Page 1 of 1
Re: CBM IEC Bus Question
Posted: Wed Feb 24, 2021 1:15 pm
by Martin_H
There are likely commercial products that can record and analyze logic levels. But I've seen people use microcontrollers to do that as well. Pretty much any modern microcontroller is a speed demon compared to the IEC bus. So sampling bus states and serializing to a PC for analysis should be straight forward.
Posted: Sun May 01, 2022 11:34 am
by strik
For IEC, even the parallel port of a PC can do the job (that is, if you still have one).
I had written a small program for this many, many years ago (
https://spiro.trikaliotis.net/pposc) which I used for OpenCBM debugging. This program must run on plain DOS, no DOS extended, no virtual 8086 mode.
