Mandelbrot yet again, but this time in assembler
Posted: Tue Oct 27, 2020 7:12 pm
I decided to revisit the Mandelbrot set, but in assembler to see how much faster I could make it than my Forth version. While I'm not an assembler wizard, I'm competent enough, especially when I reuse code libraries to do the hard part of multiplication.
The net result is that assembler is about 4 times faster than Forth, and about 20 times faster than ehBasic. This makes sense when you consider that much of my code uses a Forth like approach, but with primitives like push or drop in-lined rather than called via a subroutine.
Video: https://youtu.be/W24UmuEV0Uc
Github repo: https://github.com/Martin-H1/6502/blob/ ... elbrot.asm
The code depends upon a 16 bit math library and page zero stack macros, but the basic flow is understandable without them. So here's the code with the unused 4.12 fixed point removed:
; Mandelbrot in ASCI art. It uses 8.8 fixed point mathematics in a 16 bit cell
; instead of floating point. It depends upon the stack, math, and I/O functions
; defined in the other modules.
; Martin Heermance <mheermance@gmail.com>
; establish module level scope to hide module locals.
.scope
; Aliases
; Setup constants to remove magic numbers to allow
; for greater zoom with different scale factors.
.alias MAXITER 20
.alias IMAXVAL $0170
.alias IMINVAL $FE90
.alias ISTEP $0010
.alias RMINVAL $FE00
.alias RMAXVAL $0110
.alias RSTEP $000A
.alias ESCAPE $0400
; Data segments
.data BSS
.space CREAL 2 ; These variables hold values during the
.space CIMAG 2 ; escape calculation.
.space ZREAL 2
.space ZIMAG 2
.space COUNT 1 ; current escape count
.text
; Macros
.macro rescale
lda NOS_MSB,x
sta NOS_LSB,x
lda TOS_LSB,x
sta NOS_MSB,x
`drop
.macend
; Functions
; Main entry point
mandelbrot:
.scope
`printcr
`pushi IMAXVAL ; Start iteration at max imaginary
_do: jsr doRow ; For each row in the set.
`printcr
`pushi ISTEP
jsr sub16
`dup
`pushi IMINVAL
jsr compare16
bmi _do
`drop
rts
.scend
; For each cell in a row.
doRow:
.scope
`pushi RMINVAL ; Start iteration at max imaginary
_do: jsr doCell ; For each row in the set.
`pushi RSTEP
jsr add16
`dup
`pushi RMAXVAL
jsr compare16
bpl _do
`drop
rts
.scend
; Iterates on a single cell to compute its escape factor.
; input - row and column on stack.
; output - none
doCell:
jsr initVars
`pushZero ; set the loop up for repeating
_while:
`drop ; drop status from last iteration.
jsr doEscape
`tosZero?
beq _while
`drop
lda COUNT
jsr toChar
rts
; stores the row column values from the stack for the escape calculation.
; input - two cells on stack
; output - none
initVars:
`over
`over
`pop CREAL
`pop CIMAG
`pushzero
`peek ZREAL
`pop ZIMAG
lda #$01
sta COUNT
rts
; Performs a single iteration of the escape calculation.
; input - implicit from memory.
; ouput - true or false.
doEscape:
.scope
jsr zrSq
jsr ziSq
`over
`over
jsr add16
`pushi ESCAPE ; Numbers >= 4 will always escape
jsr compare16
beq +
bpl _else
* `drop ; cleanup the stack and return.
`drop
`pushTrue
rts
_else:
jsr sub16 ; Squared i yeilds negative, so subtract
`push CREAL
jsr add16 ; add real components and leave result on stack
`push ZREAL ; 2 * ZREAL * ZIMAG
`push ZIMAG
jsr mstar
`rescale
`pushi 1
jsr lshift16
`push CIMAG
jsr add16
`pop ZIMAG ; Store stack item into ZIMAG and ZREAL
`pop ZREAL
jmp countAndTest
.scend
; Compute squares, but rescale to remove extra scaling factor.
; output - value on stack
zrSq:
`push ZREAL
`dup
jsr mstar ; rescale by shifting one byte
`rescale
rts
ziSq:
`push ZIMAG
`dup
`rescale
rts
; Translate escape count to ascii greyscale.
; input - value in accumulator
; output - character to console.
toChar:
phy
tay
lda _charVals,y
jsr putch
ply
rts
_charVals:
.byte " ..,'~!^:;[/<&?oxOX# "
; Increment count and compare to max iterations.
; output - true or false on stack
countAndTest:
.scope
inc COUNT
lda COUNT
`pushA
`pushi MAXITER
`if_greater16
`pushTrue
rts
_else: `pushZero
rts
.scend
.scend
