhz clock, along with a 1.8432hmz connected to the ACIA, RTL or physical, it works just fine, no problem. However, when I swap out the 65c02 for a 65c816, I run into trouble.
I tested the setup with the VIO (effectively a logic analyzer I can single-step) on my Xilinx CMOD A7, and I've confirmed that the 65c816 itself, along with its ram and rom, work just fine. But the output from the ACIA is garbled. Some of it is correct, some isn't. The output looks fine, then it staggers and skips or prints garbage, then returns to printing what it is supposed to. I've tried with both an RTL ACIA and the real, physical ACIA (at 5V after a logic level shifter), and the result is the same.
Now, I know on the timing on the RAM is effected by the duplexed data lines. Is the ACIA?
I'm at my wit's end here.
Jonathan
PS If you have a CMOD A7 35T and a 65c816, my code is here:
https://github.com/jmstein7/65c02-FPGA- ... bench.srcs
Re: ACIA Works for 65c02, not for 65c816 with same settings?
Posted: Sun Sep 19, 2021 3:18 pm
by Dr Jefyll
I would start by upgrading your use of supply bypass capacitors, reconsidering how many are present and the manner in which they're connected. Due to its multiplexed data bus the '816 can generate a lot more supply noise than the '02 or 'C02, and supply noise is a plausible cause of intermittent failures such as the ones you describe.
For anyone who's interested,
this thread details some
extremely
unlikely-seeming symptoms which were eventually explained by inadequate '816 supply bypassing.
Posted: Sun Sep 19, 2021 3:27 pm
by Jmstein7
I would start by upgrading your use of supply bypass capacitors, reconsidering how many are present and the manner in which they're connected. Due to its multiplexed data bus the '816 can generate a lot more supply noise than the '02 or 'C02, and supply noise is a likely cause of intermittent failures such as the ones you describe.
extremely
I'll check that out! I just don't know how many more caps I can add, or where.
Posted: Sun Sep 19, 2021 4:52 pm
by Dr Jefyll
You've started a new thread without linking to what went before. Is
this the project you're talking about? And are those photos still up to date?
Also, nice if you can post a schematic, please -- here, I mean, rather than off-site. Cheers,
Posted: Sun Sep 19, 2021 5:14 pm
by Jmstein7
I had to modify that because I just could not get the outputs to work at all. Now, I have everything going, but for the ACIA
Posted: Sun Sep 19, 2021 5:51 pm
by Dr Jefyll
Is this the project you're talking about? And are those photos still up to date?
Arghh! You didn't answer the question I posted, and I'm still in the dark.
So, do you still want some help with "my ACIAs (65c51 and LIV2's RTL equivalent)", then? Whatever that is.
It's confusing trying to guess what you're up to, so please help us out by sharing the details! So far all I know for sure is, you have some sort of project and you swapped out an '02 for an '816. Based on that alone I've made an educated guess. But if you want help upgrading the bypass caps, or any other kind of help, please please tell us what you're doing! Photos & a schematic, too, please.
Posted: Sun Sep 19, 2021 6:00 pm
by Jmstein7
Arghh! So, do you still want some help with "my ACIAs (65c51 and LIV2's RTL equivalent)", then? Whatever that is.
I've made an educated guess based on that alone. But if you want help upgrading the bypass caps, or any other kind of help, please please tell us what you're doing! Photos & a schematic, too, please.
LOL, yes and yes!
I'm going to just draw it out and take a pic. What kind of pic files can we attach to posts? JPG? I want to keep it on-site.
Posted: Sun Sep 19, 2021 6:23 pm
by Jmstein7
Okay, this is the best I can do - I am an awful artist
Connections:
https://photos.google.com/u/2/share/AF1 ... RMZmxFOERn
Picture:
The pics show the caps - except that the oscillator has it on the bottom.
Jonathan
And, code:
Posted: Sun Sep 19, 2021 6:26 pm
It would be quite helpful if you would attach things such as code and schematics to your posts instead of making readers go off-site to see such material. I'd like to help but I don't do Github or Google.
Posted: Sun Sep 19, 2021 6:28 pm
I would start by upgrading your use of supply bypass capacitors...
Also, a FULL schematic would be a BIG help. You can't expect anyone to troubleshoot a circuit if they haven't a clue about how it's hooked up.
Posted: Sun Sep 19, 2021 6:34 pm
by Jmstein7
How's this? I'm pretty new to this, still, and my fine motor skills
stink
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 09/17/2021 03:16:14 PM
// Design Name:
// Module Name: top
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module top(
input logic clk,
input logic acia_clk,
input logic e_bit,
input logic vpa,
input logic vda,
input logic reset,
input logic rwb,
input logic [15:0] ab,
inout logic [7:0] db,
output logic phi2,
output logic nmib,
output logic irqb,
output logic resb,
//mode_2
//inout logic [7:0] data,
//output logic acia_e,
//sram IO
inout wire [7:0] dio_a,
output reg [15:0] ad,
output reg oe_n,
output reg we_n,
output reg ce_a_n,
//ACIA IO
output wire rts,
output wire tx,
input wire rx,
input wire cts
logic [7:0] bank;
logic bank_enable;
logic db_enable;
logic rom_enable;
logic ram_enable;
logic [7:0] data_w;
logic [7:0] data_r;
logic [7:0] read_data;
logic [15:0] address;
logic [7:0] rom_out;
logic mrd_n, mrw_n;
logic [7:0] ram_in;
logic [7:0] ram_out;
logic [7:0] acia_in;
logic [7:0] acia_out;
logic acia_irq;
//fixed
assign bank_enable = (~phi2) ? 1'b1 : 1'b0;
assign db_enable = (~phi2) ? 1'b0 : 1'b1;
assign mrw_enable = (phi2) ? 1'b1 : 1'b0;
assign data_rw = (rwb) ? 1'b1 : 1'b0;
assign address = ab;
assign rom_enable = (address >= 16'hC000) ? 1'b1 : 1'b0;
assign ram_enable = (address < 16'h8000) ? 1'b1 : 1'b0;
assign acia_enable = (address >= 16'h8000 && address < 16'h8010) ? 1'b1 : 1'b0;
//mode_2
//assign acia_e = ~acia_enable;
//mrd and mrw signals
assign mwr_n = (mrw_enable && ~rwb) ? 1'b0 : 1'b1;
assign mrd_n = (mrw_enable && rwb) ? 1'b0 : 1'b1;
//bank address latch
always_latch begin
if (bank_enable) begin
bank = db;
end
//No else clause so a_latch's value
//is not always defined, so it holds its value
end
/* base model
assign db = (db_enable) ? (rwb ? read_data : 'bz): 'bZ,
data_w = (db_enable) ? (~rwb ? db : 'bZ) : 'bZ,
resb = ~reset,
irqb = 1,
nmib = 1;
assign db = (db_enable) ? (rwb ? (rom_enable ? rom_out : (ram_enable ? ram_out : (acia_enable ? acia_out : 'bZ))) : 'bZ) : 'bZ,
resb = ~reset,
irqb = 1,
nmib = 1;
assign ram_in = (ram_enable && ~rwb) ? data_w : 'bZ;
assign acia_in = (acia_enable && ~rwb) ? data_w : 'bZ;
//mode_2
assign data = (data_rw) ? 'bZ : acia_in;
assign acia_out = (data_rw) ? data : 'bZ;
ACIA acia_a(
.RESET(resb),
.PHI2(phi2),
.CS(acia_e),
.RWN(rwb),
.RS(address),
.DATAIN(acia_in),
.DATAOUT(acia_out),
.XTLI(acia_clk),
.RTSB(rts),
.CTSB(cts),
.DTRB(),
.RXD(rx),
.TXD(tx),
.IRQn(1'b1)
sram_ctrl5 ram_0(
.clk(phi2),
.rw(rwb),
.wr_n(mwr_n),
.rd_n(mrd_n),
.ram_e(ram_enable),
.address_input(address),
.data_f2s(ram_in),
.data_s2f(ram_out),
.address_to_sram_output(ad),
.we_to_sram_output(we_n),
.oe_to_sram_output(oe_n),
.ce_to_sram_output(ce_a_n),
.data_from_to_sram_input_output(dio_a)
dist_mem_gen_0 rom_0(
.a(address),
.spo(rom_out)
//Clock Divider
clk_wiz_0 clock_a(
// Clock out ports
.phi2(phi2),
// Status and control signals
.reset(reset),
.locked(),
// Clock in ports
.clk(clk)
//fixed
vio_0 debug_core(
.clk(clk),
.probe_in0(ab),
.probe_in1(db),
.probe_in2(rwb),
.probe_in3(acia_e),
.probe_in4(vda),
.probe_in5(vpa),
.probe_in6(reset),
.probe_in7(bank),
.probe_in8(data_w),
.probe_in9(data),
.probe_out0(phi2)
endmodule
Posted: Sun Sep 19, 2021 8:25 pm
by Dr Jefyll
I'm willing to believe you're trying, but you need to try harder. For example your schematic shows an ACIA but the photo shows none, or even a possible site for one. What's the explanation?? And can we see the underside of that board, please?
Going back to general principles, I hope you know the 816's pinout doesn't entirely match that of the 'C02. So, your remark in the lead post about swapping out the 65c02 for a 65c816 leaves me wondering. Are there some jumpers you adjust when you make the swap?
Regarding the HDL code you posted: does your FPGA float the data bus to high impedance when Phi2 is low? The '816 requires this, but the '02 does not.
Posted: Sun Sep 19, 2021 8:30 pm
by Jmstein7
Regarding the HDL code you posted: does your FPGA put the data bus to high impedance when Phi2 is low? The '816 requires this, but the '02 does not.
That is the clock for the ACIA. The ACIA is a "soft" RTL core, written by LIV2. That clock is used exclusively by said ACIA.
Posted: Sun Sep 19, 2021 8:36 pm
by Jmstein7
The main "glitch" right now is that the ACIA seems to clip the first letter or two of each line of text. It also isn't doing the LFs or CRs in the correct places (e.g., at the end of said lines). Otherwise, the text is clear. Of course, RX doesn't work at all, and I can't type anything in. Finally, after printing the text, it hangs.
Posted: Sun Sep 19, 2021 8:38 pm
by Dr Jefyll
In the lead post you said, "I've been tinkering and testing with my ACIAs (65c51 and LIV2's RTL equivalent)," which sounds as if you meant a real, physical 65c51 as well as the soft core.
Edit: I see you've posted again, but my advice remains the same. Please consider what I said about the '816 needing its data bus NOT to be driven during Phi2 low, as ignoring this detail would cause supply noise which might be the cause of your trouble. I have no further advice to offer at this time -- gonna shut down the screens and get out into the sunshine.
