Page 1 of 1
Issue with Lattice GAL16V8Z
Posted: Sat Aug 15, 2020 6:16 pm
by Abdlrhman
first of all i could't find this specific chip in the software so i used GAL16V8 as it is pretty mush the same but i couldn't make it work so
what is the VPP voltage for this device i'm using Xgpro software with TL866II PLUS programmer
and what are Encrypt chip,flash and LOCKBIT options ?? Thnx
Re: Issue with Lattice GAL16V8Z
Posted: Mon Sep 21, 2020 11:54 am
by SteveD
Hi,
are you using WinCUPL? If not, what are you using to create the fuse map?
