Page 1 of 2
short binary to hex char using bcd mode
Posted: Fri Apr 16, 2021 8:03 pm
by fachat
That is probably old news here but I didn't know and found it clever use of BCD mode.
https://twitter.com/adumont/status/1381 ... 02785?s=19
clc
sed
adc #$90
adc #$40
cld
The code is brilliant. For 0-9 the first step gets $90 to $99, which are the uppermost values BCD can represent in a byte.
For 10-15 this gets, through the overflow, then $00 to $05, plus carry.
Adding $40 in the second step results in $30-$39 and $41-$46 (due to the carry).
There is no branch but sed and cld add cycles. Still have to compare with a classic conversion.
But nevertheless clever code.
André
Re: short binary to hex char using bcd mode
Posted: Sat Apr 17, 2021 6:29 am
That algorithm has been around for decades. When I wrote Supermon 816 I considered that method, as well as the following, which I first encountered back in the late 1970s:
.0000010 cmp #10       (2)
         bcc .0000020  (2, 3 or 4*)
         adc #'f'      (2)
.0000020 eor #'0'      (2)
*6502/65C02 only if branching over a page boundary
The numbers in parentheses are Ø2 cycles. The total for the above would require 8 cycles, worst case. It would run slightly faster on the 65C816 in native mode, 7 cycles, best case.
In contrast, the other algorithm:
         sed       (2)
         clc       (2)
         adc #$90  (2 or 3*)
         adc #$40  (2 or 3*)
         cld       (2)
*3 cycles if a 65C02
The above would take a constant 10 cycles on an NMOS part or 65C816, or 12 cycles on a 65C02.
In both cases, it is assumed the nybble to be converted is in .A in the least-significant-nybble position.
EDIT: Fixed my cycle counting. :D
Posted: Sat Apr 17, 2021 6:34 am
by BillG
That technique is as old as dirt. This was used in at least two places within the DDT debugger of CP/M-80:
 04E9 C6 90           [7] 00350         adi     90h
 04EB 27              [4] 00351         daa
 04EC CE 40           [7] 00352         aci     40h
 04EE 27              [4] 00353         daa
The 6502 version:
 0200 18              [2] 00003          clc
 0201 F8              [2] 00004          sed
 0202 69 90           [2] 00005          adc    #$90
 0204 69 40           [2] 00006          adc    #$40
 0206 D8              [2] 00007          cld
The brute force version:
 0207 18              [2] 00009          clc
 0208 69 30           [2] 00010          adc    #'0'
 020A C9 3A           [2] 00011          cmp    #'9'+1
 020C 90 02 (0210)  [2/3] 00012          blo    2f
                          00013
 020E 69 06           [2] 00014          adc    #'A'-'0'-10-1
                          00015
 0210                     00016 2
The "clever" method is one cycle faster for 0..9 and two bytes smaller.
The fastest way on the 6502 at the expense of more bytes is:
 0210 AA              [2] 00018          tax
 0211 BD 0214       [4/5] 00019          lda    Hexits,X
                          00020
                          00021 ;
                          00022 ;
                          00023 ;
                          00024
 0214 3031323334353637    00025 Hexits   db     '0123456789ABCDEF'
 021C 3839414243444546
The 8080 and 6800 cannot do that...
Posted: Sat Apr 17, 2021 6:37 am
by BillG
         adc #'f'      (2)
The numbers in parentheses are Ø2 cycles. The total for the above on a 6502/65C02, worst case, would be 10 cycles, or 8 cycles, best case. On the 65C816 in native mode, worst case would be 9 cycles, or 8-cycles, best case.
Ooh, that is good. I have never seen that before...
Posted: Sat Apr 17, 2021 7:08 am
BillG wrote:
The 6502 version:
Decimal addition on the 65C02 of an immediate mode operand costs 3 cycles, not 2. So there is a performance hit if using the 'C02. In a single conversion, it's no big deal. However, if dumping a page of memory to the screen, there would be 512 conversions for the data, plus 64 conversions for the addresses associated with the data, assuming 16 bytes dumped per line. Total cycle consumption for conversion with the 'C02 would be 6912. In contrast, it would be 5760 with an NMOS 6502 or the 65C816 running in native mode. The numbers, of course, don't include the overhead of JSR and RTS, or the shifting and masking required to extract a nybble from a byte.
That said, the branch-and-add algorithm I illustrated is generally faster on the 65C816, since that MPU doesn't incur a cycle penalty when branching across a page boundary (one of the sneaky benefits of having a 16-bit ALU). Also, there is one less instruction to execute, for an automatic 2 cycle saving.
Posted: Sat Apr 17, 2021 7:24 am
by BillG
From https://twitter.com/LIV2/status/1381885385085755392
who got it from http://www.6502.org/tutorials/decimal_mode.html#6
 0224 F8              [2] 00027          sed
 0225 C9 0A           [2] 00028          cmp    #10
 0227 69 30           [2] 00029          adc    #'0'
 0229 D8              [2] 00030          cld
Posted: Sat Apr 17, 2021 7:50 am
Funny how the stuff posted here finds its way to other places, where it is then occasionally claimed to be original thinking. :D Virtually every 6502 algorithm I've seen posted here or elsewhere was known at least 40 years ago.
Again, addition (and subtraction) in decimal mode on a 65C02 costs an extra cycle, ergo the ADC #'0' is a 3-cycle instruction, not 2. So the total cycle consumption of the above with the 'C02 would be 9 cycles. Ironically, it would be faster on the NMOS processor.
Posted: Sat Apr 17, 2021 8:14 am
Or we could be happy that people are discovering and sharing knowledge about programming the 6502.
Posted: Sat Apr 17, 2021 9:03 am
Keep 'em coming! There are occasionally still ones that are new to me, after 40 years of this. It reminds me of something a boss I had 30 years ago said, which was that in the early days of programmable calculators when memory was very limited, they'd have contests to see how short of a program people could come up with to do a certain job; and just when they thought they had absolutely the shortest possible program, in came someone with one that was only half as long, and by that time it was hard to tell why it even worked at all.
Posted: Sat Apr 17, 2021 6:31 pm
by drogon
I like reading these sorts of threads - mostly because it highlights my old saying of ask 10 programmers, get 11 answers...
It also demonstrates just how varied our world is with different people coming up with different ideas and styles - for different reasons....
My own coding style is often somewhat verbose and easy to read - and that's intentional. Until I'm really pressed for space I tend to not code for space efficiency (or even speed - until I really need it) so my preferred hex print code looks like:
; oHex4: oHex8:
;       Output the A register as 1 or 2 hex digits
;       Preserves X, Y, A has last character printed.
_oHex8:
        pha                     ; Temp. save
        lsr     a               ; A := A >> 4
        lsr     a
        lsr     a
        lsr     a
        jsr     _oHex4          ; Print top 4 bits as hex
        pla                     ; Restore A and fall into ...
_oHex4:
        and     #$0F            ; Isolate bottom 4 bits
        phy
        tay
        lda     hexTable,y
        ply
        jmp     osWrch          ; and return
hexTable:       .byte   "0123456789ABCDEF"
It's easy to read and follow, but yes, is a bit longer and has some extra guards in it to preserve Y - which in a more tighter system may be eliminated, but, for me, its easy to read now and re-read years later and easy to understand.
(and interesting choice of me using Y here - vs the use of X above - no difference in this instance, but just an interesting thing I note)
When I (re) started my 6502 love, I write my own 'wozmon' - it was much bigger than the Woz original, even bigger than the 2K one in the Apple II, but back then what were the constraints? RAM and ROM were very expensive, so Woz had to save every byte he could. I don't have that restriction, so is that making me lazy? Who knows.
I'd actually suggest I'm more lazy because I've never bothered with decimal mode on the 6502 - I've never, ever had a use for it in it's intended use-case, but it's very interesting to see little hacks like this.
Posted: Sat Apr 17, 2021 8:23 pm
by fachat
Haha, I knew it would be old news here :-)
But interestingly for a while here I still thought it would be the shortest one, but then came the BCD version here with 8 bytes http://www.6502.org/tutorials/decimal_mode.html#6
I'm interested what the comment on that page relates to regarding "relying on undocumented behaviour"? The decimal mode is well documented, so why should this be undocumented?
André
Posted: Sat Apr 17, 2021 8:30 pm
I think decimal mode is documented when the hex digits are in the range 0-9, but when they are A-F, the machine does whatever it does - and that's the sort of thing where different implementations can differ.
Posted: Sat Apr 17, 2021 8:43 pm
by fachat
         adc #'f'      (2)
Ha, I see BDD has edited out the max 10 cycles in the original post that I tripped over here :-)
Because if branch is taken the ADC does not count, so it's 8 max.
André
Posted: Sat Apr 17, 2021 8:58 pm
by fachat
So, let's compare the different versions
1. BCD version
     SED
     CMP #$0A
     ADC #$30
     CLD
  • size: 6
  • NMOS: 8 cycles
  • CMOS: 9 cycles (ADC in decimal mode is once add. cycle)
Note: behaviour in decimal mode for values 10-15 typically work, but are actually not defined.
2. Branch version
     CMP #$0A
     BCC SKIP
     ADC #$66
SKIP EOR #$30
  • size: 8
  • NMOS: 7 cycles for digits 0-9, +1 if page is crossed on branch. 8 cycles for digits A-F
  • CMOS: 7 cycles for digits 0-9, +1 if page is crossed on branch. 8 cycles for digits A-F
Note: different versions exist where e.g. the EOR is replaced with ADC (and values adapted) but they have the same properties.
3. Table version
     AND #$0F
     TAY
     LDA HTAB,y
HTAB .BYT "0123456789ABCDEF"
  • size: 22 (assuming HTAB is not in zeropage, in which it would be 21, but 16 of them ZP)
  • NMOS: 8 cycles (+1 if index crosses page boundary)
  • CMOS: 8 cycles (+1 if index crosses page boundary)
Note: additional code and cycles are needed to protect YR (typically easier per byte, not nibble)
Summary
  1. The BCD version is the shortest one with 6 bytes, with the additional benefit of using constant time (per CPU type) of 8 or 9 cycles, but relying on potentially undocumented behaviour
  2. The Branch version is the fastest one with 7-8 cycles, with variable execution time, with 8 byte size.
  3. The table version is the largest, but has constant time of 8 (+1 if page crossing, which can be controlled by placing code) without BCD mode
Posted: Sat Apr 17, 2021 9:55 pm
by BillG
fachat wrote:
3. Table version
     AND #$0F
     TAY
     LDA HTAB,y
Don't the other methods also need to do the "AND $0F"?
Also, if we do both nybbles in a byte, the cost of the table is only an additional 8 bytes per instance.
