6502 on 8080/Z80 Bus and Vice Versa
Posted: Sat Aug 29, 2020 8:16 am
In this post BigEd points out a project that's using a 6502 on the RC2014 bus, which is designed for 8080 and Z80 CPUs. Myself, I use the RC6502 bus (that link includes a comparison of the two buses), but I've been thinking I'd like to build a Z80 CPU board for that so I could continue to use my existing peripherals. But of course an alternative would be to rework my RC6502-bus CPU boards (currently a 6502, but there will be 6800 and probably 6809 somewhere in the future) and peripherals all to use RC2014 bus.
The two major issues would seem to be translating between the bus protocols and dealing with I/O. For the former, obviously one translates between the Motorola R/WB signal and the two Intel /RD and /WR signals, and of course one must do the correct thing with /MREQ and /IOREQ. What else is involved there?
For I/O, one option is simply to continue using memory-mapped I/O for everything, which is kinda nice in its simplicity. But since I usually have address decode logic on the board with the CPU (my current CPU board includes ROM, RAM and a 6821 PIA, though all of those can be disabled) I've been planning to bring out some of the decode to the bus. (In the Third-party Modifications section of the link above you can see that another RC6502 user has already done this for his systems.) The same sort of idea is used on the RC2014 bus, with the USERn signals. But it occurs to me that on an RC6502 bus accesses to the I/O address space could be used to assert those select signals instead, maybe giving you an easy way of "moving" a 6502 peripheral to I/O address space when using a Z80.
These are just some random thoughts; I've not really worked out any of this in any detail. What are your ideas for the best way to go about this, or is it even a good idea at all?
